Signatures are not required for jumps not being applied to specified needs.
If you are doing an accuracy jump for a license (or RW etc), you need a signature to verify. But if you're jumping in a 4 way and it is a zoo, the jump counts for the number and needs no signature.
Last time I tried to figure out the requirements, I understood the SIM to basically require signatures on all jumps until you get your D-license (since the number of jumps is one of the license requirements).
After that, the SIM only requires signatures on jumps towards ratings.
Have I understood the SIM wrong?
I have seen the actual practice of signing logbooks vary widely.
For reference:
http://www.uspa.org/tabid/165/Default.aspx#31c
I ran into a problem with that trying to get awards/wings...must be signed to count for anything for the USPA.
SIM section 8-2 C. 2. b. 7 lists signatures on the log entries as "encouraged but not required" and leaves verification up to the RD or ND.
Radio
Radio
I became a coach for reasons similar to yours. I liked jumping with (and teaching) low timers, and being a coach would expand the people I could jump with.
Take a look at the coach proficiency card and you'll see that the coach course is more about being able to teach the exits and skills that you will teach in Category F, G, H jumps. (It goes without saying that you should be able to perform those skills, yourself. Chances are you learned these as a student.)
The in-air flying skills that you need are awareness (so you can provide good feedback), fall rate, stability, backward movement, and turn-and-track.
Don't sell yourself short. Make a practice jump with a coach or instructor, or even another jumper. If you can perform a Cat H skydive with good control, then you probably have the flying skills you need.
Again, good luck getting your rating.
