d123 4 #1 August 8, 2011 the drouge stays inside the plane, Cessna 206? Theoretically speaking.Lock, Dock and Two Smoking Barrelrolls! Quote Share this post Link to post Share on other sites
AggieDave 6 #2 August 8, 2011 Stays how? Like a chuckle-headed freeflier held on to it when the pair exited, it fell out on the floor while moving around or it got caught on something attached to the plane?--"When I die, may I be surrounded by scattered chrome and burning gasoline." Quote Share this post Link to post Share on other sites
d123 4 #3 August 8, 2011 it fell out on the floor while moving around and lets say it's on the floor behind the pilot chair. The tandem team gets out and the drougue with the bridal unfolding stays in the plane.Lock, Dock and Two Smoking Barrelrolls! Quote Share this post Link to post Share on other sites
Rover 11 #4 August 8, 2011 Quote it fell out on the floor while moving around and lets say it's on the floor behind the pilot chair. The tandem team gets out and the drougue with the bridal unfolding stays in the plane. My guess is that it will follow them out the door. 2 wrongs don't make a right - but 3 lefts do. Quote Share this post Link to post Share on other sites
theonlyski 8 #5 August 8, 2011 Quote Quote it fell out on the floor while moving around and lets say it's on the floor behind the pilot chair. The tandem team gets out and the drougue with the bridal unfolding stays in the plane. My guess is that it will follow them out the door. +1 May get shredded in the process, but that rig needs some work anyways to tighten up the BOC pouch if it just 'fell' out. I wouldn't want to be between a drogue attached to 400 lbs of meat headed away from the plane."I may be a dirty pirate hooker...but I'm not about to go stand on the corner." iluvtofly DPH -7, TDS 578, Muff 5153, SCR 14890 I'm an asshole, and I approve this message Quote Share this post Link to post Share on other sites
AggieDave 6 #6 August 8, 2011 Quote Quote it fell out on the floor while moving around and lets say it's on the floor behind the pilot chair. The tandem team gets out and the drougue with the bridal unfolding stays in the plane. My guess is that it will follow them out the door. Assuming that it doesn't snag something along the way, it would probably just come out and inflate immediately. In a cargo version it would probably then go over the tail. In a standard version, hopefully the pilot would notice and slip hard to keep it from the tail.--"When I die, may I be surrounded by scattered chrome and burning gasoline." Quote Share this post Link to post Share on other sites
theonlyski 8 #7 August 8, 2011 Quote Quote Quote it fell out on the floor while moving around and lets say it's on the floor behind the pilot chair. The tandem team gets out and the drougue with the bridal unfolding stays in the plane. My guess is that it will follow them out the door. Assuming that it doesn't snag something along the way, it would probably just come out and inflate immediately. In a cargo version it would probably then go over the tail. In a standard version, hopefully the pilot would notice and slip hard to keep it from the tail. I know you've been around the block way more than I have, but I cannot see how the tandem pair pulling down on the drogue could cause it to inflate and go OVER the tail. The bottom of the cargo door is a good foot under the elevator, Sure, a fast and hard slip would help, but I don't think the chances would be too high of it wrapping the tail."I may be a dirty pirate hooker...but I'm not about to go stand on the corner." iluvtofly DPH -7, TDS 578, Muff 5153, SCR 14890 I'm an asshole, and I approve this message Quote Share this post Link to post Share on other sites
AggieDave 6 #8 August 8, 2011 You're assuming that the drogue will be at bridle stretch, I'm assuming that it will come out rolled up sooner than that and inflate with slack. As of a few years ago people never thought that someone could go over the tail of an Otter...then someone proved them wrong.--"When I die, may I be surrounded by scattered chrome and burning gasoline." Quote Share this post Link to post Share on other sites
mark 107 #9 August 8, 2011 Here's one possibility: http://www.dropzone.com/cgi-bin/forum/gforum.cgi?post=323234. Mark Quote Share this post Link to post Share on other sites
theonlyski 8 #10 August 8, 2011 Given the parameters he asked: "it fell out on the floor while moving around and lets say it's on the floor behind the pilot chair. The tandem team gets out and the drougue with the bridal unfolding stays in the plane." Led me to think that it would be at bridle stretch. But, I do see your point. Either way, that rig shouldn't be in the air with a BOC that loose. "I may be a dirty pirate hooker...but I'm not about to go stand on the corner." iluvtofly DPH -7, TDS 578, Muff 5153, SCR 14890 I'm an asshole, and I approve this message Quote Share this post Link to post Share on other sites
AggieDave 6 #11 August 8, 2011 Sometimes things happen. That's why I like to do another round of handle touches as I get to the door. I started doing that after I got a drogue stuck under a flap handle on an old narrow body 182. Luckily another TI was in the plane and we were able to prevent a situation from going badly.--"When I die, may I be surrounded by scattered chrome and burning gasoline." Quote Share this post Link to post Share on other sites
AdD 1 #12 August 8, 2011 Hopefully: 1) Disconnect RSL 2) Cutaway 3) Release drogueLife is ez On the dz Every jumper's dream 3 rigs and an airstream Quote Share this post Link to post Share on other sites
Abedy 0 #13 August 8, 2011 (Mandatory) Checking both drogue and first release (Vector-style rigs with 1st release at left bottom of container) before getting out of the door is part of TI courses in Germany. You'll see all TI's checking drogue and 1st release the moment before they shove out the student. (A full round of handle checks immediately after deploying the drogue is also seen with most TI's and mandatory here at my DZ, BTW.)The sky is not the limit. The ground is. The Society of Skydiving Ducks Quote Share this post Link to post Share on other sites
AggieDave 6 #14 August 8, 2011 Quote(Mandatory) Checking both drogue and first release (Vector-style rigs with 1st release at left bottom of container) before getting out of the door is part of TI courses in Germany. You'll see all TI's checking drogue and 1st release the moment before they shove out the student. (A full round of handle checks immediately after deploying the drogue is also seen with most TI's and mandatory here at my DZ, BTW.) Same here, but what I've done is add another round of handle checks right before the door in addition to the one that I do just after to hooking up the student.--"When I die, may I be surrounded by scattered chrome and burning gasoline." Quote Share this post Link to post Share on other sites
Abedy 0 #15 August 8, 2011 You got to be kidding? Cutaway before releasing the drogue? Stick to the sequence! Only(*) occasion you cutaway and bypass releasing the drogue is if drogue or drogue bridle become entangled with you or your student and you can't untangle it, but this wasn't talked about here. (*)OK, side-spin might be treated this way as well, but I know this is controversial and too far from the OT.The sky is not the limit. The ground is. The Society of Skydiving Ducks Quote Share this post Link to post Share on other sites
Rover 11 #16 August 8, 2011 QuoteYou got to be kidding? Cutaway before releasing the drogue? Stick to the sequence! Only(*) occasion you cutaway and bypass releasing the drogue is if drogue or drogue bridle become entangled with you or your student and you can't untangle it, but this wasn't talked about here. (*)OK, side-spin might be treated this way as well, but I know this is controversial and too far from the OT. If the drogue is hung up in the plane and cannot be cleared then 1 Cutaway 2 Pull drogue release 3 Deploy reserve.2 wrongs don't make a right - but 3 lefts do. Quote Share this post Link to post Share on other sites
Divalent 170 #17 August 8, 2011 Quote If the drogue is hung up in the plane and cannot be cleared then 1 Cutaway 2 Pull drogue release 3 Deploy reserve. 4 Watch plane crash? Quote Share this post Link to post Share on other sites
Andrewwhyte 1 #18 August 9, 2011 QuoteHopefully: 1) Disconnect RSL 2) Cutaway 3) Release drogue Why on earth would you disconnect the RSL? Quote Share this post Link to post Share on other sites
theonlyski 8 #19 August 9, 2011 QuoteQuoteHopefully: 1) Disconnect RSL 2) Cutaway 3) Release drogue Why on earth would you disconnect the RSL? Gotta get some freefall out of the deal. I would want to get some distance from the now pissed off pilot before I popped another canopy out."I may be a dirty pirate hooker...but I'm not about to go stand on the corner." iluvtofly DPH -7, TDS 578, Muff 5153, SCR 14890 I'm an asshole, and I approve this message Quote Share this post Link to post Share on other sites
theonlyski 8 #20 August 9, 2011 QuoteQuote If the drogue is hung up in the plane and cannot be cleared then 1 Cutaway 2 Pull drogue release 3 Deploy reserve. 4 Watch plane crash? 5 Buy pilot beer, if he survived the bail out."I may be a dirty pirate hooker...but I'm not about to go stand on the corner." iluvtofly DPH -7, TDS 578, Muff 5153, SCR 14890 I'm an asshole, and I approve this message Quote Share this post Link to post Share on other sites
Andrewwhyte 1 #21 August 9, 2011 Yay for T-terminal reserve deployments. Quote Share this post Link to post Share on other sites
Abedy 0 #22 August 9, 2011 Quote ...If the drogue is hung up in the plane... Ah, didn't see that from what is was in reply to. Didn#T think of the drogue being stuck. (Thread-related tunnel vision, so to say ) Anyway, here in Germany, the 2nd release is routed through the cutaway handle (mandatory) and thus the suggested sequence not possible.The sky is not the limit. The ground is. The Society of Skydiving Ducks Quote Share this post Link to post Share on other sites
Andrewwhyte 1 #23 August 9, 2011 Quote Anyway, here in Germany, the 2nd release is routed through the cutaway handle (mandatory) and thus the suggested sequence not possible. Does that mean Sigmas are prohibited? Quote Share this post Link to post Share on other sites
riggerrob 644 #24 August 9, 2011 "QuoteHopefully: 1) Disconnect RSL ??????????????????????????????? 2) Cutaway ??????????????????????????????? 3) Release drogue" ........................................................................ Please explain the logic behind pulling handles out-of-sequence. Hint: more than half of the dead TIs pulled handles out-of-sequence. Rob Warner Strong Tandem Examiner Vector TI since 1986 Racer TI since 1996 Quote Share this post Link to post Share on other sites
Abedy 0 #25 August 10, 2011 No, Sigmas here just get modified, the second release is routed through the cutaway handle.The sky is not the limit. The ground is. The Society of Skydiving Ducks Quote Share this post Link to post Share on other sites
