Cantoral 1 #1 July 10, 2010 Wow many jumps its the minimum that a student have to do during the S/L course? Quote Share this post Link to post Share on other sites
dragon2 2 #2 July 10, 2010 That depends on where you are. Over here, it's 3 SLs + 2 PRCPs, minimum, so 5. ciel bleu, Saskia Quote Share this post Link to post Share on other sites
wolfriverjoe 1,523 #3 July 11, 2010 QuoteThat depends on where you are. Over here, it's 3 SLs + 2 PRCPs, minimum, so 5. And over here it's 2 S/Ls and 3 PRCPs minimum, so still 5"There are NO situations which do not call for a French Maid outfit." Lucky McSwervy "~ya don't GET old by being weak & stupid!" - Airtwardo Quote Share this post Link to post Share on other sites
riggerrob 644 #4 July 11, 2010 I have seen students graduate with as few as three static-line jumps. The first jump only required a stable exit. They did graceful practice ripcord pulls on their second and third jumps and did short freefalls on their fourth jumps. HOWEVER, avoid getting hung-up on numbers - this early in your learning curve. Mastering basic skills - early - is very important, because you will have to deploy your own main parachute on ALL subsequent skydives. Quote Share this post Link to post Share on other sites
theonlyski 8 #5 July 11, 2010 Quote I have seen students graduate with as few as three static-line jumps. The first jump only required a stable exit. They did graceful practice ripcord pulls on their second and third jumps and did short freefalls on their fourth jumps. HOWEVER, avoid getting hung-up on numbers - this early in your learning curve. Mastering basic skills - early - is very important, because you will have to deploy your own main parachute on ALL subsequent skydives. Only the ones you plan on surviving."I may be a dirty pirate hooker...but I'm not about to go stand on the corner." iluvtofly DPH -7, TDS 578, Muff 5153, SCR 14890 I'm an asshole, and I approve this message Quote Share this post Link to post Share on other sites
