adietkin 0 #1 November 19, 2006 are you as TI agree to jump without the rsl if your dzo diecide to take the rsl out from system? Quote Share this post Link to post Share on other sites
stratostar 5 #2 November 19, 2006 And what is the DZO's reason for the taking them off the system, when it can remain in place and be unattached?you can't pay for kids schoolin' with love of skydiving! ~ Airtwardo Quote Share this post Link to post Share on other sites
teason 0 #3 November 19, 2006 Is it the double sided feature that Roy doesn't like or is it RSLs in general?I would rather be a superb meteor, every atom of me in magnificent glow, than a sleepy and permanent planet. Quote Share this post Link to post Share on other sites
riggerrob 644 #4 November 19, 2006 I really like RSLs, but am suspicious of the double-sided RSLs installed on Racers. Twenty plus years ago, when Canadian DZs started converting to piggyback containers for students, there were a couple of cases of students cutting away, but having their double-sided RSLs hang up on the back of their helmets. Ergo, I always use the RSL when jumping Strong and RWS tandems as well as my Talon 2. The only reason that my Vector 2 does not have an RSL is that it is too expensive to retrofit. Quote Share this post Link to post Share on other sites
taffclarke 0 #5 November 19, 2006 QuoteIs it the double sided feature that Roy doesn't like or is it RSLs in general? I am not sure of the legal ramifications of such a move, I think jump shack might have something to say about it. however the rsl system is there if ever a tandem master has a right hand incapacitated or can not for any other reason pull the reserve handle! To me it sounds like a panic response to an incident this weekend at sky kef were a tandem master had two canopies out, since the rest of the info I have is rumor I will refrain from further comment on that. However removing the RSL or tampering with the safety features bad bad bad! What if the reserve handle cannot be pulled? What will the tandem master do then? No rsl safety system to back you up?safety enjoyment learning, sel the sport. dont kill it. Quote Share this post Link to post Share on other sites
teason 0 #6 November 19, 2006 If you remember the rigs that Jim had in Beiseker, his racer's had one sided RSLs. While not approved by Jumpshack AFAIK, I don't think they are forbiddenI would rather be a superb meteor, every atom of me in magnificent glow, than a sleepy and permanent planet. Quote Share this post Link to post Share on other sites
taffclarke 0 #7 November 19, 2006 yep i remember i think we had them changed as well to the doubles i arranged for two to be shipped over here and they both had double rsl on safety enjoyment learning, sel the sport. dont kill it. Quote Share this post Link to post Share on other sites
Andrewwhyte 1 #8 November 20, 2006 Quote While not approved by Jumpshack AFAIK, I don't think they are forbidden If they are not specifically approved by the manufacturer then they are forbidden since they are part of the reserve deployment system AFAIK. This is similar to Talon's beef with Vigil; you need approval to fuck with a TSOd part. Quote Share this post Link to post Share on other sites
taffclarke 0 #9 November 20, 2006 good point it would void the tso, and a new one would need to be applied for.safety enjoyment learning, sel the sport. dont kill it. Quote Share this post Link to post Share on other sites
teason 0 #10 November 20, 2006 That's only if the Racer RSL is a TSO'd componant. The Racer RSL is not TSO'd. It does not have a serial number and it is considered an accessory and not a system. The Racer Tandem also does not require an RSL. It ultimately lands on the TIs shoulders on whether or not they will jump it as they are responsible. Finally, you're in Canada what do you care Just kidding, I know you guys like TSOs, hence all the lovely new Sidewinders. I'm just busting your assI would rather be a superb meteor, every atom of me in magnificent glow, than a sleepy and permanent planet. Quote Share this post Link to post Share on other sites
riggerrob 644 #11 November 21, 2006 According to Ray Ferrel (FAA DPRE, long-time manager of Sky Dance and before that manager of GQ Security's factory) you can attach both sides of a Racer RSL to one riser, converting it to a single-sided RSL. Remember that - back in the early 1990s - Ray held Supplementary Type Certificates to retrofit RSLs to most TSOed containers. Ray's RSL-retrofit business peaked about the time Cypres was introduced. For example, he retrofitted my two-pin Mirage in 1993. Cypres did not become fashionable in Southern California until 1994 or 1995. Quote Share this post Link to post Share on other sites
SkymonkeyONE 4 #12 November 29, 2006 That is true. I was asked when I ordered my new 2k3 racer tandem if I wanted the RSL; I said "yes." Quote Share this post Link to post Share on other sites
lug 4 #13 December 21, 2006 I can’t find anything to the contrary in the BSRs or FAA so a rig owner does have the choice whether the RSL is install or not. I was under the impression that the rig had to be RSL equipped but it was the user choice to make the final connection. Personally I think that every DZ should have the RSL installed on every rig they own that is provided for their instructors to use. However it is then up to the individual instructor to decide whether or not the RSL is connected to the risers.Memento Mori Quote Share this post Link to post Share on other sites
brettpobastad 0 #14 January 11, 2007 Why would anyone want to remove or disable a safety device?"It's only arrogance if you can't back it up" Quote Share this post Link to post Share on other sites
friday999 0 #15 January 11, 2007 Because in this case it could kill you. This question was asked after an incident when the tandem pair was injured, which could have ended much worse. Quote Share this post Link to post Share on other sites
