KevinSpencer 0 #1 August 10, 2004 I'm from a very small Canadian DZ. After several months of climbouts and training I got the go ahead to dispatch (IAD hanging exit) students on their pratice pulls. My question to you, "Is it smart to turn on your Cypress." The whole idea of climbing out onto the wing with your back exposed to the prop of a C182 sort of bothers me. If that thing ever miss fires my reserve into the prop pretty much everyone on the plane is dead. The 3 other instructors at the DZ don't have an AAD. Then on the other hand say if I slip and get knocked out (which I think will never happen but you can't be too sure) the AAD will save my life. So if your an IAD instructor can you let me know.River City Crew Rocks Quote Share this post Link to post Share on other sites
AggieDave 6 #2 August 10, 2004 What AAD's are you using? I would think that with modern AADs it would be a non-issue, much safer to have a student with one then without one. However, I am not a SL/IAD rated instructor so take my opinion or leave it.--"When I die, may I be surrounded by scattered chrome and burning gasoline." Quote Share this post Link to post Share on other sites
nightjumps 1 #3 August 10, 2004 QuoteThe whole idea of climbing out onto the wing with your back exposed to the prop of a C182 sort of bothers me. I am VERy confused by this statement. Exactly how are you climbing out that your reserve is exposed to the prop??? When I climb out with the student, we're side by side facing forward. I have one hand on the strut, both feet on the step, and my hand with their P/C in their back the whole way. Please elaborate. Quote Share this post Link to post Share on other sites
JohnMitchell 16 #4 August 10, 2004 For any jumper, the tail behind you is more dangerous than the propellor in front of you. If you are sitting in the crotch of the plane(where the strut joins the fuselage) facing to the rear, and your main or reserve come out and goes below the strut, you're in a world of hurt. I've seen unintentional deployments on mains and reserves (been the victim of both), but never Cypress caused. I'm going to say it's way down on the worry list. My 2 cents. Quote Share this post Link to post Share on other sites
JYorkster 0 #5 August 10, 2004 You're more likely to have a main opening due to poor maintenance, worn closing loop, etc, than a faulty cypres fire. Also, like Bigun said, you should not have your back facing the prop anyway. For IAD, you should be out of the plane, next to the student, 90 degrees to the line of flight. Because you're working with students, I think you're safer with it on than with it off. Just my 2 cents, Rock (S/L and IAD I) Quote Share this post Link to post Share on other sites
Remster 30 #6 August 10, 2004 QuoteWhen I climb out with the student, we're side by side facing forward. I have one hand on the strut, both feet on the step, and my hand with their P/C in their back the whole way. Dont know if this is a Canada vs USA technique issue, but thats not how we (well, I) are trained to do IADs. From a Cesna, I'll have my left hand on the strut, fairly far out, my right hand on the yoke of the student's container holding the PC, left foot on the step/wheel, and right foot on the back edge of the door. My Container would be roughly facing the 10 o'clock direction of the plane axis, maybe a bit angled upward. By the way, I woulnt worry too much about a Cypress in this situation. The bigger risk is one of your pins getting puched, rubbing on the door frame while climbing out.Remster Quote Share this post Link to post Share on other sites
nightjumps 1 #7 August 10, 2004 QuoteI'll have my left hand on the strut, fairly far out, my right hand on the yoke of the student's container holding the PC, left foot on the step/wheel, and right foot on the back edge of the door. My Container would be roughly facing the 10 o'clock direction of the plane axis, maybe a bit angled upward. I think we "may" be doing the same thing during the initial climbout, in which my body is about the same. If you stop there, then that's where the difference begins. As the student is swinging out on the strut, my right foot then gets brought to the right furthest edge of the strut and I am squatting on the step facing forward so that I am inches from their face and can ensure my right arm with the P/C and bridle remains in the center of their back. Quote Share this post Link to post Share on other sites
Remster 30 #8 August 10, 2004 Its been a while since I dispatched, but from memory, I end up pretty close to their faces too... As long as you really get out there. I saw some IADs from a DZ I wont name in McGowans' Greatest Hits where the Instructor (who actually is the DZO) barelly gets out the plane....Remster Quote Share this post Link to post Share on other sites
MajorDad 0 #9 August 10, 2004 Remi did a pretty good description on the JM climbout for an IAD. I always had my cypress on when I was dispatching and never gave it a second thought as it was well outside of the activation parameters. Proper climbout/climb-in to avoiding brushing of the pin while managing the student was higher on the priority list. If you are new to jumpmastering, you may (if you haven't done so) want to have the chief instructor watch and critique your climbout technique. Major Dad CSPA D-579 Quote Share this post Link to post Share on other sites
d604 0 #10 August 10, 2004 Hey, if your cypress is properly maintained it is fine, your better off having it for the scenario (although very unlikely) you described. Other s have said it but you will want to work on not having your rig facing the prop, try to get it so that it's facing up and/or up and back, it's not hard to learn. Sean CSPA Instructor A Quote Share this post Link to post Share on other sites
KevinSpencer 0 #11 August 11, 2004 After watching myself dispatch, My back is faced more to the door then anything. I'll keep my cypress on and a close watch on my Main, thank youRiver City Crew Rocks Quote Share this post Link to post Share on other sites
skydived19006 4 #12 August 12, 2004 This whole argument makes you kind’a miss static lines doesn’t it (I know there are a quite a few DZs using static lines, and most likely more SL than IAD)? I know I was personally quite a bit more comfortable when I was putting out static lines. We train IAD at my DZ, and like others I can’t understand why you would be back to the prop? On a related note, when we used static lines we never had the pilot put in flaps. It’s my understanding that 10 degrees of flap is supposed to help any potential premature opening (on the student) go under the horizontal stabilizer. Is this standard, do you do it at your DZ, is the reasoning I give correct?Experience is what you get when you thought you were going to get something else. AC DZ Quote Share this post Link to post Share on other sites
riggerrob 644 #13 August 13, 2004 Most of the IAD Instructors at Pitt Meadows wear Cypres and they have dropped thousands of students without accidental deployments. Most IAD instructors wear Cypres and I have never heard of their reserves deploy unexpectedly. Instructors are supposed to lead by example. Leading by example includes wearing modern AADs and turning them on. Quote Share this post Link to post Share on other sites
teason 0 #14 August 18, 2004 How do you kepp the PC out of the burble? When the student releases, the JM should bring the pilotchute down and off to the side, about arms length from the burble. The way you're describing would seem to require alot of twisting. The only other way to pitch the PC that way is to bring it up, releasing it above the head. That method is potentially dangerous as it increases the risk of the student entangling with the PC! I think I must be missing something. Could you elaborate?I would rather be a superb meteor, every atom of me in magnificent glow, than a sleepy and permanent planet. Quote Share this post Link to post Share on other sites
teason 0 #15 August 18, 2004 ARRRGGHH! I know the DZ and the video! Gawd! It drives me freakin' nuts everytimr I see it!!!!!!!!!!!! I would rather be a superb meteor, every atom of me in magnificent glow, than a sleepy and permanent planet. Quote Share this post Link to post Share on other sites
BIGUN 1,521 #16 August 18, 2004 THis is nightjumps...changed my handle to Bigun. QuoteHow do you kepp the PC out of the burble? When the student releases, the JM should bring the pilotchute down and off to the side, about arms length from the burble. The way you're describing would seem to require alot of twisting. You want to keep the P/C in the burble during the climbout. It's when you tell the student to go and they release that you toss it down and aside. No twisting involved.Nobody has time to listen; because they're desperately chasing the need of being heard. Quote Share this post Link to post Share on other sites
teason 0 #17 August 18, 2004 OK ... DUH! My question was about what you do on the release. I'm trying to picture a clean throw but I'm having trouble. Can you tell me where you release the pilotchute in relation to the student? What is your timing? What is your body orientation? Have you seen your deployments on video? I've watched probably about 7000 or 8000 IAD students (most of which I dispatched) on video in slow mo and with 4-5 still pictures taken in a 1.5 sec window. I've seen all types of releases and timings as well as pilotchute inflations. It doesn't matter how you follow your student out as long as you can 1.) control the student 2.) protect the gear 3.) deal with emergencies 4.) ensure a proper deployment I have no idea about the first 3, I assume you do it well, but I'm trying to visualize the 4th. Please elaborate, I'm having trouble picturing your technique during the student's release.I would rather be a superb meteor, every atom of me in magnificent glow, than a sleepy and permanent planet. Quote Share this post Link to post Share on other sites
BIGUN 1,521 #18 August 18, 2004 Quote4.) ensure a proper deployment It is hard to visualize textually, but I'll try. First,I should share with you that I've got a 38" each. Picture me on the step with both feet squatting down facing forward, left hand on the strut, right hand in their back in the burble. The student is hanging on the strut and I give the the "Go" command. As soon as they let go, I flick my arm back and down at about eight o'clock from their position and to the rear As the P/C catches air and begins inflatig, they too are falling. By throwing it at their eight o'clock as they release, the P/C come to about nine-o'clock (perpendicular to them) catches the air and whips behind them. That help?Nobody has time to listen; because they're desperately chasing the need of being heard. Quote Share this post Link to post Share on other sites
Remster 30 #19 August 18, 2004 QuoteARRRGGHH! I know the DZ and the video! hehehe... I knew that would rile up some fellow northerners! As far as Bigun's method, if I end up dispaching again, I'll stick to the CSPA method... I feel it allows better positioning of the PC in the airstream and of the instructor to see the jump better, without a lot of moving around on the step... Sorry Biguns! Remster Quote Share this post Link to post Share on other sites
teason 0 #20 August 18, 2004 OK I think I can see it now, sounds like good PC placement. ThanksI'm with Remster, though, you can't teach and old dog yadda yadda... I also like being able to touch the students head/face while they are hanging. It helps to get their head up. I would rather be a superb meteor, every atom of me in magnificent glow, than a sleepy and permanent planet. Quote Share this post Link to post Share on other sites
BIGUN 1,521 #21 August 18, 2004 No worries, mate. It's kinda like packing - a little different isn't the same as wrong. I have a bit of an advantage on most because of my length.Nobody has time to listen; because they're desperately chasing the need of being heard. Quote Share this post Link to post Share on other sites
