patworks 5 #1 August 16, 2012 As a parachuting teen in the new 60s I was keen on having my gear function. Like everyone, I had two-shot capewell canopy releases. Just pull down the cover, squeeze dinky two buttons together, and your canopy would release sometimes. 2-shots purpose was to allow downed air crew the option of cutting away a canopy after an emergency over windy terrain. The GSA having determined that getting dragged across Tera firma to death after surviving a bail-out was counter productive and messy, added 2-shots as a back up canopy release to the hook knife and chaff in riser pockets. - Me, being serious about function, pounds 2-ten-penny nails in a tree limb as a coat-hook for my risers. Saddled in. I mime a mal + cut-a-way which would drop me on my ass. No release. No drop. So, an engineering sort, I polish and file the release tabs. More failures albeit smoother. Whilst one side cut away the other didn't. Counting out-loud (i'm a student) ONE-THOUSAND: TWO THOUSAND: etc. etc. I'd get to big numbers before I'd get release. On one side, if any. That concern resolved, I determined that circular 28' C9 flat canopies did not warrant a cut-away noway and proceeded down the yellow brick road to Emerald City. Years thereafter the introduction of the PC was joined at the hip by nasty spinning Hi-G malfunctions. Then there, in those days of "Reserve Pilot-Chute Removed for Sport Parachuting" shot-and-one-half capewells functioned better than the no-cutaway boogie dance of, "PULL! PUNCH! THROW IN DIRECTION OF SPIN! SHAKE LINES: ASSIST OPENING. . . " ... hope for trees. Having about 15 cut aways on shot+1/2 and 25 -30 more on 3-rings has reinforced my confidence that sport reserve parachutes work well. Howsomeever, methinks that the USAF still uses shot+1/2s.... this is cool cauz they got no reserve. .... do they still jump rounds? Hope not.Pat Works nee Madden Travis Works, Jr .B1575, C1798, D1813, Star Crest Solo#1, USPA#189, Quote Share this post Link to post Share on other sites
lekstrom10k 0 #2 August 16, 2012 The main reson for the capewell alos was to make the rigs inter-changable . The lines were sewn to the risers the main lift web became the risers etc . If you had a bad canopy but good harness pitch it all . If the rig was bad and a good canopy again pitch it all. Capewell was the name of the company that made the adapters. some Navy rigs only had them on one side to collapse the canopy if being drug in sea water. The 26 foot Navy reserve had sea pockets to help slow down the dragging process. Quote Share this post Link to post Share on other sites
ripcord4 0 #3 August 16, 2012 " do they still jump rounds? Hope not. " Oh yeah, all the services still use the old reliable C9 28' canopy as the emergency bailout rig. Harness and containers vary from the B12 but are basically the same rig as back in the '60's. Quote Share this post Link to post Share on other sites
riggerrob 644 #4 August 16, 2012 Capewells were originally designed to release canopies that were dragging aircrew to their deaths. Then those silly skydivers started using Capewells for a role - in air cutaway - that they were never originally designed for. The tension on Capewells must be at least double when you are hanging from a partially inflated main. Quote Share this post Link to post Share on other sites
mjosparky 4 #5 August 16, 2012 Here you go Pat, 2 shots. SparkyMy idea of a fair fight is clubbing baby seals Quote Share this post Link to post Share on other sites
steve1 5 #6 August 17, 2012 Gee Whiz Pat, you've done a lot of cut-aways! We used to practice a far amount on a suspended harness with shot and a half's. I never had any trouble with them releasing. We used two shots when static line jumping in the army. The ones they had forty years ago looked a little different than the ones in the pictures. I knew some jumpers, in the early 70's, who had one shot capewells. I was wondering what you thought of them? Quote Share this post Link to post Share on other sites
lekstrom10k 0 #7 August 17, 2012 The one shot capewell was mostly on the early crossbow pig rigs . while nice in concept they never really oneshotted. You could pull the covers down then smackthem both at the same time to be gone. That rig had the first RSL in 1964 but you had the make sure you released the right side slightly before the left as ther were no cross cpnnectors between risers. Obviously they worked for me many times with the ropes and rings Paraplane clouds Quote Share this post Link to post Share on other sites
likestojump 3 #8 August 17, 2012 Quote" do they still jump rounds? Hope not. " Oh yeah, all the services still use the old reliable C9 28' canopy as the emergency bailout rig. Harness and containers vary from the B12 but are basically the same rig as back in the '60's. What's this then ? (hint : only bailout qualified for use on a P-3) Quote Share this post Link to post Share on other sites
masterrigger1 2 #9 August 17, 2012 *** Oh yeah, all the services still use the old reliable C9 28' canopy as the emergency bailout rig. Harness and containers vary from the B12 but are basically the same rig as back in the '60's. -------------------------------------------------------------------------------- What's this then ? (hint : only bailout qualified for use on a P-3) Quote It may br the only rig now used in the P-3, but other rigs were, and still are, qualified to be used in the P-3. You have to remember that the the P-3 was brought out in the '60's and the rig shown was not available until the mid to late late "90's. MELSkyworks Parachute Service, LLC www.Skyworksparachuteservice.com Quote Share this post Link to post Share on other sites likestojump 3 #10 August 17, 2012 Quote*** Oh yeah, all the services still use the old reliable C9 28' canopy as the emergency bailout rig. Harness and containers vary from the B12 but are basically the same rig as back in the '60's. -------------------------------------------------------------------------------- What's this then ? (hint : only bailout qualified for use on a P-3) Quote It may br the only rig now used in the P-3, but other rigs were, and still are, qualified to be used in the P-3. You have to remember that the the P-3 was brought out in the '60's and the rig shown was not available until the mid to late late "90's. MEL lost in translation :) All I meant to convey is that there are alternatives to C9s out there that some of the armed forces use. Otherwise, of course, you are 100% correct, and I wasn't arguing. Quote Share this post Link to post Share on other sites ripcord4 0 #11 August 17, 2012 Perhaps I mis-spoke....I did not mean to imply that the C9 was used EXCLUSIVELY...only that it is still in use. By the way, what canopy is in that square-look-alike? I find it hard to believe it is a square. Quote Share this post Link to post Share on other sites mjosparky 4 #12 August 17, 2012 QuoteQuote" do they still jump rounds? Hope not. " Oh yeah, all the services still use the old reliable C9 28' canopy as the emergency bailout rig. Harness and containers vary from the B12 but are basically the same rig as back in the '60's. What's this then ? (hint : only bailout qualified for use on a P-3) It is called the Thin Pack or Dura Pack. It comes in 3 versions, the basic aircrew like the picture, a version for the P-3 and a third for the E2-C. They also tried a civilian version. http://i397.photobucket.com/albums/pp55/mjosparky/Testing/LiveTest2.jpg SparkyMy idea of a fair fight is clubbing baby seals Quote Share this post Link to post Share on other sites andrewhilton 1 #13 August 17, 2012 And a whole selection of capewell and other canopy releases http://www.flickr.com/photos/vintageparachutegear/sets/72157622676844920/ Quote Share this post Link to post Share on other sites likestojump 3 #14 August 17, 2012 QuoteQuoteQuote" do they still jump rounds? Hope not. " Oh yeah, all the services still use the old reliable C9 28' canopy as the emergency bailout rig. Harness and containers vary from the B12 but are basically the same rig as back in the '60's. What's this then ? (hint : only bailout qualified for use on a P-3) It is called the Thin Pack or Dura Pack. It comes in 3 versions, the basic aircrew like the picture, a version for the P-3 and a third for the E2-C. They also tried a civilian version. http://i397.photobucket.com/albums/pp55/mjosparky/Testing/LiveTest2.jpg Sparky the version that I have is a P22P Durachute from BAE here's more info http://events.us.baesystems.com/AUSA11/prodserv/Durachute.html for whatever reason the website that BAE had for the product no longer exists, but this thing has a 5year repack cycle due to being vacuum sealed. more info http://www.docstoc.com/docs/69851368/The-Durachute-Vacuum-Sealed-Rescue-Parachute# Quote Share this post Link to post Share on other sites mjosparky 4 #15 August 18, 2012 QuoteQuoteQuoteQuote" do they still jump rounds? Hope not. " Oh yeah, all the services still use the old reliable C9 28' canopy as the emergency bailout rig. Harness and containers vary from the B12 but are basically the same rig as back in the '60's. What's this then ? (hint : only bailout qualified for use on a P-3) It is called the Thin Pack or Dura Pack. It comes in 3 versions, the basic aircrew like the picture, a version for the P-3 and a third for the E2-C. They also tried a civilian version. http://i397.photobucket.com/albums/pp55/mjosparky/Testing/LiveTest2.jpg Sparky the version that I have is a P22P Durachute from BAE here's more info http://events.us.baesystems.com/AUSA11/prodserv/Durachute.html for whatever reason the website that BAE had for the product no longer exists, but this thing has a 5year repack cycle due to being vacuum sealed. more info http://www.docstoc.com/docs/69851368/The-Durachute-Vacuum-Sealed-Rescue-Parachute# It was originally developed by a company out of the Phoenix area called Simula. I am very familiar with it…..I was involved in the testing both for the Navy and for the TSO. I did all the live jumps on it for the TSO. Here is some more shit on it. http://www.tslaerospace.com/product/simula/PDF/durachute_cypres.pdf SparkyMy idea of a fair fight is clubbing baby seals Quote Share this post Link to post Share on other sites riggerrob 644 #16 August 19, 2012 What is the diameter of the canopy? How fast does it descend? Quote Share this post Link to post Share on other sites Spooky52 0 #17 August 19, 2012 Did you do the Navy test jumps at El Centro? If so, when were you there? I was at El Centro from Nov 68 until April 1970. I was in the Air Force side of things. JimIf you know how many guns you have - you don't have enough! Quote Share this post Link to post Share on other sites Periapt 0 #18 August 29, 2012 QuoteAnd a whole selection of capewell and other canopy releases http://www.flickr.com/photos/vintageparachutegear/sets/72157622676844920/ Quite a display of various ways to release canopies. All employ the concept of leverage or other mechanical advantage to decrease the tension on the actual release point beginning with modifications of the capewll system, then to webbing arangements. This can be viewed as the evolutionary path to the 3-ring releases that are seen on virtually all modern sport rigs. Fascinating and educational. Quote Share this post Link to post Share on other sites mjosparky 4 #19 August 29, 2012 QuoteQuoteAnd a whole selection of capewell and other canopy releases http://www.flickr.com/photos/vintageparachutegear/sets/72157622676844920/ Quite a display of various ways to release canopies. All employ the concept of leverage or other mechanical advantage to decrease the tension on the actual release point beginning with modifications of the capewll system, then to webbing arangements. This can be viewed as the evolutionary path to the 3-ring releases that are seen on virtually all modern sport rigs. Fascinating and educational. Except many of them evolved after the 3-ring system was already on the market. SparkyMy idea of a fair fight is clubbing baby seals Quote Share this post Link to post Share on other sites leon.hill 1 #20 August 30, 2012 It was originally developed out of a company in Asheville NC, SEI or Safety Equipment International. I worked there directly with the Navy test jumpers and Engineers out of China Lake, CA to develop the packing and sealing processes of the P3 and E2C parachutes. The Navy has since taken control of all the drawings, which is why SEI, bought and moved to Phoenix, renamed Simula, then bought by Armor Holdings, then finally sold to BAE Systems no longer manufacture them. They called it the Durachute and did not have much demand for their civilian version. And yes, it had a Five year repack cycle due to the vacuum sealing process. Quote Share this post Link to post Share on other sites mjosparky 4 #21 August 30, 2012 QuoteIt was originally developed out of a company in Asheville NC, SEI or Safety Equipment International. I worked there directly with the Navy test jumpers and Engineers out of China Lake, CA to develop the packing and sealing processes of the P3 and E2C parachutes. The Navy has since taken control of all the drawings, which is why SEI, bought and moved to Phoenix, renamed Simula, then bought by Armor Holdings, then finally sold to BAE Systems no longer manufacture them. They called it the Durachute and did not have much demand for their civilian version. And yes, it had a Five year repack cycle due to the vacuum sealing process. It was developed by Simula a company in Apache Junction just outside of Phoenix. SEI is a division of Simula. AERO a company owned by Joe Crotwell was involved in the testing of the base unit testing and also the P-3 and E2-C versions. If you were working with the guys at China Lake you will remember the King Air used in testing. That was AERO,s plane. At time I was director of air drops with AERO. Sparky The guy in the gray jumpsuit is the Simula rigger who was responsible for most of the design work.My idea of a fair fight is clubbing baby seals Quote Share this post Link to post Share on other sites leon.hill 1 #22 August 31, 2012 Okay...a little of my background with SEI. I worked at SEI in Asheville,NC from 2000-2003. I worked with 3 designers and several individuals who jumped and did R&D with the P3 prior to my arrival there. At the time, SEI was not owned by anyone else. It was purchased by Simula while I was there. Simula opted to close the Asheville site in 2003 and moved it to Apache Junction, AZ. I still keep in touch with several of the navy test jumpers that jumped, Gabbard, Mark Esposito and Howie Tomlinson. Tomlinson still works at China Lake with the 2 vacuum sealed systems the Navy developed with the company I worked for. I never made a trip to do the test drops, that was prior to me arriving. I assembled, packed, vacuumed sealed, and closed the systems before shipping to the navy. I just wanted to add a little bit more of the history of the Durachute, not to stir up any animosity. Quote Share this post Link to post Share on other sites mjosparky 4 #23 August 31, 2012 QuoteOkay...a little of my background with SEI. I worked at SEI in Asheville,NC from 2000-2003. I worked with 3 designers and several individuals who jumped and did R&D with the P3 prior to my arrival there. At the time, SEI was not owned by anyone else. It was purchased by Simula while I was there. Simula opted to close the Asheville site in 2003 and moved it to Apache Junction, AZ. I still keep in touch with several of the navy test jumpers that jumped, Gabbard, Mark Esposito and Howie Tomlinson. Tomlinson still works at China Lake with the 2 vacuum sealed systems the Navy developed with the company I worked for. I never made a trip to do the test drops, that was prior to me arriving. I assembled, packed, vacuumed sealed, and closed the systems before shipping to the navy. I just wanted to add a little bit more of the history of the Durachute, not to stir up any animosity. You did know that Howie was married to sister at one time? SparkyMy idea of a fair fight is clubbing baby seals Quote Share this post Link to post Share on other sites leon.hill 1 #24 August 31, 2012 Quote You did know that Howie was married to sister at one time? I had heard that, but only took it witha grain of salt. There was also an guy there that married, divorced, married again and divorced again the same woman. Must of been something in the water in the mountians of western NC... Quote Share this post Link to post Share on other sites RogerRamjet 0 #25 September 6, 2012 Quote The one shot capewell was mostly on the early crossbow pig rigs . while nice in concept they never really oneshotted. You could pull the covers down then smackthem both at the same time to be gone. That rig had the first RSL in 1964 but you had the make sure you released the right side slightly before the left as ther were no cross cpnnectors between risers. Obviously they worked for me many times with the ropes and rings Paraplane clouds I jumped (and used) One-Shots after I got off student status. Mine certainly didn't work that way... Just pull the cover all the way down and you were gone. I did 2 intentional (practice) cutaways and one from an actual mal with them and they always worked perfectly (and way faster than 1.5 shots). There were some who said you should pull them down to the cocked (half open) position and then slap them to the harness, but it just was not necessary. ----------------------- Roger "Ramjet" Clark FB# 271, SCR 3245, SCS 1519 Quote Share this post Link to post Share on other sites Prev 1 2 Next Page 1 of 2 Join the conversation You can post now and register later. If you have an account, sign in now to post with your account. Note: Your post will require moderator approval before it will be visible. Reply to this topic... × Pasted as rich text. Paste as plain text instead Only 75 emoji are allowed. × Your link has been automatically embedded. Display as a link instead × Your previous content has been restored. Clear editor × You cannot paste images directly. Upload or insert images from URL. Insert image from URL × Desktop Tablet Phone Submit Reply 0 Go To Topic Listing
