likestojump 3 #1 July 4, 2012 I thought it's a PC, but upon closer inspection I am not sure. The canopy is all taffeta No data panel, but I can see factory panel ink stamps. The amount of turn slots threw me off, as did the the number of vents in the rear. My best guess is that this may be a modified Mark II.. Any clues ? Quote Share this post Link to post Share on other sites
andrewhilton 1 #2 July 4, 2012 No idea. Does this help? Quote Share this post Link to post Share on other sites
dgw 8 #4 July 4, 2012 None of the above, as far as I can see.. Quote Share this post Link to post Share on other sites
pchapman 280 #5 July 4, 2012 Just guessing: Could it be a home modification of a common design? I haven't looked in detail, but it is somewhat close to a Mark II PC, but with a bigger central aft drive hole. Does that aspect look factory built or not? Extra holes cut out at the back can also explain a missing data panel. I've seen that before. Quote Share this post Link to post Share on other sites
wmw999 2,623 #6 July 5, 2012 Could it be a parasail rather than a parachute? Wendy P.There is nothing more dangerous than breaking a basic safety rule and getting away with it. It removes fear of the consequences and builds false confidence. (tbrown) Quote Share this post Link to post Share on other sites
likestojump 3 #7 July 5, 2012 QuoteCould it be a parasail rather than a parachute? Wendy P. It's definitely a parachute (came with a slag and a container with 1.5 shot capewells :). I am quite confident it's a Mark II PC with a removed rear panel for better drive (and thus missing the ID markings) and patched vents on the bottom most of the skirt rear Quote Share this post Link to post Share on other sites
Beatnik 2 #8 July 5, 2012 I would say it is a Mark II with the data panel removed to give a little more forward drive which could be the reason you can't find it. THe panels match up so does the general look and construction from what I can tell. Quote Share this post Link to post Share on other sites
SStewart 13 #9 July 6, 2012 Looks like a French Papillion to me.Onward and Upward! Quote Share this post Link to post Share on other sites
drjump 0 #10 July 6, 2012 Nothing in Poynter's manual matches this canopy! Looks home made to me! With lots of patches. Quote Share this post Link to post Share on other sites
andrewhilton 1 #11 July 6, 2012 I seem to recall Henny Wiggers has a Mk2 PC converted to a Mk1, stamped as a Pioneer factory conversion. Calling Holland..... Quote Share this post Link to post Share on other sites
Beatnik 2 #12 July 6, 2012 Andrew already posted the information for those that doubt. The second post in this thread has an attachment called pc slots. The middle one, the Mark II, has panels that are exactly the same as the photos that Paul posted. You can't really get any closer than that. My guess also comes from the 20+ PCs that I have owned and the 8 I currently own. It might be something else but I am pretty confident that it is a Mark II. Removing the middle panel was a common mod done on PCs to give them more forward drive. This wasn't unique to Mark II's. Mark I's had them done as well. I have a slider that someone made from a PC data panel. Quote Share this post Link to post Share on other sites
denniscoursey 0 #13 July 7, 2012 QuoteQuoteI thought it's a PC, but upon closer inspection I am not sure. The canopy is all taffeta No data panel, but I can see factory panel ink stamps. The amount of turn slots threw me off, as did the the number of vents in the rear. My best guess is that this may be a modified Mark II.. Any clues ?*** Quote Share this post Link to post Share on other sites lekstrom10k 0 #14 July 7, 2012 If it was a markII it wouldnt have a drive hole Its right on 24 gores for a PC. It isnt a 23 Russian as the vents are wrong. Check the line lengths to compare it to charts for other models Its neither Paps USA or French as the nose doesnt have the vents abovethe skirt right Quote Share this post Link to post Share on other sites jgc372 0 #15 July 17, 2012 Competition Para Commander or a copy of same. Mid seventies, was brought out to compete with Papion. Quote Share this post Link to post Share on other sites likestojump 3 #16 July 17, 2012 QuoteCompetition Para Commander or a copy of same. Mid seventies, was brought out to compete with Papion. Even I can say that it's incorrect. This canopy would be a dog compared to the true CompPC, considering it's missing a turn slot from each side and some of the rear drive slots. left side image is of the factory CompPC Quote Share this post Link to post Share on other sites wmw999 2,623 #17 July 17, 2012 OMG -- Cosmic Puke! Wendy P.There is nothing more dangerous than breaking a basic safety rule and getting away with it. It removes fear of the consequences and builds false confidence. (tbrown) Quote Share this post Link to post Share on other sites Krip 2 #18 July 17, 2012 Quote OMG -- Cosmic Puke! Wendy P. Pizza anyoneR Quote Share this post Link to post Share on other sites likestojump 3 #19 July 17, 2012 Quote Quote OMG -- Cosmic Puke! Wendy P. Pizza anyoneR The PizzaPuke CompPc was very popular when i packed it at the DZ amongst thes squares ;) it also seems to land me quite well at 173lbs + gear Quote Share this post Link to post Share on other sites Mountainsky1 0 #20 August 5, 2012 it's a Mark II PC with the "dog House" removed. The reason there is no data panel. Cheers, MJ Quote Share this post Link to post Share on other sites Join the conversation You can post now and register later. If you have an account, sign in now to post with your account. Note: Your post will require moderator approval before it will be visible. Reply to this topic... × Pasted as rich text. Paste as plain text instead Only 75 emoji are allowed. × Your link has been automatically embedded. Display as a link instead × Your previous content has been restored. Clear editor × You cannot paste images directly. Upload or insert images from URL. Insert image from URL × Desktop Tablet Phone Submit Reply 0
