AviationTD 0 #1 April 6, 2013 A S&TA or one of the S&TAs approached to me and told me that I had a nice PLF but I need to make sure not to do that again. I tried to explain the fact that I was completely blind. I think it fell on deaf ears. So, I kept my mouth shut and let him have it. I thought that I would share my incident on this DZ. If it could happen to me, it could happen to anyone. Keep in mind that I am still a fairly new jumper. It was the second jump for the day and I was using the borrowed full-faced helmet (never wore full-face helmet before this day). The visor cannot be flipped up. Once enter the pattern (I entered the pattern fairly high), I noticed a water build-up at the bottom of the visor but I wasn't alarmed. After turning into base (fairly high), my visor was completely blocked with condensation like you would see on icy glass of water on hot day. Everything I see through the visor was completely distorted. I can't even read the altimeter at that time. I fanatically searched every inch of my visor, looking for a clean spot and found none. My mind was running through several actions I could do but didn't like any of them. For example, I thought about letting go my toggles in order to remove the helmet. Seems too dangerous at low altitude with little time. Because of calm and variable winds, I could easily run into a tree line ahead of the landing zone. I performed few S-turns. Since, I can't see what I was doing, people on the ground probably viewed this as potential low turns (I was on downsized rental gear). I stopped when I am confident that I wouldn't run into the tree line. The truth is I really had no idea. I rely heavily on experiences to give me a general idea of where I was. When I thought I was in perfect position to flare, I slowly pulled the toggle. I ended up realizing that I was still high. I did exactly what I have been trained to do: perform PLF. And it definitely saves my butt. Thought that I would share. Feel free to criticize or tell me what would you do. Safety is always on top of my mind, but this scenario never enters my mind before. And it caught me off guard. Quote Share this post Link to post Share on other sites
popsjumper 2 #2 April 6, 2013 Just to be clear...he told you not to PLF and nothing else?My reality and yours are quite different. I think we're all Bozos on this bus. Falcon5232, SCS8170, SCSA353, POPS9398, DS239 Quote Share this post Link to post Share on other sites
chuckakers 426 #3 April 6, 2013 QuoteA S&TA or one of the S&TAs approached to me and told me that I had a nice PLF but I need to make sure not to do that again. I will give the S&TA the benefit of the doubt here and say you may have misunderstood him/her. A PLF is seldom something to be avoided and ALWAYS a good choice if you think the landing may be less than delicate. Just out of curiosity, do you know how long that S&TA has been jumping?Chuck Akers D-10855 Houston, TX Quote Share this post Link to post Share on other sites
potatoman 0 #4 April 6, 2013 Gear can become an issue in an instant. Take note or leave it, but get confident with the gear you are going to use. Tips though on the helmet thingy: Get the antifog spray stuff, can't remember what they are called. I have aslo seen people put the helmet ontop of their heads a after opening and in clear airspace. Also, sounds like you were scared to let go of the toggles. Try leg input turns, you should be able to let go the toggles, and do something to the helmet. Glad you avoided the treeline, and also did a PLF...AND Kept your calm. Best yet, get a G3. heheheYou have the right to your opinion, and I have the right to tell you how Fu***** stupid it is. Davelepka - "This isn't an x-box, or a Chevy truck forum" Whatever you do, don't listen to ChrisD. Quote Share this post Link to post Share on other sites
theonlyski 8 #5 April 6, 2013 Just FYI, my full face does that too, if you breathe incorrectly... In thru the nose, out thru the mouth port. It takes a conscious effort on my part, but it isn't hard to do."I may be a dirty pirate hooker...but I'm not about to go stand on the corner." iluvtofly DPH -7, TDS 578, Muff 5153, SCR 14890 I'm an asshole, and I approve this message Quote Share this post Link to post Share on other sites
Andy9o8 2 #6 April 6, 2013 QuoteJust to be clear...he told you not to PLF and nothing else? Maybe was referring to the S-turns.....? Quote Share this post Link to post Share on other sites
davelepka 4 #7 April 6, 2013 QuoteI was using the borrowed full-faced helmet (never wore full-face helmet before (I was on downsized rental gear). One new thing per jump is the rule. 'New' not neccesarily meaning 'jump #1' on something, 'new' meaning however many jumps it takes you to get used to the new item. It might only take one jump in some cases, in others it might take 10 or 20. Keep everything else the same, so you can focus (no pun intended) on the 'new' thing. Quote Share this post Link to post Share on other sites
BIGUN 1,488 #8 April 6, 2013 QuoteS&TAs approached to me and told me that I had a nice PLF but I need to make sure not to do that again Please forgive me; but, I am struggling with this. I've never met an S&TA that did not only respect a well-done PLF; but encouraged them. (and, several on this thread are current or former S&TAs)Nobody has time to listen; because they're desperately chasing the need of being heard. Quote Share this post Link to post Share on other sites
AviationTD 0 #9 April 6, 2013 That's correct. That's all he said. He said the same thing after my explanation. Quote Share this post Link to post Share on other sites
AviationTD 0 #10 April 6, 2013 It is a possible that I misunderstood him, but that's all he said. If he expand his comments, then he might mean something else. He could refer to my s-turns. I think I was aggressive on them. Quote Share this post Link to post Share on other sites
AviationTD 0 #11 April 6, 2013 I have never done the leg input before. I thought that it is something that I will learn in canopy course. i haven't take the course yet (plan to wait until I have my own gear). Yes, I was scared to let toggle go because I was unable to determine how high I was. Thought that it was best to stick to what I already know. Quote Share this post Link to post Share on other sites
billvon 3,120 #12 April 6, 2013 If you have a full face helmet with a removable visor, practice with it to be sure you can open it quickly and safely. If you have a full face helmet without a removable visor, practice taking it off under canopy. Also be sure you can either stow it or hold it, or be willing to drop it if you cannot do either one. Quote Share this post Link to post Share on other sites
ghost47 18 #13 April 6, 2013 QuoteIt is a possible that I misunderstood him, but that's all he said. If he expand his comments, then he might mean something else. He could refer to my s-turns. I think I was aggressive on them. If you're not sure, ask him. Think about S-Turns. Unless you're POSITIVE that you're the only one trying to land then, think about people that might be to the left or right of you, maybe on faster canopies, who are also landing. What might someone swerving in front of them do to their approach? What if there's no time for that person to react, or they react instinctively (and badly) by stabbing a toggle down? Quote Share this post Link to post Share on other sites
grimmie 186 #14 April 6, 2013 http://www.visorclear.com/ Quote Share this post Link to post Share on other sites
potatoman 0 #15 April 8, 2013 No need for a canopy course to practice leg turns. Go for a HopnPop. Your brakes are stowed on opening, so leave them there. If your canopy is flying fine, and you don't have any traffic in your way, give the leg turns a go. The turns are normally smooth, you can only give so much input with your legs. Extend the one leg down straight, and lift the other leg up high. You will find yourself doing a slow turn. NOW, when you are under canopy and you want to let go of the toggles to tend to some sort of issue, you can steer. Keep it safe. PS. You can also do this with the brakes unstowed.You have the right to your opinion, and I have the right to tell you how Fu***** stupid it is. Davelepka - "This isn't an x-box, or a Chevy truck forum" Whatever you do, don't listen to ChrisD. Quote Share this post Link to post Share on other sites
jurgencamps 0 #16 April 8, 2013 Legturns on student (or rental) gear? The canopy will take tiiiiiiiiiiiime to react I presume. Quote Share this post Link to post Share on other sites
potatoman 0 #17 April 8, 2013 Depends on the size of the legs.... and the jumper did not mention the size, but he did mention that it was different, so I presurmed it being a bit smaller than the norm. Anyways, like I said, give it a go in a safe ennvironment. Even slooooow turns could save your life.You have the right to your opinion, and I have the right to tell you how Fu***** stupid it is. Davelepka - "This isn't an x-box, or a Chevy truck forum" Whatever you do, don't listen to ChrisD. Quote Share this post Link to post Share on other sites
mr2mk1g 10 #18 April 8, 2013 I don't like the idea of taking hands out of toggles down low - but there's an awful lot you can do with your hands in the toggles. My post opening procedure for example has me take my toggles, control check/avoid traffic/point in the right direction THEN loosen chest strap with my hands still in toggles - you just end up going into half brakes. With a little practice, you should find no issue taking your helmet off whilst still having your hands in your toggles without putting any significant input into your canopy beside slowing it down slightly. Try lifting it up so that it sits on top of your head. Not ideal frankly from a protection point of view but if you can't see out of it it's required. Consider a different helmet if you're not getting on with the full face. Leaving your hands in the toggles however mean you can always respond to surprise traffic and can't find yourself in a situation where you can't find a toggle. Plus it helps prevent twisted brake lines. I'd take the S&TA's comments to mean - don't put yourself in that position again where you s-turn on final and flare high requiring a strong PLF. PLF's should remain part of your repertoir. Quote Share this post Link to post Share on other sites
DougH 270 #19 April 9, 2013 You can yank a helmet off with your toggles in your hands. No ideal, but much better than taking your hands out of your toggles down low, and better than flying blind in the pattern. It sounds like you made the best of the circumstances and you didn't panic. That is a key takeaway for me. As you jump more you build your well of experience and your jumpers tool box. BUT... and this is a big but, you need to keep calm and avoid panic to use that extra experience and skillset. You were short on the skillset because of your jump numbers, but you responded in the best way you could."The restraining order says you're only allowed to touch me in freefall" =P Quote Share this post Link to post Share on other sites
stayhigh 2 #20 April 10, 2013 Sounds little bit on exaggeration side. If you were completely blinded you would've ripped the helmet off.Bernie Sanders for President 2016 Quote Share this post Link to post Share on other sites
Mach1dmb 0 #21 April 10, 2013 I haven't tried a full face helmet yet, but I think if I were in that situation I would have just chucked the helmet. I'd rather pay to replace it than get hurt. Quote Share this post Link to post Share on other sites
RyanFYF 0 #22 April 12, 2013 you should have had plenty of time to unbuckle it and buckle it to your chest strap if it was too foggy to see. been there before. Got a G3 and never looked back. flip up full face for ever!!!!! Quote Share this post Link to post Share on other sites
NWFlyer 2 #23 April 12, 2013 Quote you should have had plenty of time to unbuckle it and buckle it to your chest strap if it was too foggy to see. been there before. Might want to think through that advice a little bit more. Personally, I'd never attach something to my chest strap (like a helmet) that could potentially interfere with my ability to see and reach my handles. Even if I open at my normal altitude (3Kish) and decide my main is happy and landable, there are scenarios that could cause me to need to cutaway and/or fire my reserve later on (canopy collision in traffic, self-induced malfunction to name but two)."There is only one basic human right, the right to do as you damn well please. And with it comes the only basic human duty, the duty to take the consequences." -P.J. O'Rourke Quote Share this post Link to post Share on other sites
billvon 3,120 #24 April 12, 2013 >you should have had plenty of time to unbuckle it and buckle it to your chest strap if it >was too foggy to see. Not if you are already on base. If you can pull it up to the top of your head, do so. If you take it off and can fly with it in your hand, do so. If you can do neither one, drop it; when you are on base you don't have time to be messing around with your hands. You need to be flying your parachute.. A former student of mine had this happen to him and broke his femur when he could not see to flare. Do not hesitate to take the helmet off and drop it if need be. Quote Share this post Link to post Share on other sites
rockola 0 #25 April 27, 2013 Quoteyou should have had plenty of time to unbuckle it and buckle it to your chest strap if it was too foggy to see. been there before. Could you outline the steps you'd take to buckle a Factory Diver to your chest strap? ***Got a G3 and never looked back. flip up full face for ever!!!!! I have one (1) jump on a G3... fogged up so badly I could barely see. Also, since I hadn't practiced it on the ground (silly me), I couldn't get the visor to flip up. Quote Share this post Link to post Share on other sites
