Staso 0 #1 May 20, 2002 hi !what people think is the right exit order for speed divers ?i agree with the whole "slow fallers - first, fast fallers - last"concept and don't wanna start this topic again. but how speed diversfit in that picture ?on my dropzone i'm the only one who does that kind stuff and iusually go first. since next group is usually big RW group andit takes some time to climb and set, at the time they open i'm setting for the final. sometimes on windy days (we fly otter), i'malready on the ground when i see them opening.i like going out first and be sure that i'm not gonna hit anybodyat close to 300 mph speed. also if i lose my balance and zoom around,i always have time to slow down and during that time i track and getaway from anybody. my track is pretty fast when i pull out from thedive. since i have plenty of vertical speed, it gives me a lot ofhorizontal and if i find myself when i shouldn't be, i can easily fixit. in fact i have so much horizontal speed that it sometimes slows me down to 45 mph.the only one thing is that since next group is big and they need some time to climb out, they trend to put me short :)if i exit after all rw and ff and just before high openers, students andtandems, i still should have plenty of horizontal separation since i'mnot affected by wind much, but if i'm not going straight down i thinki can catch up with previous group and that wouldn't be pretty. i knowthat i should be aware of my heading but even small mistakes at highspeed would be magnified, so i'd rather eliminate that risk.just wanna hear what people think and what is the usual practice for this case.thanks,stan. Quote Share this post Link to post Share on other sites
billvon 3,151 #2 May 20, 2002 >but if i'm not going straight down i think>i can catch up with previous group and that wouldn't be pretty. I understand the concern, but it is a concern shared by all freeflyers. Novice freeflyers practicing head down can easily pass the RW group in front of them; yet we still ask them to exit afterwards because of the greater horizontal separation that affords. If a new freeflyer looks like he will be zoomy I remind them to not face one direction for the whole dive; turning occasionally tends to "cancel out" backslides and such.Basically I think any procedure that works for regular freeflyers should work for you as well, and will actually afford you _more_ separation as the wind increases. If, due to your unusual amount of sliding, you can't control where you end up at opening time, a very long delay or a separate pass might be a good idea.-bill von Quote Share this post Link to post Share on other sites
Staso 0 #3 May 20, 2002 that makes sence and i think i made a stress on it as well in my original post. i don't really have too much of the direction control after i pass certain speed. and any control input would kill the speed and as the result the very idea of this discipline.funny, some time ago, very often i had cork-screw spin on my dives. as it turned out it was my wrist altimiter :)stan. Quote Share this post Link to post Share on other sites
quade 4 #4 May 20, 2002 Topics are like brooms to a sorcerer's apprentice.They can not actually be beaten to death.quadehttp://futurecam.com Quote Share this post Link to post Share on other sites
billvon 3,151 #5 May 21, 2002 >Topics are like brooms to a sorcerer's apprentice.Not quite the most obscure reference I've seen here to date, but pretty close . . .-bill von Quote Share this post Link to post Share on other sites
Michele 1 #6 May 21, 2002 Hi, guys.So, I have a question. If a slow faller gets out right in front of me, a light, floaty kinda guy, who takes, oh, say 57 seconds in freefall, and is opening at the same atlitude I am, and I give him easily 8 seconds (a slow 8 count) before I leave the plane, and I am a not so slow floaty kinda faller and have a regular freefall rate that allows me about 47 seconds in freefall, he and I will be opening at about the same time...(this actually happened yesterday - I was last out of the plane, and ended up pulling before the other guy did. And no, I didn't go low on my pull alti...there was really good horizontal separation, but it still spooked me a bit to see a canopy above me when I was last out).So why is it that slow fallers are out before the fast fallers?Thanks, guys.And that was not an obscure reference...at least to me.Ciels and Pinks-MicheleIf you really want to, you can seize the day; if you really want to, you can fly away...~enya~ Quote Share this post Link to post Share on other sites
quade 4 #7 May 21, 2002 Michele --Assume the uppers are 30 out of the north or 44 feet per second. Further, assume jump run is from south to north. Assume neither the fast faller or the slow faller tracks. Assume the second jumper gives a 10 second delay between exits.If the belly flyer is out first and exposed to the wind for 10 more seconds than the fast faller, then at opening altitude, they should be about 440 feet farther away from each other than if they had been falling at the same rate.If the fast faller is out first, then they'd be about 440 feet closer to each other than if they fell at the same rate.Make sense?Now, the real world isn't quite this perfect and there are a lot of little variables involved, but i think this should give you a basic idea of how it works.quadehttp://futurecam.com Quote Share this post Link to post Share on other sites
AndyMan 7 #8 May 21, 2002 QuoteSo why is it that slow fallers are out before the fast fallers?The short answer is the vertical separation is meaningless. One cuttaway, a snivel, a high or a low pull can redule vertical separation to zero.So again - vertical separation is meaningless.Horizontal separation is a lot harder to screw up._AmICQ: 5578907MSN Messenger: andrewdmetcalfe at hotmail dot com AIM: andrewdmetcalfeYahoo IM: ametcalf_1999 Quote Share this post Link to post Share on other sites
Staso 0 #9 May 21, 2002 > and have a regular freefall rate that allows me about 47 seconds in freefallwow ! 47 seconds is not regular freefall time. not at least from 13500.i do speed dives and my freefall time is around 42-44 seconds. regular rw from 13500 should be at least 60 seconds. unless you pull high.please dont's start "why is it that slow fallers are out before the fast fallers?" it's discussed here in "exit order" topic -http://www.dropzone.com/cgi-bin/forums/showflat.pl?Cat=&Board=forumsafetytraining&Number=154335&page=0&view=collapsed&sb=5&o=0&part=i was curious how speed divers fit into the exit order.stan. Quote Share this post Link to post Share on other sites
Michele 1 #10 May 21, 2002 Quoteif i exit after all rw and ff and just before high openers, students andtandems, i still should have plenty of horizontal separation since i'mnot affected by wind much, but if i'm not going straight down i thinki can catch up with previous group and that wouldn't be pretty.Since your comment (above) is what triggered my question and that is exactly where I leave in the exit order, I asked a question about slow v. fast falling. I saw two people who I hold great respect for, and thought hey, maybe they understand and can explain to me what the thought process is.Begging your pardon, Staso. Sorry if I am repeating a topic which possibly had been, um, beaten to death. However, I had read that thread, and didn't understand it, and still am not sure about the answer. Ya know, I am getting the feeling my questions are not acceptable. Possibly because I am new or something. Next time, I shall make sure not to sully your thread with a question. Actually, next time, I shall think twice or perhaps three times before asking anything from anyone.As for my "regular" freefall time, I average about 135-140 on my belly, and I pull at 4.5 after leaving at 12,5.Have great jumps, Staso. If you really want to, you can seize the day; if you really want to, you can fly away...~enya~ Quote Share this post Link to post Share on other sites
AndyMan 7 #11 May 21, 2002 QuoteYa know, I am getting the feeling my questions are not acceptableYour questions are perfectly acceptable. That's why this group is here. If you're not understanding, we must not be explaining properly.Why don't you take a look at Kallend's webpage here: http://www.iit.edu/~kallend/skydive/#resourcesWander through the powerpoint presentation.... read the charts. If you're real adventurous, download and play with his freefall simulations. Maybe that will help..._AmICQ: 5578907MSN Messenger: andrewdmetcalfe at hotmail dot com AIM: andrewdmetcalfeYahoo IM: ametcalf_1999 Quote Share this post Link to post Share on other sites
Staso 0 #12 May 21, 2002 Michelle,I'm in no way tried to insult you or do something of that kind. IfI did, I apologize, I didn't mean to.The exit order topis was literally "beaten to death" and I really didn't want to start it again, especailly since it's discussed in the forum right next to this thread, I just tried to bring one small aspect of it, taking that "slow fallers first" concept isgiven.Sorry again,Stan. Quote Share this post Link to post Share on other sites
billvon 3,151 #13 May 21, 2002 >So why is it that slow fallers are out before the fast fallers?Because it helps with their horizontal separation. Vertical separation does not work, as has been mentioned above, and in many cases doesn't matter much. Heck, the Otter passes students on their way down, but since there is plenty of horizontal separation, it's not a big issue.If you get out after that slow faller, and jump run is normal (into the wind) you will find yourself opening at the same altitude and time, perhaps, but well away from him horizontally. If you reverse the order you will open well before him, but your horizontal separation will be lower - and you are at greater risk for collision.-bill von Quote Share this post Link to post Share on other sites
kallend 2,194 #14 May 21, 2002 <<>>Andy - you make an excellent agent. Unfortunately I don't pay any commission. Quote Share this post Link to post Share on other sites
billvon 3,151 #15 May 21, 2002 >Ya know, I am getting the feeling my questions are not acceptable. Possibly> because I am new or something. Next time, I shall make sure not to sully your> thread with a question. Actually, next time, I shall think twice or perhaps three> times before asking anything from anyone.Michele, your questions are completely acceptable _especially_ if you're somewhat new. However, often you're going to get redirected to a thread in progress. For example, if you ask "Should I land a canopy with a broken brake line?" we could recreate the 50 posts in the "broken steering line" thread, but more likely someone will just post a link to that thread. That doesn't mean the question's not acceptable, just that it is being answered somewhere else.-bill von Quote Share this post Link to post Share on other sites
