base698 20 #1 May 27, 2002 How does this happen? Does it happen often? I've never heard of it happening on our DZ to anyone but I do know i've heard it to look out for.Thanks Quote Share this post Link to post Share on other sites
SkydiveMonkey 0 #2 May 27, 2002 It can happen if you forget to cock your pilot chute, thus not creating enough drag to pull the pin. That's what causes it most of the time. Let's go play chicken with a planet !! Quote Share this post Link to post Share on other sites
slotperfect 7 #3 May 27, 2002 A REALLY tight closing loop and a curved pin inserted all the way into the closing loop also creates a possibility for a pilot chute in tow. The correct size/material combination of your pilot chute also makes a big difference. See Bill Booth's post: http://www.dropzone.com/cgi-bin/forums/showthreaded.pl?Cat=&Board=forumgear&Number=141055&page=&view=&sb=&o=&vc=1#Post141055Respectfully,SP Quote Share this post Link to post Share on other sites
Remster 30 #4 May 28, 2002 I dont buy the realy tight closing loop theory, as long as the rest of the system is properly made. A good PC will create a pull of +/- 60 Lbs. If the main compartment was closed manualy, I dont see it staying closed. Now, if there isnt enough slack "behind" the pin for it to move, or there is a packing error, or the PC is not properly made/maintained/cocked, then yes.Also, the type of pin helps. There are still some welded pins out there (these have round pin cross section, as opposed to the flatter ones) and those have been known to fail at the weld point. if you see one of those, you may want to suggest to the jumper that its time to change it.RemsterMuff 914 Quote Share this post Link to post Share on other sites
billvon 3,120 #5 May 28, 2002 >I dont buy the realy tight closing loop theory, as long as the rest of the system >is properly made. There are a lot of factors here. As you mention, a bad PC may cause a problem. Dirt or corrosion on the pin, a poor body position causing half a bridle wrap, a low speed deployment (hop and pop) or bad grommets can also cause troubles. I think that most PC-in-tows are a combination of several of these problems.-bill von Quote Share this post Link to post Share on other sites
CuriousGeorge 0 #6 May 29, 2002 A friend of mine pitched his pilot chute and the bridle detached from the pin. Doh! Quote Share this post Link to post Share on other sites
hobbes4star 0 #7 May 29, 2002 ok so quick ? what pin is better to use, the strait pin or the curved pin??why jump when you can fly Quote Share this post Link to post Share on other sites
billvon 3,120 #8 May 29, 2002 >k so quick ? what pin is better to use, the strait pin or the curved pin??Not really much question there - curved if the pull is perpindicular to the plane of the rig (i.e. a throwout) straight if it is in one direction only parallel to the rig (i.e. pullout or ripcord.)-bill von Quote Share this post Link to post Share on other sites
