***QuotePointer's manuals have it as Early models (1964-66). The Mark II was introduced in 1969.
The Mark I's proformance numbers:
Glide Angle: 53 degrees
Opening time (283 lbs total): Zero Velocity : 5.1 seconds
150 knots: 1.8 seconds
Distance: Twisted lines: 186 feet
Zero velocity: 321'
110 kts: 115'
150 kts: 41'
Forward speed (with 200 lbs): 14 mph
Decent Rate (with 200 lbs): 16 feet per second
The Comp model has lines shortened by 42 inches and more steering vents.
mikkey 0
QuoteThe Comp model has lines shortened by 42 inches and more steering vents.
I did a few jumps on the Comp model in the late 70's (fun canopy to jump
When people look like ants - pull. When ants look like people - pray.
PhreeZone 20
![[:/] [:/]](/uploads/emoticons/dry.png)
And tomorrow is a mystery
Parachutemanuals.com
mikkey 0
QuoteThey land hard
You are soooo spoiled....
D-12855
PhreeZone 20
I was told that's an "advanced" landing technique and should'nt be tried on a first round jump. I was at the max for the comp PC it turns out and I was coming straight down. One one bothered to tell me about how poorly you can do a PLF if you have no momentium except straight down
lazyfrog 0
Fumer tue, péter pue
ourson #10, Mosquito Uno, CBT 579
QuoteBack in the late 70's you were required to have 100 jumps under a round canopy before you were allowed to jump a square. I had 50 jumps under a 10 with front mounted reserve and 50 under a Paracommander. my paracommander landed extremely soft if you pulled back on the back risers just before landing
Tony-
You must have been on one of those progressive
California dropzones!
We had to have 200!!!
(I cheated and just bought a used Para Plane
after around 150...)
I had a Church Window PC that was shortlined incorrectly...
The Apex lines ( 2 thick ropes that pulled down the center)
were the same length as the suspension lines...
It opened like a 24' flat resrve...(snot knocker)
and came out of the sky like a modern day drogue!
...It WAS accurate though.
I also had (still have) a Papillion...
The vents in the front, which the para commanded lacked...
were said to allow you to 'back-up' if you were overshooting.
I jumped that PAP at Elsinore some years back...
after coming in downwind...
and spraying the pea gravel all the way to the packing area...
I was asked not to EVER jump it there again!!!
They let me jump my Cloud after only 39 jumps on a PC.
never pull low......unless you are
wmw999 2,627
Of course, he didn't
Wendy W.
QuoteI remember someone jumping his new Strato Star with 50 jumps in 1975. But he was gonna die!
Wendy W.
Funny how things have changed.
steve1 5
QuoteQuotemy paracommander landed extremely soft if you pulled back on the back risers just before landing
I always landed mine this way. Just reach up as high as you could on the back risers and do a chinup at flare time. It usually worked well. A lot of guys would flare with toggles though and seemed to land about the same. I guess it's what you get used to.......Steve1
Wendy W.
A little off the subject...
I was reading through the stolen gear last night...
From Omoro Wis.
Someone stole a rig with a 'safety star' reserve...
How long since they made one of those???
QuoteQuoteI remember someone jumping his new Strato Star with 50 jumps in 1975. But he was gonna die!
Wendy W.
From Omoro Wis.
I woun't know, I am not old enough to remember "Satety Stars". lol
My got my paracommander from Charlie Brown ( he later joined the Golden Knights) in 1978. It was in a bag which it wasn't designed for, in piggyback which it wasn't designed for and the rig was a Green Star Express. The absolute stupidest thing I ever did was take up to 7500 in Dublin , Virginia a make a test jump in it, not knowing til later if it hadn't worked that chances were that my reserve wouldn't have worked either. It's truly amazing I that I survived to be a young 60 years old.
How's Brooks doing? Tell I said hi.
Blue skies!
D-12855
PhreeZone 20
I woun't know, I am not old enough to remember "Satety Stars". lol I do know they were only about 180 sq. ft. Ouch
I jumped a 'safety flier' ONCE as a main
OUCH!
QuoteQuote
OUCH!
At your size that had to be a big OUCH.
Dean Westguard used to jump one and the ground shook when he landed.
D-12855
Zero velocity: 321'
110 kts: 115'
150 kts: 41'
