shibu 1 #1 April 29, 2013 I jumped a Mirage2 yesterday. The container was a bit of a tight fit & the leg straps too tight on the first jump of the day. Loosening it felt better for the next couple of jumps but then the end of the leg straps barely reached to pocket in the upper leg strap. The elastic bands seem to keep them in place but they were frayed. I was rushing to get on one more load when I realized that the elastic band on the right strap was missing. I made the straps a little tighter & tucked them into the pocket. I made sure they stayed there when I was exiting the plane. Presumably the right leg strap loosened during my dive bc when my canopy opened it was pulling to the left. My leg strap felt tighter in the left side so I tried leaning to the right which lessened the pull but not much. I couldn't look down bc the chest strap was right under my chin. I did a controllability check & it seemed landable (although my right toggle had to stay almost to my head with my left hand fully extended to keep it flying straight). Landing was ok. On the ground I found that my right leg strap was loosened all the way to the end. I don't think it would have pulled through but still.. not good. So other than rushing to get on the load instead of getting a replacement band for the right strap, what else did I do wrong? I spoke to one of the instructors briefly. Just looking for any more comments. Quote Share this post Link to post Share on other sites
NWFlyer 2 #2 April 29, 2013 Maybe I'm misunderstanding what you're saying, but it seems like you were looking at the wrong piece of hardware. If your problem is that one leg strap is looser than the other, the problem wouldn't be in the elastic band (which is there to keep excess leg strap from flapping around) - it would be in the friction adapter that actually holds the leg straps in place. Advice? Have a rigger look at the friction adapters before you make another jump on that rig. (And if it's rental gear, call the DZ and ask them to pull that rig for inspection)."There is only one basic human right, the right to do as you damn well please. And with it comes the only basic human duty, the duty to take the consequences." -P.J. O'Rourke Quote Share this post Link to post Share on other sites
shibu 1 #3 April 29, 2013 QuoteMaybe I'm misunderstanding what you're saying, but it seems like you were looking at the wrong piece of hardware. If your problem is that one leg strap is looser than the other, the problem wouldn't be in the elastic band (which is there to keep excess leg strap from flapping around) - it would be in the friction adapter that actually holds the leg straps in place. Advice? Have a rigger look at the friction adapters before you make another jump on that rig. (And if it's rental gear, call the DZ and ask them to pull that rig for inspection). It was a rental. I will contact the DZ. The thing is the friction adapter seemed fine. I pulled on it a few times & it didn't appear to be slipping when loaded. So my guess was that it loosened during my dive due it flapping around. NO FF. Just basic belly with some barrel rolls. I know I have had them flap around at least once in the past with no issues so maybe it is the friction adapter. Thanks alot. Glad I posted this. Quote Share this post Link to post Share on other sites
Bertt 0 #4 April 29, 2013 Quotecontainer was a bit of a tight fit & the leg straps too tight on the first jump of the day. A container that doesn't fit right is trouble waiting to happen. See if the DZ has a container that fits you better. When you buy gear, don't get a container that "almost" fits just because the price is good.You don't have to outrun the bear. Quote Share this post Link to post Share on other sites
shibu 1 #5 April 29, 2013 QuoteQuotecontainer was a bit of a tight fit & the leg straps too tight on the first jump of the day. A container that doesn't fit right is trouble waiting to happen. See if the DZ has a container that fits you better. When you buy gear, don't get a container that "almost" fits just because the price is good. Good point. The other container with the canopy I like is even worse. I just need to get my own rig already. I expected to have one already but I put on ~10-20lbs since last season & I wanted to loose a few before being measured but if I can't find a used one with a decent fit in the next week I think I'll just buy a new one. Quote Share this post Link to post Share on other sites
Andy9o8 2 #6 April 29, 2013 Sounds to me like your DZ has some shit rental gear. Is it all that way? Quote Share this post Link to post Share on other sites
uberchris 0 #7 April 29, 2013 QuoteQuotecontainer was a bit of a tight fit & the leg straps too tight on the first jump of the day. A container that doesn't fit right is trouble waiting to happen. See if the DZ has a container that fits you better. When you buy gear, don't get a container that "almost" fits just because the price is good. fuck man, i had bought an old talon container, and the guy said it would fit 6'2" which was a load of shit........regardless i jumped it for about 60 or so jumps, and the leg straps would BARELY tighten at all, let alone tuck into the pockets. sometimes on opening, i would start spiraling to the right or left because of this issue, and of course the one time my wingsuit arm zippers decided to get stuck, i opened up into a spiral that worsened by each rotation. i ALMOST cutaway and then was able to unzip my wingsuit and unstow, and it fixed the problem. i sold the rig a few days later and got something that fit. it wasnt worth the potential shitstorm i was putting myself ingravity brings me down......... Quote Share this post Link to post Share on other sites
shibu 1 #8 April 29, 2013 QuoteSounds to me like your DZ has some shit rental gear. Is it all that way? I've jumped his rig dozens of times last season with no issues. I also checked to see if the leg strap would slip by pulling up on it when I had it on. It didn't slip at all. Still if it was a bad friction adapter, that really sucks. In any case, I'm lad that the stitching on the harness held. Quote Share this post Link to post Share on other sites
shibu 1 #9 April 29, 2013 QuoteQuoteQuotecontainer was a bit of a tight fit & the leg straps too tight on the first jump of the day. A container that doesn't fit right is trouble waiting to happen. See if the DZ has a container that fits you better. When you buy gear, don't get a container that "almost" fits just because the price is good. fuck man, i had bought an old talon container, and the guy said it would fit 6'2" which was a load of shit........regardless i jumped it for about 60 or so jumps, and the leg straps would BARELY tighten at all, let alone tuck into the pockets. sometimes on opening, i would start spiraling to the right or left because of this issue, and of course the one time my wingsuit arm zippers decided to get stuck, i opened up into a spiral that worsened by each rotation. i ALMOST cutaway and then was able to unzip my wingsuit and unstow, and it fixed the problem. i sold the rig a few days later and got something that fit. it wasnt worth the potential shitstorm i was putting myself in shitstorm sums it up well... I'm ordering a rig this week. Quote Share this post Link to post Share on other sites
billvon 3,112 #10 April 29, 2013 FYI while slipping friction adapters is annoying and can create problems (i.e. off heading/bad openings, chinstrap hitting you) it is rarely dangerous. You won't fall out unless the rig fits poorly to begin with, and even if it gets to the end of the webbing it won't become detached. That being said it's a good thing to get fixed before your next jump. Friction adapter springs can help, as can better stowing of the webbing excess. (Often flapping straps manage to work themselves looser.) Replacement of friction adapters and/or legstrap webbing is the "right" fix. Quote Share this post Link to post Share on other sites
popsjumper 2 #11 April 30, 2013 hopefully you learned something about loose leg straps and chest straps under your chin...not good.My reality and yours are quite different. I think we're all Bozos on this bus. Falcon5232, SCS8170, SCSA353, POPS9398, DS239 Quote Share this post Link to post Share on other sites
shibu 1 #12 April 30, 2013 QuoteFYI while slipping friction adapters is annoying and can create problems (i.e. off heading/bad openings, chinstrap hitting you) it is rarely dangerous. You won't fall out unless the rig fits poorly to begin with, and even if it gets to the end of the webbing it won't become detached. That being said it's a good thing to get fixed before your next jump. Friction adapter springs can help, as can better stowing of the webbing excess. (Often flapping straps manage to work themselves looser.) Replacement of friction adapters and/or legstrap webbing is the "right" fix. I have a feeling the strap was flapping & did work itself looser. I will make them aware of it. Thanks. Quote Share this post Link to post Share on other sites
shibu 1 #13 April 30, 2013 Quotehopefully you learned something about loose leg straps and chest straps under your chin...not good. Not good. It makes it harder to check for traffic when the chinstrap feels like a noose. And although flaring with my right hand lower than the left may sound simple, I fluffed it toward the end on my first two practice flares up high. The flare would start out fine & then pull pretty hard to the left because I was not maintaining the distance between the left & right toggles at the end of the flare. It's a good thing that canopy has plenty of flare. Quote Share this post Link to post Share on other sites
popsjumper 2 #14 April 30, 2013 Two possible things: 1. The real danger of loose leg straps or a rig that doesn't fit you properly or a rig with loose/worn adjustable MLW such as many student rigs have is that, on opening, that chest strap could come up very quickly, snag your chin and pop you head back....maybe breaking your neck. That's why I said, "not good". 2. Steering/flaring a canopy with an asymmetrical weight distribution is not all that hard in most cases. As an option to having to flare asymmetrically, here's something else you can do: Let's say the weight is on the left (right-side leg strap loose or whatever) causing a harness turn to the left. Release the brakes. You'll want to stop/slow the turn by pulling the right-side brake line. Reach up with your left hand, grab the right toggle and pull until the turn stops/slows adequately and hold it there as the canopy flies straight. Now, with your right hand, grab the right-side brake line up just below the guide ring. This becomes your "new right-side toggle full-up position". Now you can take the left side toggle in your left hand and you have a balanced brake position left-to-right. Note that some people may not have the grip strength necessary to hold on to the brake line itself and may have to "take a wrap" on the line...be aware that taking a wrap could present other problems if a breakaway becomes necessary. You won't have to maintain an asymmetrical hand position for landing. Be aware that your flare is going to be different than what you are used to so do several practice flares up high to get a good feel for what's going to happen on landing. One danger is potentially stalling one side of the canopy on landing (right-side in this case) If anyone wants to call BS, I'm listening.... Handling asymmetrical canopies is not something that is taught in canopy courses. But then, there's an awful lot more that's not taught in those courses, too.My reality and yours are quite different. I think we're all Bozos on this bus. Falcon5232, SCS8170, SCSA353, POPS9398, DS239 Quote Share this post Link to post Share on other sites
jimmytavino 16 #15 April 30, 2013 well I call BS... BUt not on YOU pops....more on the OP for overexaggerating the issue, to the point of saying "being detached"as billvon points out, the confluence wrap and stitching is WELL designed to PREVENT,,,,,any such disconnect... It sounds like the legstrap may have slipped ON opening...which is a gear maintenance issue for sure...but Not some Catastrophic Emergency. IF the chest strap IS in your face, or 'choking you '... AND the canopy is open, square and controllable...Why Not simply Loosen the chest strap?????Rental gear at ANy DZ should receive the Same , maybe MORE inspection, care and REPAIR/replacement as the DZOs personal rig, or the rigs of ANy of the staff..... Rental gear is often treated much more roughly and gets beat up much more quickly, when used by lowtimers, or those who just may "jump it and dump it"...Maybe SOME DZ's log and/or keep track of TOTAL jump numbers on such gear.. but rental rigs CAN accumulate hundreds or thousands of jumps,,,pretty quickly, bringing with That,,,issues like harness slippage, 3 ring cable maintenance , riser ring "set" and P.C./ bridle and closing loop wear & tear... good deal shibu to get GOOD quality gear of Your OWN....that FITS!!! good luck jmy Quote Share this post Link to post Share on other sites
shibu 1 #16 April 30, 2013 QuoteTwo possible things: 1. The real danger of loose leg straps or a rig that doesn't fit you properly or a rig with loose/worn adjustable MLW such as many student rigs have is that, on opening, that chest strap could come up very quickly, snag your chin and pop you head back....maybe breaking your neck. That's why I said, "not good". 2. Steering/flaring a canopy with an asymmetrical weight distribution is not all that hard in most cases. As an option to having to flare asymmetrically, here's something else you can do: Let's say the weight is on the left (right-side leg strap loose or whatever) causing a harness turn to the left. Release the brakes. You'll want to stop/slow the turn by pulling the right-side brake line. Reach up with your left hand, grab the right toggle and pull until the turn stops/slows adequately and hold it there as the canopy flies straight. Now, with your right hand, grab the right-side brake line up just below the guide ring. This becomes your "new right-side toggle full-up position". Now you can take the left side toggle in your left hand and you have a balanced brake position left-to-right. Note that some people may not have the grip strength necessary to hold on to the brake line itself and may have to "take a wrap" on the line...be aware that taking a wrap could present other problems if a breakaway becomes necessary. You won't have to maintain an asymmetrical hand position for landing. Be aware that your flare is going to be different than what you are used to so do several practice flares up high to get a good feel for what's going to happen on landing. One danger is potentially stalling one side of the canopy on landing (right-side in this case) If anyone wants to call BS, I'm listening.... Handling asymmetrical canopies is not something that is taught in canopy courses. But then, there's an awful lot more that's not taught in those courses, too. Always glad to learn another way to do things. I appreciate it. Quote Share this post Link to post Share on other sites
shibu 1 #17 April 30, 2013 Quote well I call BS... BUt not on YOU pops....more on the OP for overexaggerating the issue, to the point of saying "being detached" sorry to disappoint... Quote as billvon points out, the confluence wrap and stitching is WELL designed to PREVENT,,,,,any such disconnect... It sounds like the legstrap may have slipped ON opening...which is a gear maintenance issue for sure...but Not some Catastrophic Emergency. IF the chest strap IS in your face, or 'choking you '... AND the canopy is open, square and controllable...Why Not simply Loosen the chest strap?????Rental gear at ANy DZ should receive the Same , maybe MORE inspection, care and REPAIR/replacement as the DZOs personal rig, or the rigs of ANy of the staff..... Rental gear is often treated much more roughly and gets beat up much more quickly, when used by lowtimers, or those who just may "jump it and dump it"...Maybe SOME DZ's log and/or keep track of TOTAL jump numbers on such gear.. but rental rigs CAN accumulate hundreds or thousands of jumps,,,pretty quickly, bringing with That,,,issues like harness slippage, 3 ring cable maintenance , riser ring "set" and P.C./ bridle and closing loop wear & tear... good deal shibu to get GOOD quality gear of Your OWN....that FITS!!! good luck jmy Thanks jmy. That's the plan. Quote Share this post Link to post Share on other sites
shibu 1 #18 May 4, 2013 UPDATE: I had an instructor look over the rig. The friction adapter was fine. Added some bands & made sure the leg straps were stowed neat & jumped it 3 times today with no issues. I guess it just worked itself loose as it was flapping around on my dive. Quote Share this post Link to post Share on other sites
dorbie 0 #19 May 13, 2013 That's the spirit, fuck it! Jump that rig! Not all friction adapters are designed equal and elastic keepers should not be the difference between working and failing friction adapters. Quote Share this post Link to post Share on other sites
erdnarob 1 #20 May 13, 2013 First at all I hope that you have the ends of both legs straps folded on themselves and stitched. Second, new hardware in stainless steel are quite splippery. You can rub beeswax on the leg straps to make them less slippery.Learn from others mistakes, you will never live long enough to make them all. Quote Share this post Link to post Share on other sites
shibu 1 #21 May 18, 2013 dorbieThat's the spirit, fuck it! Jump that rig! Not all friction adapters are designed equal and elastic keepers should not be the difference between working and failing friction adapters. Good point. I know how it sounds after reading the "incident" I posted but I did have an instructor check it out throughly and after checking it out on the ground, I can't figure out how it came so loose. At any rate it pushed me to get my own rig which was long overdue. Quote Share this post Link to post Share on other sites
shibu 1 #22 May 18, 2013 erdnarobFirst at all I hope that you have the ends of both legs straps folded on themselves and stitched. They definitely are. That was what kept it from coming completely loose, I think. QuoteSecond, new hardware in stainless steel are quite splippery. You can rub beeswax on the leg straps to make them less slippery. Good to know. Thank you. Quote Share this post Link to post Share on other sites
