Sonic
Body position when chopping
Well, my first cutaway was an early jump on my first piggy-back; I was trained on conventional gear. So I cut away, carefully brought my legs together and forward so I'd be belly up, and then dumped my reserve. It opened just fine :)
In a masterful ignoring of the conventional wisdom, I also managed to land with both ripcords and the camera I'd brought up, too. I had 130 jumps.
This is not ideal. :| Practicing is better...
Wendy W.
>Does this apply to all rigs?
I don't know. It should, since a perfect belly-to-earth position is a good position for a PC hesitation, whereas a somewhat feet-to-earth position will give you better PC inflation and better absorption of opening shock. But only the Racer manual says so explicitly AFAIK.
