kallend 2,150
Quotea little dramatic don't you think? I know several people with low jump numbers who fly Sabre 2's just fine.It's a nice, docile canopy at lower wing loadings. A Spectre is a tapered canopy also.Would you not recommend one to someone with less than a hundred jumps?Quote***: Norman:
i previewed your profile, and with your jump numbers already being on a Sabre2 even at a 1.1:1 is going to an extreme
Well in the new dutch rules you really need 100 jumps before you can jump a sabre2/safire2...
BTW you need 25 for a spectre, and can start out on an original sabre.
Another rule that defeats its own purpose? It equates shape with behavior in a way that fails to account for improvement in design.
AT SDC first jump students go out on a Sabre2.
billvon 3,120
I thought the first jump at SDC was _always_ a tandem (formerly had an option for SL.) Has this changed?
billvon 3,120
>fine.
Of course. It is not a good canopy to be flying, though, if landings are still sort of just catching you by suprise.
A Spectre is considerably more docile than a Sabre 2 even at the same wing loading.
kallend 2,150
Quote>AT SDC first jump students go out on a Sabre2.
Depends if you define a tandem front rider as a passenger or a student. I think FAA defines them as passengers.
billvon 3,120
So I take it from your response that, during the normal student program, 2-3 tandems during which the person in front receives instruction are required. I would agree that, after 3 jumps during which someone learns basic canopy control, they could safely be put on a larger Sabre 2.
towerrat 0
***Post: >I know several people with low jump numbers who fly Sabre 2's just
>fine.
QuoteI understand all of this. I was more or less making reference to the use of the word "extreme".I just thought this in itself was a little extreme
Play stupid games, win stupid prizes!
kallend 2,150
Quote>Depends if you define a tandem front rider as a passenger or a
I believe two tandems are still a pre-requisite. I'm not an instructor or TM and don't pay all that much attention to the details of the instructional program (which is constantly evolving). When I did it the tandem *student* was expected to do two ripcord touches, deploy the main at 5,500ft, steer the canopy with the toggles, and flare.
skybytch 273
QuoteI want to know if anyone has suggestions and advice on how i can improve my landings and become a better skydiver.
Okay. Learn to really fly your canopy and your landings will improve.
Seek canopy control training. Travel if you have to, but get to a dz that offers a canopy control course and complete it.
You can also buy a canopy control video - I recommend the one from Skydive U. Do the drills. Depending on how you learn this might be okay, but I'd still recommend a formal coached course.
At a minimum have someone video your landings, then have someone who knows something about it critique them. Many times just seeing what you are or aren't doing will help.
Michele 1
How about taking a canopy control class?
Ciels-
Michele
~Do Angels keep the dreams we seek
While our hearts lie bleeding?~
rhino 0
Pull at altitude.. 13,500 feet over and over again.
Flare over and over again. Flat turn.. Fly in brakes.. Get use to slow speed flight. The more time you spend under canopy even if it is just basic flying, turning and flaring the better you will become using it.
You will also build confidence.
I have less than 400 jumps but more canopy time than most people with 1200 jumps.
I have at least 200 hop-n-pops from 13,000 feet or higher = 2,600,000 feet flown under canopy in those 200 jumps alone. Another 175 jumps deploying at an average of 3,000 feet = 525,000 feet flown + 2,600,000 feet is 3,125,000 + feet flown under canopy. With actual pull altitudes I am around 4,000,000 feet flown right now. I never pull below 3,000 feet. Average when not doing a hop-n-pop is about 5,000 feet.
Average jumper of 1200 jumps average deployment of 2500 feet = 3,000,000 feet flown.
Average jumper at 375 jumps = 1,125,000 feet flown under canopy with average deployment of 3,000 feet.
Do the math. Time under canopy, while actually trying to improve some aspect of your canopy flying "should" result in you doing much better. You will build muscle memory and have no choice but to improve. But allways be trying to improve something a better canopy pilot gave you to work on.
I am at 375 jumps after this weekend. 175 of which have been on my crossfire2, 97. Loaded over 1.9. I'm not bragging just showing you that your skill will be where you put your energy. I love to fly canopies more than ANYTHING else. So I fly. I learned from hooksnswoop, and Charlie Mullins everything I could get out of them. Hell I bugged Hook all this weekend to coach me. ANYTHING I can get out of him to make me a better canopy pilot is worth it.
If flying your canopy is where your trouble is than spend lots of time doing it.
Hope this helps.
Oh yeagh, what skybitch said..
Rhino
sducoach 0
QuoteOk guys, i dont want to piss anyone off or anything, but i really dont care about tandems and who can fly what canopy in Europe. I want to know if anyone has suggestions and advice on how i can improve my landings and become a better skydiver
Great Reply SSkydiver!
First, have some one video your landings, not just one but several. If the problem you are having occurred under both canopies, the common factor is you.
Without seeing your landings all of the "experts" can only assume, (and you know what that means), they know what is going on. Find a good canopy pilot at your DZ and have him review your landings. More than likely that will help solve your problem more than these posts. If not, there are several here who would be more than happy to help.
Blues,
J.E.
P.S. Does "Fly like a Pro" help any? I just got that along with "Pack like a Pro, Body Pilot in Command, Trouble Free Zero P and Breakaway>
It all seemed to start about the last 5 jumps on the old main i had and seemed to follow me to this new main now. I'll apply all the things i have learned on this thread and improve my landings. Thanks CoachQuoteQuoteOk guys, i dont want to piss anyone off or anything, but i really dont care about tandems and who can fly what canopy in Europe. I want to know if anyone has suggestions and advice on how i can improve my landings and become a better skydiver
Blues,
J.E.
Watcher 0
D-24876
AFF-I
Jiggs 0
SSK:
Get video of your landing and get an instructor to review and talk you through it.
"In our sleep, pain that cannot forget falls drop by drop upon the heart and in our despair, against our will comes wisdom" - Aeschylus
ciel bleu,
Saskia
