freakydiver
Night jump equipment...
Having not done a night jump in a good year, I'm trying to remember what equipment one generally needs for a night jump. Lighted alti, flashlight to check canopy, isn't there supossed to be a light visible for 3 miles that is on during freefall and canopy ride? Can you use glowsticks for that application?
Blue ones...
-- (N.DG) "If all else fails – at least try and look under control." --
oh.. get the new glow in the dark Altimaster Galaxy.. it ROCKS... and I think Storobes can be had at Radio Shack for the light requirement.. otherwise copius use of glow sticks.. especially if you are doing RW
Don't forget some lighting on the ground. Visual accuity is limited and depth perception of a flare that is off by a few feet can really suck.
Amazon
Strap it to your lower leg.. that way you can turn it on when you get under canopy... but it will be out of your direct line of sight.... to prevent killing your night vision..... obviously you want to close your eyes when you turn it on.
Amazon
Our SOP for military night jumps (and we tend to use these at Raeford because they make total sense)is: Red chem light on chest strap or main lift web. Green chem light on back of rig. White strobe on helmet. Chem light on altimeter.
Rationale: If you see red it's oncoming traffic and it's time to turn right. If you see green you may follow that traffic (with caution). I like my strobe pointing up because it illuminates the canopy without interfering with my night vision. Don't be cheap on the strobe, they will last for years and have multiple applications.
Tim
Maggot:ph34r:
Left lateral works really well (as long as it points down)...
There was one person on my first night jump that had the thing flashing him for about 30 seconds before he got it turned around! :D
Z-Flock 8
Discotec Rodriguez
Too bad weapons grade stupidity doesn't lead to sterility.
