Cajones 0
The main difficulty I've seen with using a BOC style "dummy pull" is in the movement of the container during/after deployment.
The BOC location is rather flacid after the main leaves the packing tray. This can make it difficult to locate the dummy handle.
- Cajones
The laws of physics are strictly enforced.
mojoman 0
QuoteIs JAD the same as IAD(instructor aided deployment)?
Yes. JAD=IAD
JAD= Jumpmaster Aided Deployment
We just use "practice pulls" no throw out at all. You can see a video of it here http://www.swoop.on.ca/pff.html click on the video link to watch the video.
~Jeff
Monkey Brother #1
http://www.monkeybrothers.ca
mojoman 0
QuoteHi,
~Jeff
Monkey Brother #1
I'm not concerned about the AFF stuff. We use practice pulls today and it's basically the same procedure with throw out/ripcord.
The challenge is the IAD students. The altitude is low and I really want to know that my student throw out that PC before I let them off for their first "real" jump :)
riggerrob 644
Most DZs ask students to toss two or three newspaper dummies before going freefall. The biggest problem was getting instructors to be consistent with the size of newspaper they used. Too many small dummy PCs blew out early.
I solved that problem by sewing together some dummy pilotchutes. They are made of Cordura stuffed with foam. A regular BOC handle is sewn to one end while a piece of bungee cord is sewn to the other end. A rubber band attaches the bungee cord to the corner of the container, tight enough that they won't lose the handle when they toss it, but loose enough that the rubber band will release if the dummy handle entangles with the deploying parachute.
The second scenario has not occurred in the last two years and we have never lost a handle.
Yes the container goes slack when empty, but that is just an extra challenge to see how they perform in less than perfect circumstances. Trust me, no student jump is perfect!
Cajones 0
Just make sure they are using the same procedure for their practice pulls as for their actual pull.
If their three stable practice pulls on static line/IAD are done with a ripcord, the first c&p should also be done with a ripcord. They can switch to a BOC/throwout some time after their 15 second delays.
- Cajones
Cajones 0
I was writing my reply when you posted, so I didn't see your solution until after my previous post...
Your rigging solution sounds nice. Are you stiffening the packing tray or BOC pouch in any way to minimize the effects of packing tray movement?
- Cajones
FrogNog 1
Quote[ 2. we always reach to the same place to pull, we just have to remember whether to throw it away or hold onto it. I have always gotten it right so far.
I always wondered about little tunnel rats that get tunnel time and are used to no pull time?
I ask because of my children (If they decide)
Yeah, I've thought about this in terms of whenever I may make my first tunnel flight/trip: am I going to freak out without a rig on my back and a handle on my butt?
Pull.
riggerrob 644
QuoteRob,
- Cajones
No, we are not stiffening the packing tray.
Our excuse - after the fact - is that the extra challenge is good at weeding out students who cannot handle minor changes in gear.
When I worked at Rigging Innovations, we did build a few Telesis student rigs with stiffeners in the side and bottom walls, specifically to address a problem they encountered at a JSPC, but we all agreed that it was a typical over-engineered British solution to a minor problem
mojoman 0
QuoteCanadian DZs started giving throw-outs to students in 1979.
Do you have some pictures of this solution?
Please :)
/David
