I'd say don't get in that situation in the first place. Pull at the right altitude, know your emergency procedures, and never give up even if you do have a double mal. I know i'd be climbing my risers trying to get my reserve to open...
-Blind
slug 1
Terminal velocity into water no way.
I wouldn't recommend doing a accuracy jump over water and trying to cut away to hit the target. Depth perceprtion over water is hard to judge and jumpers in the past have died trying this manuever. so we're talking maybe 50-100ft max and they didn't survive the landing.
R.I.P.
bch7773 0
MB 3528, RB 1182
hitting the water above 35 mph is the same as hitting concrete like everyone else says. I saw a movie once where a guy shot a 9mm into a 5 gal bucket of water, the bucket survived but the bullet came out flat...
BASE813 0
anyone got information on this?? i dont know shit about it!!
cheers
metalslug 36
Hmm.. surely it's not exactly the same as hitting concrete, is it ?
I mean.. if you hit concrete you'll literaly bounce.
A body would not bounce off water from a vertical impact at terminal.. or would it ?
The water does yield to some extent at least, albeit not enough to make the impact survivable.
As for movies, as 'educational' as they are, in 'Saving Private Ryan' we all saw German MG bullets penetrate easily through 6ft of surf and 1ft of soldier before hitting beach sand, apparently not significantly affected by the water impact.
TomAiello 26
Quote...end up under the water in a suit that you, injured or not, cannot swim in and takes two people to pull you to the surface since it fills with about 30 gallons of water.
I've had two water landings in a suit (SF1, which is fairly restrictive). On the first I only had to swim for a few minutes, but on the second it was more than 10 minutes before the boat pulled me out. While swimming in the suit is difficult, it is not impossible. The suit takes on very little water, actually, because once you cut the wings away, they tend to collapse.
QuoteThe manual says stay away from water at any speed in the suit.
Definitely a good idea. Swimming in the suit is a pain.
Tom@SnakeRiverBASE.com
SnakeRiverBASE.com
TomAiello 26
I think a lot depends on how you hit the water. If you hit it flat, you're pretty much toast. If you can hit feet first in a good "entry" position, you can probably get away with a life flight trip and a hospital stay.
I'm not sure how this bears on impact at terminal, which I suspect would reduce the survivability to near zero.
SnakeRiverBASE.com
ChrisL 2
Quote5 second delay, this is 366ft (111m) with a freefall speed of approx 84mph - do divers really do this sort of thing? b'jeayzus - if so thats a pretty hardcore sport!
cheers
No, divers do not do this sort of thing.
Diving from 366 feet would be fatal.
High Diving consists of acrobatic dives between 23 - 28 meters, from 75-90 feet up, many times into very shallow water of around 9 feet deep. When the diver takes off from a natural rock rather than a man-made platform, it is reffered to as Cliff Diving. From that height, the athlete has around 3 seconds before impacting on the surface of the water. The speed when entering the water is between 78 km/h and 100 km/h.
My mighty steed
bch7773 0
a. you better hit the pond, lake, ocean etc. at a spot where it is fairly deep. otherwise you will hit the bottom hard, causing even more injuries.
b. you better have someone within 50 feet of where you land, because you are gonna be badly injured, and probably unable to swim. you will drown in a matter of minutes.
can anybody find anything on the web about the highest someone has fallen into water from? something tells me its not over about 300 ft.
MB 3528, RB 1182
Also don't forget to PLF. Anything is survivable with a properly performed DYNAMIC PLF. :-)
Chris
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body; but rather to skid in sideways, totally worn out, shouting 'Holy s#$* what a ride!'"
mr2mk1g 10
QuoteIn the four-second fall from the bridge, survivors say, time does seem to slow. On her way down in 1979, Ann McGuire said to herself, “I must be about to hit,” three times. But the impact is not clean: the coroner’s usual verdict, suicide caused by “multiple blunt-force injuries,” euphemizes the devastation. Many people don’t look down first, and so those who jump from the north end of the bridge hit the land instead of the water they saw farther out. Jumpers who hit the water do so at about seventy-five miles an hour and with a force of fifteen thousand pounds per square inch. Eighty-five per cent of them suffer broken ribs, which rip inward and tear through the spleen, the lungs, and the heart. Vertebrae snap, and the liver often ruptures. “It’s as if someone took an eggbeater to the organs of the body and ground everything up,” Ron Wilton, a Coast Guard officer, once observed.
If it's 1500lb/inch at 75 mph I'd hate to think what impact you suffer at 120 mph.
Water is just as lethal as concrete. Due to the laws of physics, (I forget the technical terms) if you try to move through a liquid quick enough it takes on the properties of a solid. Water can litterally act like concrete.
BASE813 0
you are a very lucky man Tom!!
very lucky!!!
kallend 2,196
Even an incompressible fluid can move out of the way if it has a route.QuoteWater has /zero/ compressibility. To put it another way, the steam catapults on an aircraft carrier generate tremendous amounts of force.. Once the plane has been released, that catapult's shuttle needs to stop as quickly as possible. The Navy uses a very simply braking system. At the end of the shuttles track is a tube filled with water. The shuttle hits that and stops instantly.
-Blind
The issue is momentum transfer. Hitting the water requires a transfer of momentum to the water, and force = rate of change of momentum.
kallend 2,196
QuoteIf you hit big heavy waves its gonna hurt and damage you less than if you hit flat still water, because the still water has all that surface tension directly opposed to the direction you're coming in at.
Surface tension forces are negligible in this context.
It will at least keep you occupied.
Red, White and Blue Skies,
John T. Brasher D-5166
