Fab 0 #1 January 20, 2005 Just wondering. If you cut a line-over on your reserve...Will a chute still more or less fly normally? How would a canopy behave? _______________________________________ Quote Share this post Link to post Share on other sites
darkwing 5 #2 January 20, 2005 One great danger is that you cut the wrong line. Flyability after you cut the correct line depends greatly on which line. Generally speaking if you give a couple of shots to get it to release, and the canopy isn't landable as is, then I'd cut it. Of course this assumes you have opened with enough altitude to do anything. -- Jeff My Skydiving History Quote Share this post Link to post Share on other sites
mjosparky 4 #3 January 20, 2005 QuoteJust wondering. If you cut a line-over on your reserve...Will a chute still more or less fly normally? How would a canopy behave? When you cut a line-over you are in affect cutting two lines at the canopy. If you cut the right one, and only one (2 at the canopy) it will fly better than with a line-over. SparkyMy idea of a fair fight is clubbing baby seals Quote Share this post Link to post Share on other sites
Fab 0 #4 January 20, 2005 thanks _______________________________________ Quote Share this post Link to post Share on other sites
larsrulz 0 #5 January 20, 2005 Related directly to how it will behave. The canopy will be much less problematic the further back the cut line is. A brake line will only effect steering, while an A line will have the possibility of collapsing the nose under itself. Bs and Cs will be somewhere in between those two, but As are definitely a problem. This is more relevant with a main canopy, as I would personally immediately cut away an A line break if I was above my hard deck. I got a strong urge to fly, but I got no where to fly to. -PF Quote Share this post Link to post Share on other sites
jerry81 10 #6 January 20, 2005 QuoteRelated directly to how it will behave. The canopy will be much less problematic the further back the cut line is. A brake line will only effect steering, while an A line will have the possibility of collapsing the nose under itself. Bs and Cs will be somewhere in between those two, but As are definitely a problem. Unless you have really long arms, I doubt you'd be able to cut just a B line without affecting the A as well... Quote Share this post Link to post Share on other sites
dragon2 2 #7 January 20, 2005 Ask Kees, I think he once landed a Lightning with a broken A-line ciel bleu, Saskia Quote Share this post Link to post Share on other sites
LouDiamond 1 #8 January 20, 2005 I wish it was online because it would be a good visual teaching tool. Jeffro made a parody movie for the film festival where they played "flight club". A wrong answer meant you had to spin the dial to see how many lines you had to cut. Jeffro effectively cut away more lines than one would ever have to short of chopping. He was still able to fly the canopy or I should say, the canopy continued to stay inflated and flying. Besides being extremely funny, the film clip was actually informative as to what happens when one cuts a line(s) while under canopy."It's just skydiving..additional drama is not required" Some people dream about flying, I live my dream SKYMONKEY PUBLISHING Quote Share this post Link to post Share on other sites
mjosparky 4 #9 January 21, 2005 QuoteI wish it was online because it would be a good visual teaching tool. Jeffro made a parody movie for the film festival where they played "flight club". A wrong answer meant you had to spin the dial to see how many lines you had to cut. Jeffro effectively cut away more lines than one would ever have to short of chopping. He was still able to fly the canopy or I should say, the canopy continued to stay inflated and flying. Besides being extremely funny, the film clip was actually informative as to what happens when one cuts a line(s) while under canopy. I have done that type of thing on test jumps, but with a round canopy. Start at front center and cut one right, one left, one right, one left until it is time to leave.SparkyMy idea of a fair fight is clubbing baby seals Quote Share this post Link to post Share on other sites
