lowpole
Cessna 401
I've got jumps out of a 402 which I *think* is a similar bird.
If so CG is sensitive at best. Keep lots of weight foward as each group gets out.
Paul Janes at Skydown Skydiving is Idaho is running a 402. Give him a call......http://www.dropzone.com/dropzone/Detailed/461.shtml
Like everyone else I'm not sure how relevant this is... but I've done 100 or so jumps out of a 411. We'd put two outside (one rear float and one in the door)and one inside the door with everyone else lined up single file inside. Only heard the stall warning horn a few times...
I have done a few tandems out of a Cessna 400 series twin. Sorry, but I cannot remember exactly which model it was.
We remembered to keep weight well forward until the first few groups had exited. For example, the last tandem kept his pack against the instrument panel until 5 seconds before it was his turn to exit.
The door was narrow, so I put my elbows on top of the student's shoulders.
Suggest to your pilot that he lower a few notches of flap, to raise the tail, reducing the chances of some git hitting the horizontal stabilizer.
Also remind him to fly jumprun fast enough that he still has plenty of control.
Has anyone out had exp. jumping this plane? Owner is pretty green and is not sure how too load for the door.
I have a good friend out on the 'Left Coast'
that has a 401...
He's a semi-retired sky god and jump pilot.
I emailed him for any suggestions he may have,
and will post his reply when I receive it.
I know the 402 I've jumped also had quite a bit of ballast (weight) in the nose.
The one thing I can add to this is...when jumping a 400 series Cessna, skydive down! I've known of at least one fatality and several non-fatal tail strikes because of exiting in a conventional "student" poised arch-type exit. If it were me flying that bird, I'd plan on a power-flaps-pitch combination that resulted in a minimum prop blast, nose low attitude; even if it means losing a bit of altitude on jump run. A few hundred feet of altitude loss is a lot less expensive than a stabilizer and/or a human life. So, these planes can and have been jumped successfully, but proper planning to avoid an accident is imperative.
If an operation were using them for AFF they might consider the seated "206U" style exit.
We had one in Cal City and I hated it for AFF and Tandems. For up-jumpers it's okay as long as they don't snag anything around the small door and are observant of the horizontal stabilizer position.
With medium to large size AFF students the early levels are hard to launch. I found myself alone with AFF Level Ones so many times we started figuring the second jumpmaster was in the plane just to make things legal.
I'm an A&P mechanic, although I never did any work on one, but they always seemed underpowered to me and when fully loaded we used a lot of RWY. To get my mind off an engine going south at that point I always kept myself busy doing something else.
I was in the right seat one day, no students on board, and I mentioned my concerns to the pilot. He promptly pulled the right throttle back and scared the hell out of everyone in the back. We had a hell of an argument later about that.
I won't say this series Cessna is involved in a lot of mishaps, as there are a lot of factors to consider like maintenance, pilot, weather, etc. but it seems over the years I've seen them mentioned quite a bit.
At the DZ we called that aircraft a four-oh-shit . . .
NickD :)BASE 194
I said the same thing to the pilot , that taill is way! too close and if you have to sacrifice alt. for head clearance that's a good thing! and too the people talking about a "small door" when we took apart the "lux" door , the was almost as big as an otter.\
thanks for the input from everybody! I really appreciate the feedback.:)
Darwin's Watching!
