justinb138
What are these things? (Aircraft question)
hyper canopies has the same thing. they help with reducing the vortacies during slow flight, wich helps slower flight performance, like flare.
beezy shaw will be able to give a better explanation.
But increasing the vortacies on the top skin gives
MORE lift
Stall fences are thin plates of metal mounted on the top of the wing, projecting upwards, aligned in the same orientation as the direction of flight.
Their purpose is to reduce the spanwise (root to tip) flow of air, thus maintaining boundary layer thickness (delaying the stall) and enhancing aileron control at high angles of attack.
They keep the airplane in better control at lower airspeeds such as when jumpers are exiting.
ignore this for now:
They aren't VGs.
What they help to do is to keep a stall from moving outboard along the wing. The wing has a certain amount of "wash-out" or twist to make the inboard end stall first but leave the outboard end flying as the a/c recovers. The fences assist in preventing stall propagation outboard.
This can also be done with vortelons which are small sticky-outy thingys on the lower leading edges at about the same location. Look on a Gulfstream IV.
Vortex generators make small vortices which excite the boundry layer and keep it closer to the wing in high angles of attack. This gives the wing more efffective lift at slower speeds. For example, my Stinson takes off at 45 mph with them but 60+ without them. Landing performance is similar but I am too busy landing to look down at the airspeed to give you an accurate number.
The Gulfstream II has fences which stick up about 8" for the entire chord of the wing. They have VGs outboard of the fences and in front of the ailerons.
Another place where VGs are effective is over the cockpit of jets. There is a mach buffet on some which can be extremely noisey. Carefully located VGs move this rearwards a couple of feet and away from the pilots' heads.
That description works!:)
Must be my ethnic background...;)
I knew they weren't actual VG's but I thought they worked 'like' them...your explaination is clear.
They aren't VGs.
While they aren't a vortex generator, they are a "vortex generator of sorts." They work by producing a vortex, which in turn takes the spanwise flow of the wing and turn it parallel to the line of flight. The biggest difference is that vortex generators directly influence the boundary layer of a wing, pumping energy into it so it will stay attached at high lift, while fences and vortilons indirectly effect the boundary layer by influencing the potential flow (flow in which vorticity is zero). But, you know....details. :P
I got a strong urge to fly, but I got no where to fly to. -PF
is that an aircraft technical term???
If you said it in french, probably. Many of those technical for airplane parts are in french for some reason. I never figured out how that happened since they first showed up on american designs. ie canard, aileron, etc.
Dave
