flighty 0
I wholeheartedly agree. By saying safety day class, I meant familiarizing skydiving medical professionals with the specific model at the dz, as there are several different types. I just couldn't imagine holding manual traction for any extended period of time.QuoteIMHO A traction splint is NOT a topic for a safety day class. This is a piece of equipment that while available to the public should only be use with specific training that is part of an overall certification in pre hospital treatment. As a MFR licensed in MI I DO recommend that medical personel trained in its use that hang out at the DZ have one. I suggested it in my first aid for the DZ seminar at the PIA symposium last year.
Anyone want to give an opinion on whether it is better to do manual traction or wait for the ambulance.(lets say we're talking about a trained EMT, plenty of help, isolated femur fracture with deformity and swelling)
People have brought up some great points about legal issues. I am so glad to see that a few dzs have policies about first response. I fear that that isn't true of most dzs though.
~Cindy~
Quantum materiae materietur marmota monax si marmota monax materiam possit materiari?
Spelling and grammar errors are left as an exercise for the reader.
-Eric Hoffer -
Check out these Videos
Erroll 80
QuoteSo, in the absence of specialized training and a traction device just administer first aid/CPR until EMT's arrive, correct?
In the event of a compound fracture and your victim is stable, would it still be worthwhile to attempt to slow the blood flow by applying pressure or, with femur, it might cause more harm than good?
A little clarification, please?
I seem to recall an incident several years ago where a (military?) parachutist died in Bloemfontein, South Africa, after suffering a compound fracture. Reported cause of death was 'Bone marrow entering the bloodstream'. Does this sound probable?
skymedic 0
QuoteReported cause of death was 'Bone marrow entering the bloodstream'.
possibly...but more likely caused by numerous other issues with a broken open femur fracture.
my advice for displaced CLOSED femur's is wait for an ambulance. I could hold manual traction...but you have no idea how stron the muscles are in the thigh, on top of a screaming hurting person, they will tense up and have more resistance for you to hold. remember most DZ's are way out of the way....and your nearest ambulance most likely will be an extended time(10-20mins or more) so if you apply traction and then let up an any point as those VERY sharp ends of bone go penetrating back into that jumpes leg you could lacerate nerves, or worse major vessels...letting an already very bad injury into a fatal injury.
please dont be a hero....I dont treat at the DZ....other than rapid assessment and ABC's...let the ambulance do it.
Marc
otherwise known as Mr.Fallinwoman....
mr2mk1g 10
My concern is that in many jurisdictions the moment you start trying to perform procedures that require specialist training or start using equipment that is normally the preserve of a specially trained profession, your litigation risk instantaneously shoots through the roof. The reason is that many jurisdictions sensibly say that if you are going to perform a specialist procedure or use specialist tools then you must do so with the skill of a reasonable person who is trained in that procedure / with that equipment.
eg: if you perform CPR you may only have to live up to the standard of a reasonable person who is trained in CPR... not too hard to do as that probably means someone just like you. If try to use a backboard in order to immobilise a person you may find yourself having to live up to the standard of a reasonable EMT for example... that may be significantly harder… you’re probably not an EMT nor are you trained to know what they know. If you start trying to do things like use a traction splint, depending on what the local rules are and how complicated things get, you [I]could[/I] find yourself having to live up to the standard of a Doctor… if you fail to meet that standard then you open yourself up to the possibility of litigation – and they’ll probably win.
If you’re an individual skydiver, do you have medical malpractice insurance? Well if you don’t your unlikely to be a tempting target for a lawsuit, but if they want to sue and you’re the only one out there… If you’re an employee of the DZ then the DZ can be liable for anything you do – even negligently provided medical care in the right circumstances.
The crux of the matter is, if a DZ is going to have a backboard or traction splint, they better have a procedure for who can and cannot use it, a documented training scheme for those who can, and a documented system for keeping their knowledge current and well practiced. They should also check out the local rules on who in the medical community can use that equipment and what look standard they are going to be judged against should the worst come to the worst.
These comments are only intended to reflect the generality of the common law system and those basic principals that are shared with many legal systems in the English-speaking world. I have little direct knowledge of US law and can only fully comment on the law of England and Wales. Please check your local jurisdiction for the applicability of my comments before relying upon any of them.
skymedic 0
QuoteMy concern is that in many jurisdictions the moment you start trying to perform procedures that require specialist training or start using equipment that is normally the preserve of a specially trained profession, your litigation risk instantaneously shoots through the roof. The reason is that many jurisdictions sensibly say that if you are going to perform a specialist procedure or use specialist tools then you must do so with the skill of a reasonable person who is trained in that procedure / with that equipment.
exactly the problem we face....hence the reason why I never stop at car accidents and only do the bare minimum at the DZ if someone is injured...I know due to our good sam laws they can't really touch me...but that doesn't mean they can't sue anyway and try to beat the good sam law's. I am in no need or want of a lawsuit for something I did or did not do...
Marc
Skydiving isn't scary;...but clowns...CLOWNS are scary!
I think there is enough major trauma in this sport to warrent a greater level of understanding of EMS then first aid...Where I jump that is the case (blind dumb luck on my part) I've been in EMS a bit as well and the fact is it's the first responders and bystanders that save peoples asses more times then not. Mabey it's an east coast thing that you all don't teach the public to do things, out here you can buy a traction splint with no training, KED makes one especially for climbers. If people are interested in learning more to help their buddies when they slam in, we should be teaching them. Hell, you can't throw a rock without hitting medical professional on my DZ, it can't be that different everywhere else. Lets teach and organize, it might save my ass, and I'm all for that!
-Eric Hoffer -
Quote...I know due to our good sam laws they can't really touch me...but that doesn't mean they can't sue anyway and try to beat the good sam law's. I am in no need or want of a lawsuit for something I did or did not do...
Not in CA. Good Sam laws DO NOT cover you. You are held to standard of care. So act within it and you are covered...anyways if you are known as a Paramedic at your DZ you have a duty to act and are liable. Omission is as bad as commission here. So if you had gear...your buddy was down, you would do nothing beyond ABC's & c-spine?
-Eric Hoffer -
skymedic 0
Quoteyou would do nothing beyond ABC's & c-spine?
Yep...and I dont have gear and my DZ doesn't have gear...just to avoid the issue. we have life flight closer than we have a ground ambulance where I jump. also standard of care for good sam laws apply if you are on duty here in IL where I practice. as far as duty to act if I am not at work I do not have a duty to anyone.
Marc
Wow! the laws are very different there?!?
Quoteas far as duty to act if I am not at work I do not have a duty to anyone.
Again, here "Duty to act" is a legal distinction, not a moral one
But that's all beside the point, I'd help my buddies regardless of the consequences, fuck the law.
-Eric Hoffer -
I would also add:
If there is obvious massive bleeding, either externally or internally (you know if you see it) I would also apply direct presure to the inner groin area where the leg and pelvis meet. this will help limit the blood flow to the leg below.
If there is massive external bleeding and applied presure does not limit the flow enough, I would consider a tornequette. but only if I knew how to apply it. (and I do).
My Life ROCKS!
How's yours doing?
