airtwardo 7 #1 May 17, 2005 Adjustable Harness.... I think I can make this one work for EVERYTHING! ~ If you choke a Smurf, what color does it turn? ~ Quote Share this post Link to post Share on other sites
AndyMan 7 #3 May 18, 2005 A tandem passenger harness wrapped around a Sigma??? _Am__ You put the fun in "funnel" - craichead. Quote Share this post Link to post Share on other sites
Zep 0 #4 May 18, 2005 Did'nt the early Parachute de France containers have some thing like that? May be wrong. But I seem to remember you could adjust them every wich way . Gone fishing Quote Share this post Link to post Share on other sites
lawrocket 3 #5 May 18, 2005 Bring out the Gimp! Did you get that one, ahem, off the rack? My wife is hotter than your wife. Quote Share this post Link to post Share on other sites
JohnnyD 0 #6 May 18, 2005 Where do you put the big brass balls? Quote Share this post Link to post Share on other sites
airtwardo 7 #7 May 18, 2005 QuoteWhere do you put the big brass balls? *** Just snap 'em onto one of the several adjustable "hang-ie on-ie" rings! *** ~ If you choke a Smurf, what color does it turn? ~ Quote Share this post Link to post Share on other sites
SwampThing 0 #8 May 18, 2005 WOW! It looks so- Lightweight AND Comfortable! The Pessimist says: "It can't possibly get any worse!" The Optimist says: "Sure it can!" Quote Share this post Link to post Share on other sites
billvon 3,162 #9 May 18, 2005 If the tersh rings are ever actually used, won't they be loaded the wrong way? Looks like the load might be taken by the binding tape stitching right above the ring rather than the type-12 that holds the ring captive. Or are they for something else? Quote Share this post Link to post Share on other sites
Hooknswoop 19 #10 May 18, 2005 I'm guessing for a flag or ruck sack. Derek Quote Share this post Link to post Share on other sites
airtwardo 7 #11 May 19, 2005 QuoteIf the tersh rings are ever actually used, won't they be loaded the wrong way? Looks like the load might be taken by the binding tape stitching right above the ring rather than the type-12 that holds the ring captive. Or are they for something else? *** True but the stitching for the 'tape' isn't intergal to the harness itself so even if it were overloaded to the point of failure, it won't compromise the strength of the harness...unlike some 'removable' D-Ring set-ups that are sometimes used on standard sport harness systems. ~ If you choke a Smurf, what color does it turn? ~ Quote Share this post Link to post Share on other sites
billvon 3,162 #12 May 19, 2005 >True but the stitching for the 'tape' isn't intergal to the harness itself so > even if it were overloaded to the point of failure, it won't compromise the > strength of the harness. OK, so it's sort of a one-time-use tersh attach? I guess that makes sense if the tersh is used to back up a regular reserve. >unlike some 'removable' D-Ring set-ups that are sometimes used >on standard sport harness systems. Yeah, I rarely see an aftermarket tersh ring attachement that looks well designed. Quote Share this post Link to post Share on other sites
airtwardo 7 #13 May 19, 2005 >OK, so it's sort of a one-time-use tersh attach? I guess that makes sense if the tersh is used to back up a regular reserve.< Quote Opps...Left out a line on my 1st reply, It's attachment points for Flags / Rucks etc. as Hook said. Not tersh attachments.... BUT..that does give my an idea! > Yeah, I rarely see an aftermarket tersh ring attachement that looks well designed. < Quote It's not the rings that cause me concern...it's where people put them, and what they use them for. I've cautioned several demo jumpers that had the removable rings threaded through their harness just above the Box-X...with quite a load mounted on them. The Harness was never meant to have something pulling against the stiching like that. A high G opening 'could' seperate the whole harness. ~ If you choke a Smurf, what color does it turn? ~ Quote Share this post Link to post Share on other sites
