.... not a good thing to do the 3-rings because of hand oil, I think someone had commented on this related to cast fittings, but I don't believe it would apply to stainless steel in any regard.
Cast fittings?
Cast hardware has never been fashionable for skydiving.
He was probably referring to forged steel hardware with cadmium plating.
The original reason for rotating rings was to detect a soft batch of rings made in the 1980s. Unfortunately - like many religions - skydivers still obssessively and compulsively rotate rings long after the bad batch was scrapped.
You are correct in that excessive compulsive rotating of rings will wear off the cadmium plating, leading to pre-mature rust.
You are also correct that stainless steel hardware will oxidize at a much slower rate.
You can post now and register later.
If you have an account, sign in now to post with your account.
Cast fittings?
