jose
How do I find air temps at altitude for Canada?
For Canada, the NavCan AWWS site (suggested by Bob.Dino) suggests one go to the Meteorological Service of Canada for historical data.
e.g.,
http://www.climate.weatheroffice.ec.gc.ca/Welcome_e.html
I've used it only a bit. It seems that only surface data is available for their reporting stations, but it does include hourly values.
For temps in the atmosphere, who knows -- even the normal NavCan forecasts are for 3k, 6k, 9k, etc. feet ASL -- less detailed than what you are ideally looking for.
Its always easier to get forecasts than historical data for weather. The best I can think of, is if one is doing something like reducing flight test data and need temps, make sure to get the forecast temps by calling Flight Service and then check the aircraft OAT gauge before exit...
If you know the ground temp, just subtract 3.5 degrees for every 1,000 feet of altitude above that. This is a general rule of thumb, but will vary slightly depending upon degree of humidity - moist air retains warmth compared to dry air.
Let's say it is 95 degrees on the ground, like here in summer time Houston, Texas. So at 13,000 feet: 95 - (13 x 3.5) = 49.5 degrees.
Jose
I work in Flight Service. One of our specialists has a website that has a link to an ACCARS computer analysis of upper air soundings. Use the RUC portion and type in the four letter identifier such as CYYZ for Toronto CYUL for Montreal etc. Use the major airports 4-ltr indentifier. You can disregard the winds and dew point and isotherm data on the chart portion and use the lower portion.
Here is the link, hope this helps.
http://www-frd.fsl.noaa.gov/mab/soundings/
Chris
Skydive Houston
Jose. Again here is a partial sample of winds and temperature aloft for Montreal Dorval at 18Z today up to about 15,000 feet.
(DD = 'A' means analysis)
Pressure_Alt DD Dir Spd ---Temp--- DewPt
(ft) (mb) (kts) (F) (C) (C)
111 1013.0 A 40 14 69.6 20.9 14.0
183 1011.0 A 42 16 68.2 20.1 14.2
328 1006.0 A 43 18 67.5 19.7 14.2
492 1000.0 A 40 19 67.1 19.5 14.5
544 998.0 A 48 19 67.1 19.5 14.6
836 988.0 A 48 19 65.7 18.7 14.6
1279 972.0 A 50 20 63.3 17.4 14.3
1725 957.0 A 47 20 61.0 16.1 14.2
2178 941.0 A 46 21 58.6 14.8 13.9
2634 926.0 A 47 21 56.3 13.5 13.1
2680 925.0 A 46 21 56.1 13.4 13.0
3097 911.0 A 50 22 54.0 12.2 11.9
3566 895.0 A 57 23 52.0 11.1 9.4
4041 880.0 A 64 25 51.3 10.7 7.6
4524 864.0 A 67 26 50.7 10.4 7.9
4996 850.0 A 65 24 50.2 10.1 8.2
5016 849.0 A 74 24 50.2 10.1 8.2
5515 834.0 A 80 21 49.6 9.8 6.9
6023 818.0 A 79 17 50.5 10.3 0.6
6541 803.0 A 67 13 49.6 9.8 -4.5
7066 787.0 A 59 11 48.6 9.2 -9.9
7601 772.0 A 60 10 47.1 8.4 -12.8
8146 757.0 A 65 9 45.7 7.6 -16.6
8700 741.0 A 64 8 44.2 6.8 -17.7
9265 726.0 A 63 6 42.8 6.0 -18.0
9845 710.0 A 74 3 40.6 4.8 -16.7
10246 700.0 A 116 2 39.0 3.9 -16.0
11181 675.0 A 223 1 35.4 1.9 -14.5
12831 634.0 A 259 6 29.8 -1.2 -12.2
14324 599.0 A 269 8 25.0 -3.9 -11.2
15761 566.0 A 271 11 20.3 -6.5 -12.5
Chris
Skydive Houston
Jose this is for CYXX Abbotsford, BC for today at 20Z for example from the RUC analysis from ACCARS.
Analysis fro the US is kept at The National Climatic Data Center in Asheville, NC.
Here is ABBOTSFORDS Analysis sample.
311 1003.0 A 192 8 59.5 15.3 14.4
380 1000.0 A 193 9 59.4 15.2 14.3
390 1000.0 A 194 9 59.4 15.2 14.3
521 995.0 A 192 11 60.3 15.7 14.2
731 988.0 A 194 13 61.3 16.3 14.0
1017 977.0 A 198 13 59.9 15.5 13.7
1450 962.0 A 203 12 57.7 14.3 13.0
1886 947.0 A 225 10 55.6 13.1 11.8
2329 932.0 A 247 10 53.6 12.0 9.7
2555 925.0 A 251 10 52.5 11.4 8.5
2778 917.0 A 244 10 51.6 10.9 7.4
3231 902.0 A 233 10 49.5 9.7 5.7
3687 887.0 A 216 11 47.1 8.4 4.1
4153 872.0 A 206 12 44.8 7.1 2.3
4622 857.0 A 204 13 42.4 5.8 2.4
4849 850.0 A 214 13 41.5 5.3 2.4
5098 842.0 A 213 12 40.5 4.7 2.5
5580 827.0 A 218 13 38.5 3.6 3.0
6069 812.0 A 219 15 36.3 2.4 2.3
6955 785.0 A 223 16 32.9 0.5 -0.2
7664 764.0 A 227 17 32.5 0.3 -1.6
8362 744.0 A 231 19 32.2 0.1 -2.4
9261 719.0 A 237 22 30.7 -0.7 -3.4
9977 700.0 A 248 25 29.3 -1.5 -4.5
10275 692.0 A 242 26 28.8 -1.8 -5.0
11489 660.0 A 245 31 25.5 -3.6 -7.4
13057 621.0 A 245 36 20.5 -6.4 -9.5
Chris
Jose.
I know, I think some others on this group gave you someplace to start to find the data to. Like I said the US stores this data in Asheville, NC. Canada probably has someplace that stores the data to. Probably someone at NAVCANADA knows.
Chris
