atsaubrey 0 #1 September 18, 2005 How likely is it to blow a 3 ft long hole along a seam on a bottom cell on a brand new canopy? I did yesterday and am curious how likely it happens."GOT LEAD?" Quote Share this post Link to post Share on other sites
DeNReN 0 #2 September 18, 2005 That sucks man....and looks like it was very likely as it happened And you should know better....more info will be asked for...speed at deployment...extra hard opening etc etc etc Quote Share this post Link to post Share on other sites
FlyinseivLP2 0 #3 September 18, 2005 I would say your size has something to do with it. Had a friend about your size that would blow up canopies a good bit. PD made him a Sabre that was super reinforced.He eventually quit jumping cause he was afraid he might blow up his reserve. Quote Share this post Link to post Share on other sites
billvon 3,170 #4 September 18, 2005 >How likely is it to blow a 3 ft long hole along a seam on a bottom cell on a brand new canopy? If there was an inherent problem with the fabric or construction of the canopy, it will most likely be seen at the first jump. In the electronics industry we call this phenomena "infant mortality." There's a failure curve we call the 'bathtub curve' because it's high initially (due to infant mortality) low in the middle and then starts rising towards the end of its life as wear items start to wear out. Quote Share this post Link to post Share on other sites
sd-slider 0 #5 September 18, 2005 I was there @ deployment and we were cruisin' @ about ~140 (via Pro-Track on the ankle) when he threw. I watched the opening as I tracked away and it didn't seem rough or ABnormal from my view. Still sucks though!.Anvil Brother #69 Sidelined with a 5mm C5-C6 herniated disk... Back2Back slammers and 40yr old fat guys don't mix! Quote Share this post Link to post Share on other sites
darkwing 5 #6 September 18, 2005 In the absence of other factors, I'd ordinarily look for a manufacturing defect for a first jump failure. -- Jeff My Skydiving History Quote Share this post Link to post Share on other sites
PhreeZone 20 #7 September 18, 2005 140? Thats about 20 mph over speed of a normal deployment. Excess force on the canopy can easly result in a blown canopy.Yesterday is history And tomorrow is a mystery Parachutemanuals.com Quote Share this post Link to post Share on other sites
Anvilbrother 0 #8 September 18, 2005 Damn dude that sucks, have you spoken to the canopy maker yet? Did you land it, or chop it? Postes r made from an iPad or iPhone. Spelling and gramhair mistakes guaranteed move along, Quote Share this post Link to post Share on other sites
midnightrider 0 #9 September 18, 2005 you were jumping a 320?? i've had a PD rep tell me they drop tested PDR 113's (dont really know the difference in construction) with three hundred lb weights at terminal (over 200 maybe??)..he swore it snapped the risers and did no damage to the canopy..140 is fast but not fast enough to blow a canopy up (typically anyways) Quote Share this post Link to post Share on other sites
atsaubrey 0 #10 September 18, 2005 I didn't have a hard opening but it was on the brisk side but far from hard. (anything is brisk when i was getting 500 ft+ snivels before) As far as speed goes I never went above 140 and was slowing down before deployment (Neptune). Guesstimate would be about 135 at the time I threw. It does appear it does happen and that is what i was looking for. I did not chop it andonce under canopy I did notice a small "hole" that appeared to be a crossport. I have a all white bottom skin and the hole appeared to be yellow which is the color next to the black cell that was blown. When I say hole it only looked to be about 3" in diameter. We didn't notice the actual tear until we went looking for the hole. My guess is it was a small hole that continued to go as I did my checks and a few spirals. I changed my info to protect the manufactuer, I don't care to start a manufactuer A over B session."GOT LEAD?" Quote Share this post Link to post Share on other sites
airtwardo 7 #11 September 18, 2005 As I said in the PM... I would think it's a manufactures defect, it does happen. Document the stuff we talked about and return it, that company stands behind their products and you shouldn't have a problem getting it fixed. ~ If you choke a Smurf, what color does it turn? ~ Quote Share this post Link to post Share on other sites
EvilLurker 2 #12 September 18, 2005 The manufacturer needs to see the canopy as soon as possible. It may be bad fabric and the flaw might extend to other canopies, or it's a manufacturing defect and they need to see that, too. Glad you made it out okay. It sounds like a seam ripped from your description. I think you're a "test jumper" every time you buy a new canopy, I always opened high on the first few jumps, just in case. That may be the lesson in this. Quote Share this post Link to post Share on other sites
Anvilbrother 0 #13 September 18, 2005 You might be able to get the right colors this time if it ripped in the right spot right? Postes r made from an iPad or iPhone. Spelling and gramhair mistakes guaranteed move along, Quote Share this post Link to post Share on other sites
mjosparky 4 #14 September 19, 2005 Glad to see you dealt with it and landed safely. I know the manufacture you dealt with and Airtwardo knows them very well. Follow the advice he gave you in PM and I am sure it will be handled. SparkyMy idea of a fair fight is clubbing baby seals Quote Share this post Link to post Share on other sites
outlawphx 1 #15 September 19, 2005 That sucks man! I hope the manufacturer does right by you. Quote Share this post Link to post Share on other sites
atsaubrey 0 #16 September 19, 2005 It appears all will be well from the manufacturer."GOT LEAD?" Quote Share this post Link to post Share on other sites
outlawphx 1 #17 September 19, 2005 Quoteand a few spirals. That probably wasn't a good idea with a known canopy problem. Quote Share this post Link to post Share on other sites
outlawphx 1 #18 September 19, 2005 QuoteIt appears all will be well from the manufacturer. Good to hear! So the question is, are you going to try another one just like it, or get something else? Quote Share this post Link to post Share on other sites
atsaubrey 0 #19 September 19, 2005 Don't know yet..actually waiting to talk to the manufacturer and imagine they will want to see the canopy before we decide if something else is needed or if it was just a flaw when it was made."GOT LEAD?" Quote Share this post Link to post Share on other sites
nate_1979 9 #20 September 19, 2005 Dude, that sucks.... I heard about it at the DZ, I got there after it happened.. Hopefully you get it all figured out ASAP So, when are you, eric, and me gonna do a three way, you guys can just tow my ass. FGF #??? I miss the sky... There are 10 types of people in the world... those who understand binary and those who don't. Quote Share this post Link to post Share on other sites
atsaubrey 0 #21 September 19, 2005 QuoteQuoteand a few spirals. That probably wasn't a good idea with a known canopy problem. After opening I didn't know I had a bad cell until I landed. If I saw the problem I would more than likely chopped it."GOT LEAD?" Quote Share this post Link to post Share on other sites
Joellercoaster 6 #22 September 20, 2005 Man, after all the trouble you went to to get a decent-sized main, container, etc... now this! Hopefully you're accruing huge amounts of Gear Karma.-- "I'll tell you how all skydivers are judged, . They are judged by the laws of physics." - kkeenan "You jump out, pull the string and either live or die. What's there to be good at? Quote Share this post Link to post Share on other sites
skymiles 3 #23 September 23, 2005 So what did the manufacturer say and what are they going to do? Phil Quote Share this post Link to post Share on other sites
dgskydive 0 #24 September 24, 2005 Had a friend once that had his entire canopy blowup on jump number 1. I mean shreds of it were falling all over the place. It happens from time to time.Dom Quote Share this post Link to post Share on other sites
Superman32 0 #25 September 24, 2005 QuoteHad a friend once that had his entire canopy blowup on jump number 1. I mean shreds of it were falling all over the place. It happens from time to time. I just hope that doesn't happen with a reserve Inveniam Viam aut Faciam I'm back biatches! Quote Share this post Link to post Share on other sites
