riggerrob 644
I have seen a couple of tandem students "throw" their shoulders out of joint when they arched immediately after exit.
I even saw one poor static-line student throw his shoulder out by practicing arching too vigorously in ground school - long before he got near an airplane.
Some people just have weak shoulders and don't know it until they try arching/boxman.
bob.dino 1
QuoteI now pull with my left hand as a result.
I assume you just turned around the BOC pouch? Is your reserve handle still on the left side of your MLW? (I'm figuring that even if it is, you could deploy it using your right hand).
Just curious as to what needs to be done for left-handed throw-out.
brits17 0
QuoteI assume you just turned around the BOC pouch?
You just answered your own question in question form, but its the correct answer
_______________________
aerialkinetics.com
QuoteI assume you just turned around the BOC pouch? Is your reserve handle still on the left side of your MLW? (I'm figuring that even if it is, you could deploy it using your right hand).
Yes my Reserve Handle is still on my left side and no I would use my left hand to deploy my reserve just as usual. Were you meaning my cut-away Pad?
Normal use both arms good - right hand cut-away, left hand reserve.
Right arm dislocated - left hand cut-away, left hand reserve "yes you can reach it".
Yes, the BOC pouch was modified for lefty throw out
Tami
bob.dino 1
Sorry, I was just thinking about what would happen if your left arm was disabled - both your parachute activation devices are on your left side.
(I haven't had my morning coffee. I don't think I'm making total sense yet
I believe myself to be in pretty good shape. It was just one of those things
Tami
