SkydiveJack
PAC 750XL PROBLEM
I got this from my weekly AOPA e-mail update. Looks like the operators will have to reduce the take-off weight by 375 lbs. until this issue is resolved.
Jack
FAA ISSUES EMERGENCY AD FOR RARE AIRPLANE MODEL
The New Zealand Civil Aviation Authority has notified the FAA that the wings on Pacific Aerospace 750XL airplane models may not meet the ultimate load requirements for a maximum takeoff weight of 7,500 pounds. The maximum takeoff weight has been reduced to 7,125 pounds while the company develops a modification that will replace critical rivets with "AN" bolts. There are only five of these aircraft in the U.S. registry. Download the AD (http://download.aopa.org/epilot/2005/20052653ad.pdf ).
Download the AD ( http://download.aopa.org/epilot/2005/20052653ad.pdf ).
Clicky of Jack's AOPA link: http://download.aopa.org/epilot/2005/20052653ad.pdf
Clicky direct to FAA: http://www.airweb.faa.gov/Regulatory_and_Guidance_Library/rgAD.nsf/0/024844d7e970c68d862570e00057f02e/$FILE/2005-26-53%20(Emergency).pdf
If FAA clicky doesn't work:
Go to http://www.faa.gov/aircraft/safety/alerts/
Click on "Airworthiness Directives (AD)"
Click on "Emergency ADs (Last 30 days)"
Click on "2005-26-53"
Original emergency airworthiness directive from New Zealand CAA:
http://www.caa.govt.nz/fulltext/nzcars/Emergency/DCA_750XL_7.pdf
Followup emergency AD from NZ CAA, approving replacement of rivets
with bolts per PAC service bulletin:
http://www.caa.govt.nz/fulltext/nzcars/Emergency/DCA_750XL_7A.pdf
Eule
PLF does not stand for Please Land on Face.
Does this mean less jumpers? {how much does the a/c weigh?}
Would be the easiest way to reduce weight on a jump plane. The difference looks like 375 lbs, so I'm thinking less two "average" size jumpers might do it ? 'Til they get a new bag of screws to hold the wings on anyway....
Your humble servant.....Professor Gravity !
There are never more than 15 jumpers on the PAC at Davis. Assuming the max weight refers to full fuel, 17 jumpers and a pilot, I'm assuming that this will not affect normal operations here.
But I've been wrong before.
Don't know how many jumpers the other PAC's in the US typically fly with.
We could review the numbers, but very few airplanes can fly will full seats and full fuel and full baggage.
They plan it so that pilots can trade off passengers or cargo on longer flights so that they can fill all the fuel tanks.
For example King Airs have a total of six fuel tanks: 2 nacelle tanks, then inner and outer wing tanks. Most King Airs - configured for skydiving - rarely fill any more than the nacelle tanks. They only fill the outer wing tanks for end-of-season ferry flights.
This bit of info was posted in another group here in Nor Cal by aliasjumper@yahoo.com
"For European certification they required a new
test
on the wing of the PAC 750XL. The test is
something
like 3.5 G's plus 150%. On the test wing (almost
40,000lbs), It came up 8% of the desired goal.
That
is why there is a new temporary max weight of
7125
lbs. The factory knew that the wing and spar
should
easily pass the test, so they knew there was
either a
manufacturing issue with that one wing or a flaw
in
the test. Upon investination, they discovered
incorect rivits installed in the spar cap. So
within
48 hours the factory had a fix and issued a
service
bullentin. To insure the error could not
repeated,
they elected to replace the rivits with bolts.
Now in the real world, it was never a operational
issue. We had to do a new weight & balance. So
with a
full load of 17 jumpers, you are now limited to
350
lbs of fuel. Since we usually only fly with 15
or 16
as a max, there is no change.
The good news is the Factory ID'ed a problem and
had
it resolved with a fix, retested and had service
bullentin issued within 48 hours. That's factory
support!
Be safe
Ed
www.WestCoastWingsuits.com
www.PrecisionSkydiving.com
Rather than bumping it, why not contact them?
I'd be pretty sure it is done by carrying either less jumpers or less fuel, if they were even operating at max load in the past. :P
Didn't feel it important enough for me to call and bug them... just currious and thought maybe some of the Taft Locals might want to post and say if they knew.
You're probably right though... less fuel, maybe a couple few jumpers until they comply with the AD.
Meanwhile, an airworthiness directive (AD) reducing the 750XL’s maximum take-off weight from 3,400kg (7,500lb) to 3,230kg, issued by the New Zealand CAA on 23 December, has been overcome. The AD was issued after the wing failed ultimate load tests.
A modified wing passed ultimate load testing the day after the AD was issued, Hébert says, and the directive has been revised to restore the 3,400kg take-off weight after operators have modified the wing.
exerpt from www.flightinternational.com/Articles/2006/01/24/Navigation/177/204290/PAC+changes+reinvigorate+750XL.html
Fire Safety Tip: Don't fry bacon while naked
And that's generally the purpose of an Airworthiness Directive, to make everybody happy and punch fewer craters.
Marc Marc had the Pac in for service the minute he received word of this. I believe all that it required was changing out some of the bolts.
At Taft, we carry 17 jumpers with no one flying right seat or 16 with a right seat flyer. 8 will get the Pac in the air.
"People often say that this or that person has not yet found himself. But, the self is not something that one finds. It is something that one creates"- Thomas Szasz
