JohnRich
Used Military Sky Diver Chutes: $40!
Hey, put a new line set on one of those and you are ready to go! I wonder if they would tell you what the label on it says? Sometimes the military gets rid of gear that normal people would still call airworthy. Then there is the possibility it has some very serious subtle damage...
-- Jeff
My Skydiving History
OK I see it is just the way he is holding it
a 245 7 cell for 40. I wonder who made it. Can you use military equipment in a civialian rig? It is my understanding that while all civilian equipment is required to be TSOd, and Military equipment dosen't because it is built to different standards. Or is this irrelivant if this is used as a main canopy?
Divot your source for all things Hillbilly.
Anvil Brother 84
SCR 14192
I dunno, when 245 sq/ft of parachute opens above my head, I usually prefer a slider to soften the blow a bit... :P
"Whoever in discussion adduces authority uses not intellect but memory." - Leonardo da Vinci
A thousand words...
Wouldn't work...it needs LINES to slide down!;)
That's what he just put on to his $39.95 vintage militairy parachute as he was saying that he was "ready to go!"...
Famous last words?
"Not only did I learn to skydive on the internet, I also learned how to build my own parachute in five easy lessons..."
A thousand words...
