jumpingjimmy 0 #1 April 19, 2006 why is the a main pin curved and the reserve straight? why not have them both the same if one is a better design than the other? Quote Share this post Link to post Share on other sites
Chizazz 0 #2 April 19, 2006 Because the pins are pulled in different directions. The reserve pin is pulled parallel with your rig and the main is pulled perpendicular to it. Or so the little voices in my head tell me.... Quote Share this post Link to post Share on other sites
dragon2 2 #3 April 19, 2006 If you get a pullout system your pin IS straight. But then the pin is pulled from the side instead of from above. Try picturing a straight pin that's lying flat with a regular pilotchute pulling from above. It then has to pull the pin out at a 90o angle. If you want to try this, be my guest ciel bleu, Saskia Quote Share this post Link to post Share on other sites
councilman24 37 #4 April 19, 2006 It took a long time for the curved pin to be developed. Before that throw out pc rigs were closed in a number of ways. So had a straight pin, some used a bungie cord loop and a fold of the bridle through that to close the main. All of theses had issues with causing PC's in tow. The straight pin if pulled 90 degrees to the direction of the pin (straight up from the container) can form a lever. The end of the pin is against the pack, the pridle is pulling up on the other end, and the pin doesn't slip out of the loop. Bungie and bidle could have too much friction or knot/ball/wad up and not get pulled. The curved pin allows the pin to rotate out of the loop against the gromment even when pulled at 90 degrees. IF IT ISN'T SEATED TOO FAR!. Push your cured pin in all the way to the eye AS A TEST. Turn it down flat and hold it flat with a finger. Pull on the pin with the bridle on the opposite side from the blade of the pin. It can also jam like a straight pin when this is done. Some earlier curved pins had the eye on the inside of the circumference of the curve of the pin. This really couldn't happen as easily with them. But they were made out of wire that could corrode. Other curved pins were plated. Sometimes the plating would start to flake and the pin could catch on the bridle with the edge of the plating. The current stainless pin is nice, but I'd prefer one with the eye inside the circumference and one completely round rather than smoothed over sheet stock. Price is probably in the way of a pin like that. With pull out main deployment systems the jumper pulls the pin with the handle and extracts the PC. So they use a straight pin because the pull is in line with the pin. The direction of the pull of a reserve pin is inline with the pin itself. The placement of the ripcord housing and it being secured ensures the direction of the pull. Also most RSL have a guide ring that also directs the pull of the RSL on the cable to be in the direction of the pin. The difference is a PC pulling the curved pin at 90 degrees versus the ripcord pulling the staight pin in line.I'm old for my age. Terry Urban D-8631 FAA DPRE Quote Share this post Link to post Share on other sites
billvon 3,114 #5 April 19, 2006 >one completely round rather than smoothed over sheet stock. Remember the pins that were basically a piece of (round) wire stock welded to a washer? I always worried about that weld. But it did seem to rotate much more easily. Quote Share this post Link to post Share on other sites
Remster 30 #6 April 19, 2006 QuoteI always worried about that weld. Wasnt there a couple of mals from just that? The pin seperating from the head?Remster Quote Share this post Link to post Share on other sites
mjosparky 4 #7 April 19, 2006 QuoteIt took a long time for the curved pin to be developed. The curved pin as we know it today took about 20 minutes to design by two guys who had way more beer than the law allows in the wee hours of the morning in a parachute loft in Perris. It is made of flat stock because when it rotates up to slide out there are only 2 small points of contact with the loop making it that much easier to remove. The type that BillV mentions were copy cat versions of the original. In my opinion it is one of the 4 major improvements in sport gear in the last thirty years.My idea of a fair fight is clubbing baby seals Quote Share this post Link to post Share on other sites
councilman24 37 #8 April 19, 2006 I ment a long time after the throw out pc came out. And I didn't see a flat pin until several years after the round ones came out.I'm old for my age. Terry Urban D-8631 FAA DPRE Quote Share this post Link to post Share on other sites
jumpingjimmy 0 #9 April 19, 2006 QuoteIn my opinion it is one of the 4 major improvements in sport gear in the last thirty years. thanks for the answers, i never thought about which way the force pulling the pin could come from ! as a matter of curiosity, what are the other 3 ways ? thanks Quote Share this post Link to post Share on other sites justinb138 0 #10 April 19, 2006 I'd guess one is the 3 ring. Quote Share this post Link to post Share on other sites peckerhead 0 #11 April 19, 2006 I used to jump a classiflyer container that had four pins. Two curved on the main and two straight pins on the reserve. Quote Share this post Link to post Share on other sites mjosparky 4 #12 April 20, 2006 QuoteI'd guess one is the 3 ring. Another one is the hand deploy pilot chute.My idea of a fair fight is clubbing baby seals Quote Share this post Link to post Share on other sites sd-slider 0 #13 April 20, 2006 You just gave away the answer to one of your exit speech quiz questions.... I was getting close too!Anvil Brother #69 Sidelined with a 5mm C5-C6 herniated disk... Back2Back slammers and 40yr old fat guys don't mix! Quote Share this post Link to post Share on other sites JohnMitchell 16 #14 April 20, 2006 QuoteI used to jump a classiflyer container that had four pins. Two curved on the main and two straight pins on the reserve. Remeber that company's other rig, the Top Secret? And the top secret was that the reserve would total from time to time. Quote Share this post Link to post Share on other sites peckerhead 0 #15 April 20, 2006 The corsair was the best one. In my opinion the most comfortable rig ever made. Sniff, I still miss my corsair. The top secret was a piece of shit. Quote Share this post Link to post Share on other sites mjosparky 4 #16 April 20, 2006 QuoteYou just gave away the answer to one of your exit speech quiz questions.... I was getting close too! But do you know their names?My idea of a fair fight is clubbing baby seals Quote Share this post Link to post Share on other sites johnny1488 1 #17 April 20, 2006 What are your thoughts on the yellow cable for the main closing pin? I first saw it on a Scottish buddies tear drop. I have mulled it over for some time to try to come up with a real downside to it and Im not sure I can aside from the possibility of getting kinked, but how likely is that? I mean it seemed it would have been harder to dislodge it by accident. Any thoughts on the cable vs the curved pin? Johnny --"This ain't no book club, we're all gonna die!" Mike Rome Quote Share this post Link to post Share on other sites councilman24 37 #18 April 20, 2006 We've went through all kinds of cables. Yellow, Black, Clear, and flex pins on tandems, etc. I can't remember a throw out with a cable pin but there probably was. The yellow cable real isn't stiff enough. Most ripcord student rigs use coated cable through the loop. I haven't paid enough attention to be able to quote plastic type and cable construction and size. But its the black "stuff" It can get kinked. In some cases the plastic can strip off the cable. Remember there are only a couple of pounds of force on the cable when used for the cutaway. You can hold a three ring with two fingers, loosly. If I did it it wouldn't be yellow cutaway cable. Just too soft. But I think the stainless pin is better for a throw out. I'm not in a technical mood. I'll let others more knowledgable chim in.I'm old for my age. Terry Urban D-8631 FAA DPRE Quote Share this post Link to post Share on other sites Orange1 0 #19 April 20, 2006 QuoteWe've went through all kinds of cables. Yellow, Black, Clear, and flex pins on tandems, etc. I can't remember a throw out with a cable pin but there probably was. The yellow cable real isn't stiff enough. Most ripcord student rigs use coated cable through the loop. I haven't paid enough attention to be able to quote plastic type and cable construction and size. But its the black "stuff" It can get kinked. In some cases the plastic can strip off the cable. Remember there are only a couple of pounds of force on the cable when used for the cutaway. You can hold a three ring with two fingers, loosly. If I did it it wouldn't be yellow cutaway cable. Just too soft. Isn't this what happened here http://www.dropzone.com/fatalities/Detailed/167.shtmlSkydiving: wasting fossil fuels just for fun. Quote Share this post Link to post Share on other sites johnny1488 1 #20 April 20, 2006 The rig I saw it on was a throw out. I dont think I would pick it but I thought the idea had some merit. Johnny --"This ain't no book club, we're all gonna die!" Mike Rome Quote Share this post Link to post Share on other sites councilman24 37 #21 April 20, 2006 Yep, Don't think I saw that one. Wrong cable. Damn, too bad people have to die from things we've already figured out are wrong.I'm old for my age. Terry Urban D-8631 FAA DPRE Quote Share this post Link to post Share on other sites councilman24 37 #22 April 20, 2006 I wouldn't be too concerned about a cable pin on a pull out. Essentially a ripcord. EXCEPT SEE ABOVE. Yellow cutaway cable is the WRONG cable to use! If you see him again, give him the link above.I'm old for my age. Terry Urban D-8631 FAA DPRE Quote Share this post Link to post Share on other sites johnny1488 1 #23 April 20, 2006 I will send him that link. Johnny --"This ain't no book club, we're all gonna die!" Mike Rome Quote Share this post Link to post Share on other sites skydiverek 63 #24 April 20, 2006 QuoteWhat are your thoughts on the yellow cable for the main closing pin? Read this thread - there are 3 posts from Bill Booth there: http://www.dropzone.com/cgi-bin/forum/gforum.cgi?post=110815#110815 Quote Share this post Link to post Share on other sites ZigZagMarquis 9 #25 April 20, 2006 QuoteQuoteI'd guess one is the 3 ring. Another one is the hand deploy pilot chute. Okay, we've got the "Curved Main Pin", the "3 Ring" main release and the "Hand deployed Pilot Chute"... what's the 4th one?? Twist off beer caps??? Quote Share this post Link to post Share on other sites Prev 1 2 Next Page 1 of 2 Join the conversation You can post now and register later. If you have an account, sign in now to post with your account. Note: Your post will require moderator approval before it will be visible. Reply to this topic... × Pasted as rich text. Paste as plain text instead Only 75 emoji are allowed. × Your link has been automatically embedded. Display as a link instead × Your previous content has been restored. Clear editor × You cannot paste images directly. Upload or insert images from URL. Insert image from URL × Desktop Tablet Phone Submit Reply 0 Go To Topic Listing
