plante 0 #1 November 1, 2013 ive heard both- pull risers apart and push risers together. ive tried both methods and havnt noticed the difference. what about you guys? Quote Share this post Link to post Share on other sites
mattjw916 2 #2 November 1, 2013 harsh language and pulling apart worked fine for meNSCR-2376, SCR-15080 Quote Share this post Link to post Share on other sites
DSE 5 #3 November 1, 2013 https://vimeo.com/29103767 offers two methods. Quote Share this post Link to post Share on other sites
rwieder 0 #4 November 1, 2013 Looking at your profile, 405 jumps, USPA coach and a "C" license holder and your asking for advice on getting out of line twists? What do you tell your students when they asks you for advice on the same topic? That's just an odd question coming from such an experienced sky diver who would ask on all the world's stage. KICK OUT! If you can't kick out, cut the dang thing away. I can't imagine the injuries if you tried to ride this down. Best- Richard Quote Share this post Link to post Share on other sites
mattjw916 2 #5 November 1, 2013 I'm pretty sure he was just soliciting input... I seriously doubt he doesn't know how because he offered two methods in his post. You realize this is a discussion board right? People ask questions looking to perhaps learn something new... NSCR-2376, SCR-15080 Quote Share this post Link to post Share on other sites
yeyo 1 #6 November 1, 2013 hes not asking for advice ..he just wants to know what we think about those 2 methods...jeesuzz! ive tried both too. for me, pushing together seems to untwist faster when the twist is up in the lines. when the twists are on the risers, i pull them appart. i also kick in both methods. anyway thats my first response, if it doesnt do anything, i change HISPA #93 DS #419.5 Quote Share this post Link to post Share on other sites
Edjglass920 0 #7 November 1, 2013 My first line twist I tried to pull apart the risers while kicking to no avail so I actually used my left hand to grab the right riser which was on top, than my right hand to grab the left riser that was on bottom. I pulled apart essentially transferring the twist to the riser but it made it easier to kick as the motion helped to cause momentum. This was on my twelfth jump and I was taught in the class to just pull apart but read in the sim to transfer, so when the training didn't work well for me I changed methods. 13th jump another twist and used the transferring method and it came out quicker. Quote Share this post Link to post Share on other sites
DSE 5 #8 November 2, 2013 The "best method" is also determined by how high up the lines the twists are. If they're low/near the riser, squeezing works well. If they're high, pulling apart works better. FWIW, I don't kick any more, but YMMV. Neither of the two methods in shown in the video use kicking. Jan Meyer has some data on this somewhere, too. Quote Share this post Link to post Share on other sites
DrDom 0 #9 November 2, 2013 DSEhttps://vimeo.com/29103767 offers two methods. wow, those are pretty clever indeed. I was taught pull together and kick... knock on wood have not had to use yetYou are not the contents of your wallet. Quote Share this post Link to post Share on other sites
GAjumper84 0 #10 November 3, 2013 My first jump I opened into line twists (my fault, IAD opening on my back), I pulled apart and kicked. Worked well on 3 1/2 rounds of twists. Quote Share this post Link to post Share on other sites
skyjumpenfool 2 #11 November 3, 2013 DSE The "best method" is also determined by how high up the lines the twists are. If they're low/near the riser, squeezing works well. If they're high, pulling apart works better. ^^^This^^^ In my tool box, I have phillips screwdrivers and I have flat head screwdrivers. Also, I have a hammer. The situation is what determins the tool I reach for. The more tools in my toolbox, the more choices I have to solve a problem. Birdshit & Fools Productions "Son, only two things fall from the sky." Quote Share this post Link to post Share on other sites
monkycndo 0 #12 November 3, 2013 Plante, it also makes a difference if you are jumping your wingsuit. I have found kicking with the leg wing zipped is not nearly as effective. As long as the canopy is flying straight and not diving, my go to first choice is the second example in DSE's video. I twist the risers to get all the twist out of the lines and into the risers. You might start twisting the wrong direction, but it will be obvious if you are doing it the right or wrong way. Once the lines are clear, the risers are now a coiled spring that wants to unwind. As you can see in the video, the tops of the risers often start to separate. Put your hands where they are separated and use the risers for leverage to untwist yourself by pushing off the risers. It is remarkable how fast you can get out of a lot of twists using this method. And by the way folks, just because it is mostly guys jumping, don't assume the gender of the OP. 50 donations so far. Give it a try. You know you want to spank it Jump an Infinity Quote Share this post Link to post Share on other sites
Arvoitus 1 #13 November 4, 2013 rwiederLooking at your profile, 405 jumps, USPA coach and a "C" license holder and your asking for advice on getting out of line twists? What do you tell your students when they asks you for advice on the same topic? That's just an odd question coming from such an experienced sky diver who would ask on all the world's stage. KICK OUT! If you can't kick out, cut the dang thing away. I can't imagine the injuries if you tried to ride this down. Best- Richard Kicking isn't the only way to get out of a line twist. I only kick when I have to (the twist was down to my neck and pinned my head down and couldn't look up). Otherwise I use the other method. Once you get the twist down to the risers you don't have to do anything, it will usually untwist on its own.Your rights end where my feelings begin. Quote Share this post Link to post Share on other sites
plante 0 #14 November 25, 2013 yea no kidding! thanks dude. i was having this convo with my co worker and was looking for more opinions Quote Share this post Link to post Share on other sites
riggerrob 643 #15 November 26, 2013 DSEThe "best method" is also determined by how high up the lines the twists are. If they're low/near the riser, squeezing works well. If they're high, pulling apart works better. FWIW, I don't kick any more, but YMMV. Neither of the two methods in shown in the video use kicking. Jan Meyer has some data on this somewhere, too. ................................................................................... Riiiiight! The whole game changes when you wear a wing-suit. I found that I had to change my whole attitude towards legs ... to prevent line twists. Quote Share this post Link to post Share on other sites
riggerrob 643 #16 November 26, 2013 As for kicking technique ... I have found the best way is to swing a leg as wide - and as hard - as I can ... sort of like a capoeira leg sweep. Quote Share this post Link to post Share on other sites
