AEsco48 0
bigway 4
.Karnage Krew Gear Store
matt1215 0
We had a fair amount of horizontal separation as I was downwind of the landing area, along with the 3 other fun-jumpers who jumped before me. The 4 of us spent most our canopy flights on a long final but the tandems/video had plenty of ground for a standard approach. They looked a lot closer than that when they dumped.
Thanks
Eule 0
QuoteYou're right, there are a lot of optical effects that come into play.
I don't have that many more jumps than you, but I have noticed the same thing. I'm under canopy and everything is OK, and I look down to see if I can see my AFF instructor under canopy. For a long time, when I first caught sight of him, I _always_ thought he was just about to land, and would freak out a little - "shit, he's still over the trees!" Then I'd watch him continue to fly, and realize he was much higher up than I thought.
This probably doesn't work right around noon, but I figure like this: if my instructor really is as low as I think he is, then his shadow shouldn't be that far away from the point directly underneath him on the ground. When I've applied this idea, I've usually found that the shadow was very far away or so far away I couldn't pick it out, which means he is a lot higher than I first thought.
Eule
ChrisL 2
QuoteThanks for the info guys. You're right, there are a lot of optical effects that come into play. That was my 27th jump and my inexperienced eye can't begin to estimate distances accurately, but he looked really damn far under me. He actually did look like he was at about tree-level when he was open.
If you were at 4000ft and you could see him clearly then he was still plenty high
Keep in mind, you guys open pretty high.
I usually pull just above 3000 ft and I'm fully in the saddle at maybe 2400 or so.
Thats pretty normal and definitely not a dangerously low pull.
My mighty steed
matt1215 0
I was at more like 3400 after I dumped & did all my functionals, and his pull looked a little lower than eye-level, so I'd guess he dumped around 3k.
Peej 0
Advertisio Rodriguez / Sky
DJL 235
QuoteDo a lot of videographers die this way?
Yes. This happens all the time. That's why we switched to gingerbread men at our DZ, so we can just cook up a fresh batch.
Ok, not really. It always looks like someone is alot farther away, especially when you're looking down at them.
Quote...i fly the opening on back, then turn over, switch my camera off and dump. .
Really? Any other videographers switch their cameras off BEFORE they dump? I know I don't. [emphasis mine]
steveOrino
DJL 235
QuoteAny other videographers switch their cameras off BEFORE they dump? I know I don't.
Yes, and I also use this time to knit a sweater.
QuoteReally? Any other videographers switch their cameras off BEFORE they dump? I know I don't. [emphasis mine]
I used to do that, when I had about 500 jumps. I was editing my own stuff with just a camera and VCR. The only cut I had in my videos was after the tandem opened, I would have to pause the VCR, and then start it up when the footage of their landing began.
Anyway, I figured out if I shut the camera off right after they opened, when I was still on my back, and the next time I recorded was filming their landing, I just record the video straight through, and get my rig packed while it was dubbing.
Why anyone would do this with digital (I was shooting Hi8 at the time), or why they would do it after the flip over, and the opening shot had ended is beyond me.
My guess is that he figured out that he could do it, so he does. I grew out of it pretty quick.
Peej 0
Like i said to Steve in a PM, after looking at my tandem vids i decided that me waving off and my canopy opening wasn't the nicest thing to include on the DVD i'm handing to my customer. So now i film their opening, flip over and so long as my dytter isn't screaming that i'm super low i reach up, hit my cameye button so the camera is in standby, wave off and dump.
I've never seen anything wrong with this.
We edit with the camera and a linear board btw.
DJL 235
Or, you could wait unitl you land, dub your tape to the end of the tandem opening and use a an overlap or wipe effect on your camera.
If you really are tryng to clean up the video, you need to stop recording before you flip over.
Keep the camera rolling. You'll want to footage if soemthing goes wrong on your opening, and you can review the video, and pinpoint the problem, as opposed to just guessing. Not to mention, you should have your focus on other things down around 4k. Pulling, clearing the tnadem, traffic etc.
I hear what you're saying, and even did it myself for ahwile. I stopped. You should too.
Peej 0
DJL 235
Quotei decided that me waving off and my canopy opening wasn't the nicest thing to include on the DVD i'm handing to my customer
I disagree, I think that's a great thing to include in the DVD. It's an inside view of an opening. The more in-the-air dynamic things, the better. I slow-mo the tandem opening and then as I'm flipping over I put it back to full speed and slowly bring audio up so you can hear me yelling "Wahooo!!" as the canopy slows me down, thumbs up and end record.
I also have a very serious attitude towards breaking away from a tandem. I'm tracking away on my back AS they pull the handle. I'm not going to waste a moment fiddling with my camera. I've seen malfunctioning or snivelling tandems pairs come flying by videographers who REALLY should know better.
steveOrino
One thing to bear in mind, videographers can freefall a full 2,000ft (thats 10 seconds) after the tandem deploys and still open at what most experienced skydivers consider a perfectly normal height, 3,000ft. If this guy did open only a little bit lower than you (~4k) then he had plenty of height in the bag - even if his snivel was really long.
Why don't you talk to the camera guy about what happened, I'm sure he'd be happy to tell you what heights he pulls at/ his hard deck for ep's etc.
