bob.dino 1
Do you know if 182s use flaps on jump-run?
No, you dont use flaps on jump run in a 182. isnt 60 slow enough?
Anyone ever hear of a Minimum Equipment List?
btucker 0
I know of a PAC750 that regularly does take off's with zero flaps given a light load. Albeit that is a different kettle of fish from flying with broken flaps...
Blue Dreams Benno
Normally no, however, the IRM recommends one notch of flaps for IAD CAT A and B jumps out of C-182s to ensure the pilot chute passes under the horizontal stabilizer.
kkeenan 14
Are you saying that Piper Cubs, which do not have functioning flaps, are not safe to fly?
I think they're saying that making an off-airport, engine-out landing with a full load of jumpers aboard could be very dangerous without the use of the flaps.
Kevin
_____________________________________
Dude, you are so awesome...
Can I be on your ash jump ?
A Cub drags its tail around, and stalls at about 35 m/h... which makes it an entirely different case altogether.
kallend 2,196
QuoteQuote
Kevin
It could be very dangerous with the full use of flaps too. Off airport engine-out landings at full gross are generally dangerous.
Flaps on a C182 reduce stall speed from 62kt to 54kt, so while an off-landing at 54kt is preferable to 62kt, it is still no guarantee of survival.
riggerrob 644
That all depends upon the type of aircraft and length of runway.
A Cessna 182 with a long runway is not a big deal. I would only operate a flap-less Cessna for a day two until parts and shop time were available.
At the other end of the scale, a King Air might not be able to take off from a short runway without flaps.
If the runway is very long there is no added risk for any phase of the flight EXCEPT if the pilot is suddenly faced with an engine failure and has to land the plane in a paddock etc.
In the unlikely event of being on-board an aircraft and having to make a forced landing without power I sure as hell would be wishing the pilot had working flaps to lower the stall speed (Vs) and lower the approach and landing speeds if that paddock just isn't quiet long enough.
Dave Cogan
Dave Cogan
I'll go with MOSTLY NO, but maybe sometimes yes.
If the aircraft is designed for flight without flaps and the runway is appropriate for that type of flight, then it should be OK to not use working flaps. Legally, for commercial operations, any installed equipment must be operational, so in most cases involving skydiving with broken flaps I'd say 'no flaps' should be a 'no fly.'
You specify a 182. In that case, if you were flying at a mega airport it wouldn't be a big deal to not use the flaps from a safety standpoint, but if they were inop, it probably wouldn't be legal.
Now, a 182 at a standard small skydiving airport...flaps should be operational, and should almost always be used. In some cases a pilot may elect not to use the flaps, and that's not always a big deal, but if they aren't working, I'd stay out of the airplane. In most cases skydiving 182's are being operated at near maximum gross weight, from small runways, with less than ideal temperatures and winds. That all adds risk, so flaps should be in working order.
If the DZO or pilot told you the flaps were broken, but continued to conduct skydiving operations anyway, I'd say you should find a new pilot or a new drop zone.
Instructor Emeritus
Comm Pilot MSEL,G
Author: JUMP! Skydiving Made Fun and Easy
