2shay 0 #1 February 9, 2007 awesome idea but worried bout bungie in the middle curious how thats goona turn out. by the way jump bils gear and love it all let me knowdon't try your bullshit with me!!! Quote Share this post Link to post Share on other sites
DSE 5 #2 February 9, 2007 This is already being discussed at length in the Gear and Rigging forum sticky thread Ironically or at least differently, JumpShack has a new, much thinner and stronger steel cable ripcord that is very soft and pliable, but doesn't kink, and allows for significantly smaller diameter housings. Quote Share this post Link to post Share on other sites
billbooth 10 #3 February 10, 2007 While the particular design of my Retractable Reserve Ripcord is new, the materials used (Spectra, bungee cord, and stainless steel housing) are identical to those used in my Sigma main ripcord, which has been in use in thousands of Sigmas for over 6 years now. Plus, all RWS RSL's have been Spectra for around 10 years now. I think the materials and basic design have been very well tested indeed. Quote Share this post Link to post Share on other sites
2shay 0 #4 February 10, 2007 thanks billdon't try your bullshit with me!!! Quote Share this post Link to post Share on other sites
sundevil777 102 #5 February 10, 2007 How much stronger is your reserve pin than the standard? I can't understand why the wimpy standard pin hasn't been made obsolete. I think they shouldn't bend even if you lean against something (such as a narrow frame of an airplane structure) really hard. I think jumpers would be willing to pay a lot more for that, if marketed properly.People are sick and tired of being told that ordinary and decent people are fed up in this country with being sick and tired. I’m certainly not, and I’m sick and tired of being told that I am Quote Share this post Link to post Share on other sites
sundevil777 102 #6 February 10, 2007 Did you consider whether the bungee feeling might turn off some people, just because it might convey a feeling of being not 'solid'?People are sick and tired of being told that ordinary and decent people are fed up in this country with being sick and tired. I’m certainly not, and I’m sick and tired of being told that I am Quote Share this post Link to post Share on other sites
billbooth 10 #7 February 10, 2007 QuoteDid you consider whether the bungee feeling might turn off some people, just because it might convey a feeling of being not 'solid'? All ripcords have slack. The "bungee feeling" of my new recoil ripcord goes away after you pull it just 3-4". It is then just as solid as steel, and comes completely out of the housing. Quote Share this post Link to post Share on other sites
IanHarrop 43 #8 February 10, 2007 I couldn't tell from the video what the "pin" end of the ripcord is like so I could have a good understand of how the pin is attached. Is it possible to get a picture of it? Thanks, Ian"Where troubles melt like lemon drops, away above the chimney tops, that's where you'll find me" Dorothy Quote Share this post Link to post Share on other sites
RMURRAY 1 #9 February 10, 2007 QuoteWhile the particular design of my Retractable Reserve Ripcord is new, the materials used (Spectra, bungee cord, and stainless steel housing) are identical to those used in my Sigma main ripcord, which has been in use in thousands of Sigmas for over 6 years now. Plus, all RWS RSL's have been Spectra for around 10 years now. I think the materials and basic design have been very well tested indeed. like it. lighter, cheaper and durable. is it patented and exclusive to RWS (or new name)? rm Quote Share this post Link to post Share on other sites
PhreeZone 20 #10 February 10, 2007 Since it uses the pins that are exclusive to the UPT/RWS design I'd be really surprised to see anyone else using them.Yesterday is history And tomorrow is a mystery Parachutemanuals.com Quote Share this post Link to post Share on other sites
3331 137 #11 February 10, 2007 Quote Ironically or at least differently, JumpShack has a new, much thinner and stronger steel cable ripcord that is very soft and pliable, but doesn't kink, and allows for significantly smaller diameter housings. Jump Shack Ripcords http://www.jcometals.com/ Parachute Laboratories, Inc. Deland Florida email: ripcords@jumpshack.comI Jumped with the guys who invented Skydiving. Quote Share this post Link to post Share on other sites
billbooth 10 #12 February 10, 2007 QuoteI couldn't tell from the video what the "pin" end of the ripcord is like so I could have a good understand of how the pin is attached. Is it possible to get a picture of it? Thanks, Ian The pin is the same one we've been using for the past 15 years. It looks something like a standard hand deploy pilot chute curved pin. It is stamped out of a solid plate of stainless steel...no joints. The new ripcord simply loops over it. There must be a picture of it on the UPTVector web site somewhere. Quote Share this post Link to post Share on other sites
mark 107 #13 February 11, 2007 QuoteThere must be a picture of [the curved reserve pin] on the UPTVector web site somewhere. The Sigma manual (pdf , 3.5Mb) has a few pictures. Page 22 shows an uninstalled RSL; pages 24 and 32 show what it looks like installed. Mark Quote Share this post Link to post Share on other sites
skydiverek 63 #14 February 12, 2007 Quotelike it. lighter, cheaper and durable. Plus, you will be pulling a reserve pin from the running start, because of the "slack", similar as in the standard reserve cable. So that functionality is retained, with the advantage that the "slack" is not dangling below inside the reserve handle (read: end of cable with a ball). Also, on the slack issie, from Bill Booth in 2004: "I have learned that if you pull "quickly", from a "running start" (slack in the cable), the pull force necessary to open the same reserve container is up to 300% lower than if you apply the force gradually to the handle. Most riggers only have a spring loaded fish scale, and therefore must apply pull forces gradually in order to read the scale. So, what reads 30 pounds on the fish scale in the loft, will only be around 10 pounds when you actually pull your reserve in an emergency, because I don't know of anyone who applies ripcord pull force "gradually" while falling rapidly toward the earth." Quote Share this post Link to post Share on other sites
NewGuy2005 53 #15 February 12, 2007 Hi Bill, Is it nerve-racking to put your work in front of thousands of critics, and nay-sayers and set back and wait for the questions? Here's my try: What if the reserve handle end of the bungee becomes detached? Will the bungee bunch up in the "housing" and bind the rip-cord? Thanks, Ken Quote Share this post Link to post Share on other sites
mark 107 #16 February 12, 2007 QuoteWhat if the reserve handle end of the bungee becomes detached? Will the bungee bunch up in the "housing" and bind the rip-cord? The ripcord is made from braided line like your suspension lines, not metal aircraft cable like most other ripcords. The bungee is fingertrapped and bartacked inside the braided line. In the unlikely event that one of the bartacks failed, the strength of the ripcord would be unaffected. Mark Quote Share this post Link to post Share on other sites
NewGuy2005 53 #17 February 12, 2007 QuoteQuoteWhat if the reserve handle end of the bungee becomes detached? Will the bungee bunch up in the "housing" and bind the rip-cord? The ripcord is made from braided line like your suspension lines, not metal aircraft cable like most other ripcords. The bungee is fingertrapped and bartacked inside the braided line. In the unlikely event that one of the bartacks failed, the strength of the ripcord would be unaffected. Mark Right, however, not concerned about the ripcord strength. Wondering more about the detached bungee interfering with the movement of the ripcord. Quote Share this post Link to post Share on other sites
airtwardo 7 #18 February 12, 2007 http://www.dropzone.com/cgi-bin/forum/gforum.cgi?do=post_attachment;postatt_id=79424; See pic, the 'fatter' part of the blue line is the bungee section... The elastic bungee in internal to the braided line, it can't become detached. It could however become less 'bungee' I guess, still wouldn't effect the strength. ... but then again, Bill made the comment that it was still up to par after 100,000 'stretches'... AND as said above, the current housing configuration could be done away with altogether, going with a soft 'housing' or channel that the RC would be in. ~ If you choke a Smurf, what color does it turn? ~ Quote Share this post Link to post Share on other sites
NewGuy2005 53 #19 February 12, 2007 Quotehttp://www.dropzone.com/cgi-bin/forum/gforum.cgi?do=post_attachment;postatt_id=79424; See pic, the 'fatter' part of the blue line is the bungee section... The elastic bungee in internal to the braided line, it can't become detached. . I see, Thanks. Quote Share this post Link to post Share on other sites
