Zeppo 0
QuoteMaybe not entirely. Some people have reported that it felt like they left in a curve rather than a straight line. I think that's mainly a matter of desorientation, which is physiology rather than physics.
But I do believe we're on the right track: the jumper's body moves in a straight line but might still be rotating around itself.
Thanks,
Alphons
It could also be possible that they are curving, depending of their speed and their body position to the relative wind. If they're going fast enough, then the wind will definitely have an affect on their trajectory.
fonz 0
But I'll have a look at it.
Alphons
-- The Hitchhiker's Guide to the Galaxy
fonz 0
QuoteIt could also be possible that they are curving, depending of their speed and their body position to the relative wind.
I think you're right. But I also wouldn't want to rule out the possibility that desorientation merely makes you think you're carving when you're not. Or that you try to fly straight, but your brain is temporarily confused about what is straight.
I think that both theories (body position plus wind versus the brain stuff) can apply. Possibly even at the same time.
Alphons
Nutz 0
"Don't! Get! Eliminated!"
spoons 0
Quotewith a good arch and no rsl no problem - but with a rsl will definately have line twists on the reserve
I don't think definitely, but maybe it is more likely...I know of people who have not had twists (even when jumping smaller and more highly loaded mains [and reserves]).
I guess a lot depends on body position on deployment (of reserve).
DJL 235
Furthey Hypothesis:
You'll probably spin into your reserve lines because of the mechanics of where the lines are attached.
spoons 0
wmw999 2,587
Not necessarily. I've cut away two spinners, with an RSL, and haven't had line twists on my reserve.Quotewith a good arch and no rsl no problem - but with a rsl will definately have line twists on the reserve
Wendy W.
DJL 235
dragon2 2
QuoteNot necessarily. I've cut away two spinners, with an RSL, and haven't had line twists on my reserve.Quotewith a good arch and no rsl no problem - but with a rsl will definately have line twists on the reserve
Wendy W.
Ditto.
ciel bleu,
Saskia
Gene03 0
The force which to make a rotating body move away from the center of rotation: it is due to inertia.
Think centrifuge.
Centripetal force;
The force tending to make rotating bodies move towards the center of rotation.
(From the Webster's New Universal Unabridged Dictionary, Second Edition)
Visualize this example.
A common ceiling fan in a large room free of obstacles.
Secure a, let's say, one foot length of fishing line to the end of one of the fan blades.
Attach a fishing weight to the free end of the line.
Turn on the fan and observe.
What will happen to the weight?
Same fan, same weight (mass), but lengthen the fishing line to 5-6 feet in length.
Turn on fan and again observe.
What will happen to the weight this time?
Wiki defines centrifugal force as a fictitious force.
How can it be fictitious if it is observable and repeatable?
Maybe I'm confusing common, everyday use with the pure science?
Stanislaw Jerzy Lec quotes (Polish writer, poet and satirist 1906-1966)
The111 1
QuoteWiki defines centrifugal force as a fictitious force.
Because the definition of fictitious force is not "unobservable and unrepeatable."
billvon 3,114
It's not just due to inertia; it IS inertia. What we call centrifugal force is inertia in a spinning system. It's not a separate force.
Question is: if you have a violently spinning mal on the main, will you stop spinning once you have cut it away (cleanly, no hangups)?
Yes.
My educated guess is that you'll get slingshot away in a straight line (the canopy no longer pulls you in a circular motion and you leave along the tangent) but depending on the situation your body itself might still be rotating.
You're going to go in a straight line, in whatever orientation you were during the spin, and may get a little angular velocity from the risers not releasing at the same time or aerodynamic forces.
Pulse 0
No....as was stated, the center of mass would travel in a straight line. But the jumper's body may spin, it may stabilize. But that's a different matter.
The fact that jumper's may feel they are falling away in a 'curve' would have more to do with their instability and possibly inner-ear workings. The fact is, at that moment they are not in the best situation to truly realize what kind of trajectory they have.
I suppose it would be plausible that the jumper's body position could fling them into a curve. But think about it. The conditions would have to be sooooo perfect that I doubt it would ever happen. The aerodynamic forces from the jumper's body would have to cause enough force to offset the momentum causing him to go in a straight line.
I don't know if I'm clear about what I'm saying. But no, the jumper may spin. But his trajectory, when viewed from above, will be in a straight line.
Gene03 0
I read that Wiki site 3 times and still couldn't get my apes' brain around it.
Back to my other post, what would happen to the weight on the long line?
Gene03 0
D22369 0
Roy
Even though it has some impressive math to a moron like me, I wouldn't trust it for answers on a college final.
