countzero
jumping with paper
sometime ago i saw post that suggested jumping with a piece of paper or plastic streamer material as a tool to work on fall rate and proximity while on a solo jump.
what kind of paper or streamer material is used?
what size and shape should it be?
any other tips on using this method to work on fall rate and proximity would also be greatly appreciated.
diamonds are a dawgs best friend
Paper streamer can be good only under canopy. reply]
guess i misunderstood, and thought it could be used in freefall.
what skill exercises can be done with paper under canopy?
I'm sorry you can not fall as fast/slow any paper thing can.
There is a thing called skyball, a tennis ball sized of thing filled with lead. You can tune that with your freefall speed. The bad news is that you might not be allowed to use it everywhere.
You might train your canopy/CRW skill with a paper streamer under canopy.
NOTE:
The explanation he gave isn't really thourough enough. At your jump numbers and assumed skill level countzero you will not be allowed to use a skyball ANYWHERE not even on your belly (they are mostly used in freeflying). Do not attempt to make or use one, it is not safe for the people on the ground.
~D
That was for canopy work. Here is the link if you are interested. http://www.pcprg.com/swoopstreamer.htm
