Mike111 0 #1 April 16, 2007 It says the minimum opening height for A licence jumpers and above is 2000ft. does that mean you have to open and be under canopy by then or is that the lowest you can pull ur PC? Thanks!!! edit - not that i plan on opening that low, just curious as to the meaning o the wording. (normal pull alti is 3-3.5k) Quote Share this post Link to post Share on other sites
Yossarian 0 #2 April 17, 2007 i was always told it meant you needed an open container by then Quote Share this post Link to post Share on other sites
evilivan 0 #3 April 17, 2007 Always used to refer to "pack opening height", but not sure if that has been clarified over the years (sounds like not)."If you can keep your head when all around you have lost theirs, then you probably haven't understood the seriousness of the situation." David Brent Quote Share this post Link to post Share on other sites
Pendragon 1 #4 April 18, 2007 You need to have a flying canopy above your head by 2,000 ft in accordance with BPA rules. For most people, that means pulling by 2,700 - 3,000ft at the latest, depending on canopy. USPA defines it differently, and gives pull altitudes. I recall this is 2,000 ft for D licence holders! -- BASE #1182 Muff #3573 PFI #52; UK WSI #13 Quote Share this post Link to post Share on other sites
Mike111 0 #5 April 18, 2007 ahhh thts 2300 for meopens faster than i can say it. ahh well 3k is my normal height. Quote Share this post Link to post Share on other sites
riggerrob 644 #6 April 18, 2007 USPA rules say that a D-license holder - like me - only has to show a pilot chute above 2,000 feet. Fortunately low pulls have fallen out of fashion. These days, I criticize myself if I am not sitting in the saddle by 2,500'. Quote Share this post Link to post Share on other sites
schuey87 0 #7 April 18, 2007 I thought it meant you have to have an open canopy above your head by 2000ft. If the CCI thinks you've pulled low, and asks to see your protrack if you have one, I always thought if it was under 2k you were in trouble... and I thought protracks register deployment altitude when you have a pretty much inflated canopy above your head... Quote Share this post Link to post Share on other sites
Pendragon 1 #8 April 19, 2007 Read the thread... different countries, different rules!-- BASE #1182 Muff #3573 PFI #52; UK WSI #13 Quote Share this post Link to post Share on other sites
jakee 1,634 #9 April 19, 2007 Quote USPA defines it differently, and gives pull altitudes. I recall this is 2,000 ft for D licence holders! [Shocked] Which squares pretty well with the BPA minimum opening height for demo jumps - 1500ft (and you can do that with a C-licence)Do you want to have an ideagasm? Quote Share this post Link to post Share on other sites
Dazzle 0 #10 April 19, 2007 Quote Quote USPA defines it differently, and gives pull altitudes. I recall this is 2,000 ft for D licence holders! [Shocked] Which squares pretty well with the BPA minimum opening height for demo jumps - 1500ft (and you can do that with a C-licence) BPA C license = 500 jumps USPA D = 500 jumps (and a bunch of other things that BPA doesn't require) Quote Share this post Link to post Share on other sites
jakee 1,634 #11 April 19, 2007 Quote BPA C license = 500 jumps Bzzzzt. How did I get one then?Do you want to have an ideagasm? Quote Share this post Link to post Share on other sites
jamie_smoove 0 #12 April 19, 2007 Quote2. FAI (BRITISH STANDARD) CERTIFICATE (RED) 2.1. FAI ‘A’ CERTIFICATE: Category 8 and at least ‘CH-Grade 1’. 2.2. FAI ‘B’ CERTIFICATE: FAI ‘A’ Certificate, 50 descents and at least ‘CH- Grade 2 and JM-Grade 1’. 2.3. FAI ‘C’ CERTIFICATE: FAI ‘B’ Certificate, 200 descents and at least one further ‘Grade 1’. 2.4. FAI ‘D’ CERTIFICATE: FAI ‘C’ Certificate, and 1000 descents From BPA ops manual Section 2 Paragraph 2 C licence inly 200 jumps! Quote Share this post Link to post Share on other sites
shropshire 0 #13 April 19, 2007 snap.... same way as I did? Blue is the proper colour for a license (.)Y(.) Chivalry is not dead; it only sleeps for want of work to do. - Jerome K Jerome Quote Share this post Link to post Share on other sites
jakee 1,634 #14 April 19, 2007 Quote snap.... same way as I did? Blue is the proper colour for a license Hell no, I'm a youngun! I got mine last weekI was just pointing out to Dazzle that C-licence is 200 jumps, not 500.Do you want to have an ideagasm? Quote Share this post Link to post Share on other sites
