Rdutch
Why Canopy collisions happen
Canopy collisions happen when two or more people are attempting to land at the same time, near the same place, or lets call it the same landing window. While everyone after opening is trying to land, the time to final is the time I’m mentioning.
Skydivers attempting a straight in landing turn to final the lowest, and remain in final the longest this creates a window from a low altitude for a long amount of time, canopy size also has a great factor in this window. Pilots doing high performance landings turn a lot higher and remain in final the least amount of time; canopy size has a minor factor in this. Another factor in this is turn degree, a larger turn degree means a higher altitude, and this creates a window of greater altitude and a small amount of time. When you mix these windows (with the same desired landing area) the risk of a canopy collision increases.
How do you avoid crossing these windows? One way to do this is with similar groups, canopy size dictates exit order, i.e.: two 4way teams, one with sub 100 canopies, and the other with 135's. Obviously the sub 100-canopy team should exit first. On bigger groups this gets more difficult, but not necessarily. The old standard is that a 10 way exits before a 4 way because a 10 way takes more time to climb out. While this is a good idea it isn’t cast in stone. It is much safer to have a 4way team that is all jumping tiny canopies and performing high performance landings exit first, instead of exiting after and finding themselves in the middle of a landing pattern of 10 big canopies that intend to do straight in landings. Of course when using this method exit order = landing order, it should be this way with any scenario.
Close calls under canopy happen all the time, they happen with low time jumpers as well as experienced jumpers, they happen with pilots attempting straight in landings as well as high performance landings.
What is the cause: Failure to provide adequate separation under canopy! Today’s canopies perform better than they have ever before; the range of descent is adjustable by the pilot in extreme ranges, from flying in full brakes, regular flight, and spiraling down. What is lacking is EDUCATION in the range that a canopy has available, and how to provide adequate separation under canopy. How often do you see an entire load land in under a minute? With the time from group separation before exit, and the time it takes to fly under canopy to your landing, there is plenty of time to figure out a flight plan and clear your air for landing. The most annoying thing is when you find your slot for landing and someone from above spirals down under you and cuts into your landing window, by the time you reach 1500 ft you should be near or in your pattern and have figured out who you are landing after. Lack of this standard can be traced back from AFF where you are taught how to fly a pattern and flare. Proper procedures can be added to AFF to address your entire canopy flight. It happens in pilot training and should happen in skydiving.
Large group formations are another instance of this problem, in this instance I fully agree on a rule on landing. If you do 270-degree turns on a 30 way, into the regular landing area, you’re an idiot. But safety in big ways isn’t only limited to big turns. Racing each other to the ground is something that happens regularly in big way formations. Now I’m not saying that people are actually in a race to see who can get to the ground first (but it does happen, there is always someone that has to boast "I always land first"), I’m talking about the strange desire for everyone on a big way to rush to the ground and land at the same time at the same spot, and usually in many different directions. I personally would be under brakes letting everyone jihad each other and find some nice clear airspace to land in, even with my sub 100 canopy.
A great idea on big ways is to establish a landing order. The jumpers with the smallest canopies land first, and in return the jumpers with the largest canopies land last, it’s never good to spiral down with a big canopy into the landing traffic and try and find a slot. Just as it isn’t very smart to exit late in the pas and spiral down and pass everyone that exited before and is lower than you, regardless of the canopy size you jump and especially if you wish to do a big turn. It just takes a few minutes to figure out a landing order during the dirt dive, and very easy to enforce, and set a hard deck for spiraling.
Proper separation, and finding a slot in the landing pattern can work; I’ve seen it work for years. It just takes cooperation from everyone.
Experienced High performance canopy pilots typically use this approach, and competitive canopy pilots have to use this approach, land out of your exit order and you get a 0! Most of the time under canopy the "Swoopers" line up above and behind somewhere in your pattern and wait until the person below has initiated his turn and is clear before starting theirs. This includes the swoopers that are doing hop and pop's or landing from a fun jump. Exit order is usually selected by canopy size, and you would be surprised at how much separation there is with 5 jumpers on a pass.
Now we all know that sometimes pilots that perform high performance landings will have to get out in the back of the plane, maybe because their dropzone has a freeflyers exit after belly flyer rule, or they are performing a wingsuit jump. If you wish to do a high performance landing it is your responsibility to either pull high enough to allow the traffic after you to land, or do your swoop somewhere else. It’s a trade off for safety, if you have to swoop, then you have to pull higher. Want more freefall, then don’t swoop. And of course once open, ride your brakes! You need to use your judgment to decide when it is safe to swoop and when it is not. High performance landings can be safe but doing them in a crowd is just a bad idea.
Turn debate: there is a debate that turns are safer or more dangerous, in reality there isn’t much difference between a 180 or a 270. Your still flying blind until you reach your desired heading, the only difference and possibly what makes a 270 safer is you have a good view of where your going to go, your looking at your final heading before you even start your turn, and a great view of your left and right of your flight path. With a 180 you’re doing a blind turn where your heading is directly behind you. Also 270 turns are usually carving turns and you’re leading with your eyes, so you have a greater chance of seeing any traffic and with the carving turn a greater chance of avoiding it. I know you can do a 180 carving turn, but that isn’t the normal case. Flying a good landing pattern greatly decreases the risk in doing a turn landing, this gives you a good view who or what is around you, if someone is below you or inside your pattern while flying your pattern and you cant see they are clear of you before your turn, don’t do a high performance landing. If you are set up for a 270 its fairly easy to just do a 90 turn onto your heading.
Swoopers and fun jumpers can share the air together; it just takes a little time, education and willingness.
Ray
Small and fast what every girl dreams of!
One of the major problems with a 270 is that you are flying away from the pattern during the execution of the turn. If someone is flying below and behind you on a similar canopy with the intention of making a 90 degree turn to final, they are very hard to see, and they are in a perfect position to get blindsided by you when making the 270.
When doing a 180 there is no analogue to the massive blind spot that is unavoidable with a 270 or greater. In a hard turn, the canopy can block your view of an important sector of sky, but it is possible to clear your airspace much more effectively in advance (assuming you can locate all traffic of concern - not always as easy as it would seem).
The bottom line is that I can keep a visual on the target at all times while doing a 180, though I don't recommend a 180 in traffic. With a 270, you would be hard pressed to keep a visual with your eventual direction of flight if you had a neck like Linda Blair in the Exorcist. While 180s are bad news in traffic, 270s are an order of magnitude worse.
Not a chance in hell. Swoopers and fun jumpers should have clearly defined - and entirely separate - airspace. Sharing the air together was, is and will be a recipe for disaster.
Blue skies,
Winsor
Rdutch you have way more jumps and experience so my questions are out of pure curiosity.
1. What about two 4 way teams with mixed canopies on each team. Which team goes first?
2. Would wingloadings play into this more than canopy size? Say someone on a 150 loaded at 2:1 compared to someone on a 119 loaded at 1.4:1.
Just curious.
"You start off your skydiving career with a bag full of luck and an empty bag of experience. The trick is to fill the bag of experience up before your bag of luck runs out."
Just curious.
communication between teams is the answer
Dave
http://www.skyjunky.com
CSpenceFLY - I can't believe the number of people willing to bet their life on someone else doing the right thing.
I absolutely guarentee you that you are not able to watch for the traffic you are flying directly TOWARDS for a 180 and perform your turn safely. Most, if not all, pilots will be focusing on the ground since that's where the perceived (and rightly so) danger is.
A 180 will never, ever be any less dangerous than a 270 with regards to traffic.
Blues,
Ian
Performance Designs Factory Team
Blues,
Ian
"Directly towards" at which part of the turn? You are going a different direction at the beginning and the finish.
A 180 and a 270 have similar issues with regard to increased danger, but a 270 has the added problem of being an OUTSIDE turn. A 180 is an INSIDE turn.
From the standpoint of safety (or lack thereof) in the pattern, both suck, but a 270 is more dangerous by virtue of having much more significant blind spots (you have your back to traffic while executing the maneuver).
Blue skies,
Winsor
with similar groups, canopy size dictates exit order, [instead of group size]
Completely agree. Similar group mean fall rate categories - 'between' fall rate categories drift still trumps.
EDUCATION ......Proper procedures can be added to AFF to address your entire canopy flight. It happens in pilot training and should happen in skydiving.
Just about turned off from seeing all caps on the mantra. No kidding (glad I didn't, the whole post is nicely written). But in training early in the process is a great idea. Drift, canopy flight, etc - how to get along with others on the load is missing I think.
{big groups, have a landing order} The jumpers with the smallest canopies land first, and in return the jumpers with the largest canopies land last,
Important, if you are tagged to get down first, PLEASE get down and out of the way. Sitting in the bottom of the stack and then holding half brakes just stacks up everybody above you and tempts them to go ahead and take that big ol' 100 ft hole you have below you. I really hate this, if you make a big deal about getting out first because your (my) canopy is smaller, then get the hell down.
I really hate seeing this all the time. EVERY discipline has high performance pilots.
It's VERY frustrating to see staff AFF and Cameramen (out last) spiraling down through traffic and swooping through others and cutting next to the wuffos. How do we eliminate that bad example?
actually I see this, but there's a lot of assumptions hidden in the background of the comments about how people do 180's that I think are wrong. Even if using the same techniques (carve it, etc) I still think that a 270 gives a better ability to setup right before the hook. Still, depends on the individual so there'll always be some nonsense.
One thing to the naysayers - If you are BEHIND someone in the pattern, then you should be ABOVE and BEHIND. So if they do a front riser 270 onto final, you should be completely safe (unless YOU choose to crank your 90 before he makes his move and cause the intersect). If you are below him, he should be able to see you 90 or 180 or 270......
I still think that separate landing areas is best if a DZ has the real estate. And that the high speed should be away from the wuffos for the safety of the wuffos in the event a landing goes bad. But, whatever type of landing the DZOs do, that's what will be near the hanger.....
Driving is a one dimensional activity - a monkey can do it - being proud of your driving abilities is like being proud of being able to put on pants
Here's the diagrams I use when teaching. They clearly show just how instrusive (more so than ANY other type of turn) a 180 is.
http://www.dropzone.com/cgi-bin/forum/gforum.cgi?post=2835281;#2835281
I'm not sure I got that from the pictures. Could you elaborate?
Also, why does the 270 illustration show the maneuver taking up virtually no space at all, while the 180 looks like a broad sweeping parabola?
www.WingsuitPhotos.com
Also, I think a more realistic illustration would show that a "mass" pattern (flown by many parachutes) will be regions rather than lines, since not everybody flies the exact same 3 legs. Looking at it this way, you get a different picture. See attachment. Realistically the "regions" can be much wider.
The truth is anybody can draw a picture to illustrate a point in theory, but in real life, at the DZ, it is always more chaotic. There is always a new jumper flying the wrong way. Hell, I usually see 25% of the load flying the wrong way or landing crosswind depending where I am. No matter how great of a swooper you are, common sense dictates that the higher degree of turn you do:
1) The faster you go
2) The more you have to be aware of (due to the rapid change in direction and accordingly your blind spot)
Both of these things make it harder to avoid an unexpected canopy in your path, and again no matter how good you are, there will someday be an unexpected canopy in your path (especially on twin turbine loads when 20 people are under canopy at once).
I am not saying 180's aren't without their risks, but I can see where they would be preferable to 270's. It's the same reason we tell students not to do S-turns in the pattern. Collisions aren't as likely when you're going straight; they are more likely when you're turning. Car crashes usually happen at intersections. More turns = more collisions. Larger turn is analagous to more turns.
I'm sure many swoopers are capable of doing 270 degree turns in traffic, just like I'm capable of driving 100 mph in traffic down the highway. I will get ticketed for going over the chosen limit of 70 mph though, regardless of my ability or my opinion. And if I am totally honest with myself I'll admit that 70 mph is safer, for that one day when the car in front of me changes lanes unexpectedly.
The original post already apologizes for the quality of the drawings. The intent is, and clearly so, to depict how intrusive the 180 pattern is. Compress the turn and overlay it with ALL the other turn types and you'll see it in no way conforms to the downwind, base and final paradigm.
edit: Once again I'm NOT arguing for doing 270's in traffic, but rather that the notion of 180's being safer iin traffic is absurd.
Blues,
Ian
If you want to know why canopy collisions happen, you could always ASK those who have been involved (and survived), rather than speculating.
Ray has jumped, for a number of years, at some of the busiest DZ's in the USA. I wouldn't discount his thoughts simply because he hasn't been in a collision. He's an experienced skydiver who's seen and done a lot.
Ian
A few years ago, at WFFC, I was in the spectator landing area. I saw 5 people landing into the wind (90 degrees to the fence) and one hotdog doing a 90 and running parallel to the fence.
When I mentioned it to the showoff that he was being unsafe, his response was, "I looked before I did it."
My response was, "You don't kill people that you see." (Also, "Do it again and you can leave.")
That sums it up for me.
Some of the accidents that I have seen were caused by clueless, new jumpers who flew across the pattern into the side of someone.
The other part were arrogant "I've got Mad Skillz" showoffs.
The pattern and the rules are there for everyones safety. Just because someone has done 2,000 stellar landings, does not mean that they can do whatever they wish.
Arrogance has caused more collisions than stupidity.
Please explain to me how this would even remotely apply to say the most recent canopy collision, where someone with more experience than even you hooked into a crowded LZ and killed someone? Seriously, lay out the scenario on that fateful day in Dublin. The bigway, the camera flyers, a solo, some small canopies, some large canopies... What would the order be.
A dry run, using your theory, that would have saved a life. Please explain it to me.
Because its obvious at least in that scenario, in all probability no hp landings in the main LZ would have saved (most likely) a life, Bobs life.
You see Ray, to most of us this is tangible, something a DZO can do to actively make a difference. Ray Im not here to argue with you, frankly I don't care, personally most of the time unless the main landing area is empty I land in the student area and ride in the truck and this applies to Perris and Deland (two DZ's Ive jumped at in the last year) You see I understand your theory it just doesnt apply to all scenarios, whereas no hp landings in the main area does.
Ian
Roger Nelson had seen and done a lot more.
Agreed on Roger Nelson.
However, as usual (lately), your post doesn't seem to offer anything more than a shot at someone. Seems rather usual for someone who has contributed a lot to other subjects (such as freefall drift and exit seperation).
Is there any reason you intentionally make quips to posters on this subject. Your intent, for whatever reason, appears to be to discount or discredit Ray's thoughts? Maybe I'm just reading into, or mistaking the meaning behind your post(s), in which case I apologize for misunderstanding them.
Ian
I'm on your side, but he did talk about big ways and some of the content was very good. Go back and read the following paragraph starting with "Large group formations are another instance of this problem, in this instance I fully agree on a rule on landing. If you do 270-degree turns on a 30 way, into the regular landing area, you’re an idiot."
There's some good to take from it, and some to reject, but the discussion is worthwhile still.
don't you mean 1000 ft hole?
Why yes, I did.
fine then, try to be more accurate next time
Ian
Let's see.
John and I each have thousands of hours flying airplanes.
John and I each have thousands of skydives.
John and I have experienced canopy collisions and survived.
John and I have advanced technical degrees and have made a living teaching Physics.
John and I have taken the time to analyze the Physics of canopy collision.
There is some merit to raw experience, but it has a limit. If experience was the only yardstick that mattered, a great-grandma who has been driving since she was 16 would be a better driver than Jeff Gordon.
Thus, when someone cites their "experience" to me as credentials regarding a physics issue, it is often like being a Nutrition Physiology researcher trying to decide whether to engage in a discussion with someone who holds the record for eating McDonalds hamburgers.
One of the problems in this sport is that ignorance can kill, and ignorance is often bolstered by arrogance (trust me, I know from arrogance).
What we are trying to do is establish parameters whereby canopy collisions are not quite as inevitable as they now are. Just because you don't die most of the time, the free-for-all approach is not quite optimal.
Insanity is sometimes defined as doing the same thing and expecting different results. We are somehow expecting things to work differently with parachutes than airplanes, and the lessons were learned in airplanes a long, long time ago.
I have landed an airliner right after a Cessna Skyhawk, and have landed a Cherokee ahead of a MiG, with no problems. Landing disparate types is no great feat, but there are ways to approach it that routinely result in disaster.
I can land one of my cross-braced Class VI canopies among students under Mantas with no problem. If, however, I insist on doing a High Performance Landing because I am under a High Performance Canopy, all bets are off.
If someone chooses to put forth an argument that is devoid of merit, one must decide quite how much time to waste addressing the fallacies contained therein. When they put forth a "solution" that has been tried and found wanting every time, it does not warrant a lot of discussion in and of itself. Giving someone credit for being able to figure out the fundamentals is often unjustified.
Blue skies,
Winsor
Blue skies,
Winsor
Well written and well thought out.
People will pick this apart and try to discredit the post.
Education IS the answer...nothing can replace experience but you can arm yourself with as much knowledge as possible.
People...read the post...take away from it what you want and leave the rest.
Regardless....we as sky-divers will continue to die...try not to let it be you, if it is, try not to take anyone with you.
Better you than me
And neither of these things will make any difference when a HP Canopy Pilot makes a mistake and doesn’t see that slower canopy already on Final when they start their 180 or 270. Then it is too late.
How are you going to "Educate" these people with 1000`s of jumps that already think they are bullet proof??
Humans make mistakes. They will continue to make mistakes no matter how much education they have.
Education is a nice concept, but it isn’t going to change the fact that we don’t have eyes in the back of our head and even if we did there isn’t much we can do when someone is coming out of a Blind Turn (180 or 270) heading straight for us at a very high rate of speed. Nothing we can do at that point but pray.
I spent years working as an Engineer designing and building Industrial machinery. Every machine had to be redesigned constantly because the operator (regardless how much training and education you gave them) would still find ways to hurt themselves and/or others. We had to design the machines where it was harder and harder for the operators to do that. Still they would find a way.
Same here. We have to make it harder for people to find a way to have canopy collisions. Right now it is very easy for this to happen. All it takes is One canopy pilot not seeing Someone else till it is too late. Separating Fast Moving canopies from slow moving canopies is necessary to accomplish that.
Absolutely. If you have to Swoop, Do it where you are not putting others in danger.
