kschilk 0
QuoteHey I know, it could have a motion and proximity sensor on it like a supermarket door, or maybe a laser velocity sensor like the cops use in the speed-traps. That way it would fire automatically. I'll get to work on the design.
Nah....hook it up to a "clapper"!
For your info i have come off a bike at 100mph plus,, it really hurts, both the original fall and the sliding and the sudden stop on the central reservation.
NO breaks, a lot of bruises.. the impact clothing i was wearing took a lot of the hit, it was shreaded to peices in the slide.. but a walk away none the less.
You didn't have a sudden stop going 100 and then just walk away. Helmets won't deal with impacts at even 30. High speed getoffs are survivable because you only fall a bit and then you slide a long long way on an open road. If race tracks had as many barriers as the trafficked roads do the fatality rate would be much much higher.
riggerrob 644
I am old and grumpy and made up my mind on this subject 15 years ago. ... and I am not in a mood to learn anything new!
HUMPF!
I wear a Pro-Tec helmet on every jump.
It is covered in scratches to explain why I wear it: door jams, riser slap, etc.
Similarly, I always wear gloves to protect my fingers against riser slap.
Finally my prescription goggles were specifically chosen to survive "loving" students slamming my head into door frames.
And I can still do more tandems per day than most of the "skygods" half my age!
Neener neener neener!
QuoteQuote
NO breaks, a lot of bruises.. the impact clothing i was wearing took a lot of the hit, it was shreaded to peices in the slide.. but a walk away none the less.QuoteQuote
"You didn't have a sudden stop going 100 and then just walk away"
Sorry i did not know you were there at the time..
Were you the big skeletal figure carrying a large scythe dressed in black, I have'nt seen you in months. good to hear from you.
I did stop pretty quickly maybe 50 - 60 M..
I did just walk away....
I did not break anything....
You know what I don't mind if you wear the gear or not... maybe you don't wear a Helmet whilst skydiving.. maybe you don't wear leathers whilst motorcycling.
The fact of it is, Impact clothing has the clue in the name.. your right at 75mph straight into the ground it won't do a lot, 35mph though it may save you from spliiting your spleen, and in a rough ride across the ground after tripping whilst hammering in it'll save your bits, or act as a handy splint / compression kit untill the paramedics arrive..
QuoteQuote
Let's frame this on topic. If proper gear could make it possible to survive sudden impact at 100mph, then Jeb wouldn't need $4M to land his wingsuit without a parachute. His vertical speed is far lower than 100. Smaller women could belly land without even using the wingsuit.
Jeb does not need $4m to land his wingsuite. he needs maybe $50 000. the other 3.95 million is for him and his mates to party with,once he is in peices. or pulls 60ft above the ground, and calls it off minus the $4m.
The whole point of the thread is whether Impact gear can help in case of a crash...
I agree worst case senario.. in full flight tilted 90 degrees towards the earth there aint a lot that will save you...
But the point of the thread was wether if tilted at say 60 degrees impact gear could save injuries....
I disagree!!
Merry christmas though :)
