skydive4u2
skydiving weather website
I use this one religiously:
http://www.usairnet.com/weather.htm
Select your state in the "Launch Code" drop down, then your location in the "Get Forecast" drop down. The next screen gives you loads of GREAT information for planning. Links at the top right lead to radar images and sunrise/sunset info.
Winds aloft info is also available starting from the opening page, although the selection of reporting locations is not as good.
Arrive Safely
John
I also use the local ASOS telephone numbers to get real-time automated reports for airports in close proximity to the DZ I am jumping at. You can find your local numbers here:
http://www.faa.gov/airports_airtraffic/weather/asos/
If you are a fellow Raefordite, here are the local numbers:
Fayetteville (910) 484-1546
Laurinburg (910) 844-5338
Southern Pines (910) 692-4287
Arrive Safely
John
