Broke 0 #26 February 22, 2008 wind at your back you will want to put your canopy into minimun sink mode deep brakes. Wind coming at you from the front at a high speed you will want to use your front risers. Winds not as high rear risers may be the thing to do. Also don't forget about loosening your chest straps. Do minimal corrections, and lift your feet up. Of course every canopy is different, so you will have to find what works for your canopyDivot your source for all things Hillbilly. Anvil Brother 84 SCR 14192 Quote Share this post Link to post Share on other sites
shropshire 0 #27 February 22, 2008 Quote Do some CREW. It will become immediately apparent how your canopy is flying--i.e., what toggles vs. rears does, how much fronts do you need to get down, etc. That's a great idea (.)Y(.) Chivalry is not dead; it only sleeps for want of work to do. - Jerome K Jerome Quote Share this post Link to post Share on other sites
Dean358 0 #28 February 23, 2008 Great to see a polar posted on this forum – thanks Kallend! Please correct me if I’m wrong but I believe that a big difference between a sailplane wing and a canopy however is that unlike a sailplane’s wing the shape of a canopy changes with different control inputs. Specifically, brakes distort the shape of a canopy where as rear risers change the overall angle of attack of the canopy but leave the shape more alone, i.e., flat. I assume that’s why in no wind conditions I can get a better L/D out of my Saber-2 170 with rear risers than with toggles. Of course, as has been pointed out, with a good tail wind it’s much more important to go for minimum sink which I seem to get by using full brakes. P.S. – Perhaps just a tall tale, but I’ve been told that the “yaw string” was invented by one of the Wright brothers – the first airplane instrument.www.wci.nyc Quote Share this post Link to post Share on other sites
billvon 3,154 #29 February 24, 2008 >Specifically, brakes distort the shape of a canopy where as rear risers > change the overall angle of attack of the canopy but leave the shape > more alone, i.e., flat. Both distort a canopy. Rear risers tend to introduce a step in the center of the canopy, whereas brakes tend to deflect the back of a canopy. Note that the control surfaces of a sailplane wing are designed to do the same thing (i.e. distort the wing) but within the limitations of a rigid wing. Quote Share this post Link to post Share on other sites
