ShadowCount 0 #1 May 19, 2008 What happens if you pop the brakes during deployment? Quote Share this post Link to post Share on other sites
phoenixlpr 0 #2 May 19, 2008 QuoteWhat happens if you pop the brakes during deployment? In what phase? You have a nice chance to spin up. Why would you do that? Quote Share this post Link to post Share on other sites
ShadowCount 0 #3 May 19, 2008 I wouldn't do it. However. Say you deploy and during the snivel you see a canopy deploying in front of you. You'd want to get at the toggles as soon as possible I guess. So this is only useful when the canopy is fully inflated? Quote Share this post Link to post Share on other sites
shropshire 0 #4 May 19, 2008 You don't need Toggles to steer the canopy.. That is only one of the control modes.... You can use the risers and/or weight shift too. (.)Y(.) Chivalry is not dead; it only sleeps for want of work to do. - Jerome K Jerome Quote Share this post Link to post Share on other sites
damion75 0 #5 May 19, 2008 Quote I wouldn't do it. However. Say you deploy and during the snivel you see a canopy deploying in front of you. You'd want to get at the toggles as soon as possible I guess. So this is only useful when the canopy is fully inflated? There are eight controls you can use to steer your canopy... I'll let you work out what they are for yourself. *************** Not one shred of evidence supports the theory that life is serious - look at the platypus. Quote Share this post Link to post Share on other sites
michalm21 2 #6 May 19, 2008 possibly this: http://www.skydivingmovies.com/ver2/pafiledb.php?action=file&id=6957 Quote Share this post Link to post Share on other sites
TrickyDicky 0 #7 May 19, 2008 I was always told (from my first packing course, if not my first jump course) that having the breaks set for deployment was to actually force air into the canopy. Without the breaks set, you're likely to get a streamer. So taking them off during deployment is likely to have a similar effect, as shown in that video. UK Skydiver for all your UK skydiving needs. Quote Share this post Link to post Share on other sites
shropshire 0 #8 May 19, 2008 I thought that they are set to slow the canopy (air speed) down, otherwise it's would want to fly fast and dive as soon as it was fully open. (.)Y(.) Chivalry is not dead; it only sleeps for want of work to do. - Jerome K Jerome Quote Share this post Link to post Share on other sites
kschilk 0 #9 May 19, 2008 Quote There are eight controls you can use to steer your canopy... I'll let you work out what they are for yourself. Oh, I know what #1 is....loading-up on beans and cabbage, the night before and using "thrust-vectoring"! "T'was ever thus." Quote Share this post Link to post Share on other sites
DSE 5 #10 May 19, 2008 QuoteI was always told (from my first packing course, if not my first jump course) that having the breaks set for deployment was to actually force air into the canopy. Without the breaks set, you're likely to get a streamer. So taking them off during deployment is likely to have a similar effect, as shown in that video. You were taught that un-set brakes would result in the canopy not coming out of the bag correctly, and/or would be a high speed mal? Quote Share this post Link to post Share on other sites
d123 4 #11 May 19, 2008 Quote There are eight controls you can use to steer your canopy... I'll let you work out what they are for yourself. I come up with 2 for sure and *maybe* 3 - rear risers. My 1st choise for turn (into the wind or whatever) until I un-stow the brakes. - brakes. - weight shift? Maybe works haven't try it and I wont try it during the snivel. With brakes stowed front risers pressure its impossible.Lock, Dock and Two Smoking Barrelrolls! Quote Share this post Link to post Share on other sites
shropshire 0 #12 May 19, 2008 QuoteYou don't need Toggles to steer the canopy.. That is only one of the control modes.... You can use the risers and/or weight shift too. Dont for get - Do Nothing (Full drive) another valid Control Mode. So 1 Full drive 2. One Control (part way, full extent or anywhere in between) 3. Both controls together (slo flight mode... Very important) 4. Rears 5. Fronts 6. Weight Shift (Harness) 7. Combination of any of the above (.)Y(.) Chivalry is not dead; it only sleeps for want of work to do. - Jerome K Jerome Quote Share this post Link to post Share on other sites
Foster 0 #13 May 19, 2008 Quote Quote There are eight controls you can use to steer your canopy... I'll let you work out what they are for yourself. I come up with 2 for sure and *maybe* 3 - rear risers. My 1st choise for turn (into the wind or whatever) until I un-stow the brakes. - brakes. - weight shift? Maybe works haven't try it and I wont try it during the snivel. With brakes stowed front risers pressure its impossible. Front risers Rear risers Brakes Harness I think he is counting left and right as seperate... Quote Share this post Link to post Share on other sites
billvon 3,161 #14 May 19, 2008 >With brakes stowed front risers pressure its impossible. Tony Domenico avoided what likely would have been a fatal collision by using front riser on opening a few weeks back. Quote Share this post Link to post Share on other sites
shropshire 0 #15 May 19, 2008 Quote Front risers Single = mode 1 Double = mode 2 Rear risers Single = mode 3 Double = mode 4 Brakes Single = mode 5 DOuble = mode 6 Harness = mode 7 Full Drive = mode 8 (.)Y(.) Chivalry is not dead; it only sleeps for want of work to do. - Jerome K Jerome Quote Share this post Link to post Share on other sites
Fast 0 #16 May 19, 2008 QuoteQuote Front risers Single = mode 1 Double = mode 2 Rear risers Single = mode 3 Double = mode 4 Brakes Single = mode 5 DOuble = mode 6 Harness = mode 7 Full Drive = mode 8 The 8 inputs that you can use on your canopy are: Left Front Riser Right Front Riser Left Rear Riser Right Rear Riser Left Toggle Right Toggle Left Harness Right Harness The number of things you can do at once is a combination of the above inputs. There are a lot of weird combinations that do some interesting stuff. CRW dogs use some of them! You can also pull on individual lines, but there isn't a whole lot of use for that in 99% of situations. Anyways, the fastest means of avoiding a collision on opening is to not unstow the brakes and to use one of the other 6 inputs available. For what it's worth, leaning in your harness doesn't work really well with a larger canopy. Feel free to try it though and see what happens. I have gone from jumping my velocity103 to jumping a Manta288 while working on one of my instructor ratings. It's kinda a weird feeling when you are used to being able to just lean a little bit and start doing spirals.~D Where troubles melt like lemon drops Away above the chimney tops That's where you'll find me. Swooping is taking one last poke at the bear before escaping it's cave - davelepka Quote Share this post Link to post Share on other sites
Amazon 7 #17 May 19, 2008 I just look at that as a little extra fun and excitement when added at the end of a jump as the canopy is deploying and going into an interesting spin... woo hoo... a little spin to keep life interesting. Quote Share this post Link to post Share on other sites
pilotdave 0 #18 May 19, 2008 Quote The 8 inputs that you can use on your canopy are: Left Front Riser Right Front Riser Left Rear Riser Right Rear Riser Left Toggle Right Toggle Left Harness Right Harness The jumper in this video steers just fine without using any of those inputs: http://www.skydivingmovies.com/ver2/pafiledb.php?action=file&id=3673 Pulling an outer A/B line does the trick nicely (for our "don't try this at home" file). Dave Quote Share this post Link to post Share on other sites
peckerhead 0 #19 May 20, 2008 QuoteWhat happens if you pop the brakes during deployment? Are you asking what happens if you release the brakes during a snivel? If you pull them down evenly and let up at the same time it should make the canopy inflate faster. The nose goes down and the tail goes up. The reason we stow the brakes is because we don't want it to open too fast. History lesson Before ZP it was common procedure to pop your brakes to stop a snivel. I had a Raven that would snivel for a thousand feet and I jumped a Unit that would probably not open at all unless you popped the brakes. Some things change but some things don't. Quote Share this post Link to post Share on other sites
davelepka 4 #20 May 20, 2008 QuoteIf you pull them down evenly and let up at the same time it should make the canopy inflate faster. The nose goes down and the tail goes up. The reason we stow the brakes is because we don't want it to open too fast. I've had a different experience. I used to jump a Sabre with the brakes unstowed to get it o snivel more. It full flight it took longer to inflate. Additionally, I had a Stiletto with an 'older' lineset that was opening too fast. I relocated the cats eye to a lower position on the brake line, and the canopy went back to opening more slowly. I'm pretty sure that if your canopy is sniveling too long, unstowing the brakes and pulling them down will help to bring the slider down faster. Much like tugging on the back risers will bring a slider down as well (which I do with my Velo on extra low hop n pops where the airspeed is low, and I don't have time for a snivel). Quote Share this post Link to post Share on other sites
Fast 0 #21 May 20, 2008 Quote Quote The 8 inputs that you can use on your canopy are: Left Front Riser Right Front Riser Left Rear Riser Right Rear Riser Left Toggle Right Toggle Left Harness Right Harness The jumper in this video steers just fine without using any of those inputs: http://www.skydivingmovies.com/ver2/pafiledb.php?action=file&id=3673 Pulling an outer A/B line does the trick nicely (for our "don't try this at home" file). Dave Are you saying he was doing turns by some other means or by pulling on the a/b lines? I did mention that you can pull on individual lines but given the circumstances of the original question, it wouldn't be the best way to deal with the problem. ~D Where troubles melt like lemon drops Away above the chimney tops That's where you'll find me. Swooping is taking one last poke at the bear before escaping it's cave - davelepka Quote Share this post Link to post Share on other sites
