gregpso 1 #1 June 25, 2008 I have just returned to sport after 25years (old t10s) Quick question are the big tandem canopies less likely to mal than the new high performance ram air ones. My family will be making tandems soon. Also prob a stupid question but re the 3 ring cutaway system has there ever been a documented case where the canopy cutaway without the jumper pulling anything. I suppose this system has stood the test of time.. but if it just cutaway at 200 feet.. good night.I tend to be a bit different. enjoyed my time in the sport or is it an industry these days ?? Quote Share this post Link to post Share on other sites
AggieDave 6 #2 June 25, 2008 QuoteQuick question are the big tandem canopies less likely to mal than the new high performance ram air ones. Any canopy can malfunction. Most of it has to do with maintance and packing. I've had more tandem rides then sport rides, BUT there are others who are different. QuoteAlso prob a stupid question but re the 3 ring cutaway system has there ever been a documented case where the canopy cutaway without the jumper pulling anything I'm sure there is, but I haven't heard of one from a properly built and maintained 3-rings setup. You might have some old fart that knew a guy that heard his buddy had a friend go in due to his 3-rings releasing in 1981, but there's a reason why its the hands down standard!--"When I die, may I be surrounded by scattered chrome and burning gasoline." Quote Share this post Link to post Share on other sites
humanflite 0 #3 June 25, 2008 Quote I have just returned to sport after 25years (old t10s) Quick question are the big tandem canopies less likely to mal than the new high performance ram air ones. My family will be making tandems soon. Also prob a stupid question but re the 3 ring cutaway system has there ever been a documented case where the canopy cutaway without the jumper pulling anything. I suppose this system has stood the test of time.. but if it just cutaway at 200 feet.. good night. Stop thinking so deeply and do the tandem You cauld get runover by a bus because you 'hadnt foreseen that the subway you were walking on collapsed' etc etc ad infinatum but as to the 3 rings question. The tandems at our DZ use an RSL (reserve static line) which when the 3 rings sytem is used and the canopy is cutaway, acts to pull the reserve out with the main thaty has been cutaway. If anyone cuts away at 200ft they are gonna have problems....but..and some of the experienced people here will hopefully comment (as Im a newbie) but Ive only heard of 3 ring system detachment (partial) due to catching the cutaway pad velcro or other accident. Quote Share this post Link to post Share on other sites
hackish 8 #4 June 25, 2008 I think it's good to educate yourself about the risks and the equipment before doing your tandem. As for the 3-rings any tandem master I've seen carefully checks the equipment before jumping it. This includes making sure that the 3 rings are properly configured (cutaway cable is properly routed and has enough cable stowed past the loop). Most tandem rigs are equipped with an RSL and stevens lanyard - at least ours are. This ensures that the reserve will deploy if either or both of the 3 rings are released. A growing number of tandem rigs are also equipped with skyhooks which can deploy the reserve in as little as 75' -Michael Quote Share this post Link to post Share on other sites
riggerrob 644 #5 June 25, 2008 Modern tandem mains (ZP fabric) malfunction less often than sport mains ... way less often than zippy little pond swoopers. We worked the bugs out of 3-Ring releases 20-plus years ago. Unintentional cutaways are almost non-existent. Quote Share this post Link to post Share on other sites
billvon 3,130 #6 June 25, 2008 I have about 5500 jumps; about 200 of those were tandems. I've had 3 reserve rides on tandems and 2 on my gear. Quote Share this post Link to post Share on other sites
humanflite 0 #7 June 25, 2008 Quote I have about 5500 jumps; about 200 of those were tandems. I've had 3 reserve rides on tandems and 2 on my gear. yeah, but who packs your tandem canopy? I bet its not ? and I bet you pack your own sport gear though... Quote Share this post Link to post Share on other sites
rushboy 0 #8 June 26, 2008 As your grade 3 teacher once told you..."The only stupid question is the one you don't ask..." Welcome back to the sport... If you are not living on the edge, you are taking up too much space. Quote Share this post Link to post Share on other sites
AggieDave 6 #9 June 26, 2008 Quoteyeah, but who packs your tandem canopy? I bet its not ? Tongue and I bet you pack your own sport gear though... I rarely pack my sport gear. I have 1300 tandems out of my 2400 jumps. I have had 4 tandem rides and 2 sport rides.--"When I die, may I be surrounded by scattered chrome and burning gasoline." Quote Share this post Link to post Share on other sites
des 2 #10 June 27, 2008 24 tandem chops,0 on my own gear,but i do have more tandem jumps than fun jumps Quote Share this post Link to post Share on other sites
deadbug 0 #11 June 28, 2008 Line overs and tension knots seem to be the common tandem mals. Line twist resulting in a spinning mal on hot sport canopies seems to be the common sport mal. Doug Quote Share this post Link to post Share on other sites
skydived19006 4 #12 June 30, 2008 Over 2000 tandems, Zero malfunctions! No tandem malfunctions primarily due to good gear manit, good packing, and no Dacron line tandem mains. I did look up yesterday to see my slider stuck way up, with slack line below it, then it popped down. Had a discussion with packers on potential causes of tension knots. My drop zone over 7 years, and 4000 to 5000 tandems, one line over tandem mal! Talking the other day with a guy who trained with us, and now jumps at a fairly large Texas DZ. I asked him how many tandem malfunctions he has, and I think it's something like 10. He said "You guys don't have packers doing two tandem packs per Otter cycle." No, we don't! Somewhere over 1000 jumps on sport mains, one line twist cut away, one student pull above 2000' fired an FXC AAD, released the main.Experience is what you get when you thought you were going to get something else. AC DZ Quote Share this post Link to post Share on other sites
