Andy9o8 3 #27 August 7, 2008 QuoteWhat happened? http://www.dropzone.com/cgi-bin/forum/gforum.cgi?post=3287168;sb=post_latest_reply;so=ASC;forum_view=forum_view_collapsed;;page=unread#unread Quote Share this post Link to post Share on other sites
dugy 0 #28 August 7, 2008 Interesting posts. Weight: Yeah if you buy a cheap one they are going to be about 1kg heavier. But this will have less of an impact on you neck than a top mounted camera. Visibility: Go put a helmet on, and look down, unless you've got your Imperial Storm Trooper, or Iron Man helmet on, or a neck bigger than fat albert you should be able to see your nipples (blokes). If you're handles are higher than that, you've got a problems anyway. Actually if you've got a neck like FA then you can probably see your nipples in the Iron Man Helmet. Visor opening: Ever watched a MotoGP race? I think Nicky Hayden still races, give him a call and ask him what speeds the guys in front do. They definately offer more protection than the eskys we normally put on our mellons. But the protection is probably only really benificial to swoopers or a regular jumper than doesn't know how to flare. The reality is you won't look cool. (Unless you're swooping.) So best not to wear one. Quote Share this post Link to post Share on other sites
