roccoflys 0 #1 August 18, 2008 does anyone have a link/copy of the exit seperation "packet" hanging by manifest at skydive arizona? i've searched a bit on here, but to no avail(and i gave up quickly). also would love the guidelines that are posted in the planes there... thanks for your help! i'm on a mission to squash the "45 degree rule" at my dz! Quote Share this post Link to post Share on other sites
LouDiamond 1 #2 August 18, 2008 The article you are referring to was written by Brian Burke. The article can be found in the Safety section of the site here but it appears that the link is broken at the moment. The other information that you asked about can be found in the document attached to this post(and then some). One thing that has changed in the document is in regards to turns and landing. Check with manifest to get the latest rules for turns. The placards inside the aircraft explain the lights ,your actions during take off(helmets, seat belts) and if you are on one of the skyvans, there is is an explanation of the CG point and how many people are allowed beyond the red line at one time. If you have any other questions don't be afraid to e-mail Skydive Arizona directly as they are prompt in replying to e-mails.PS: I've attached an Excel sheet on exit separation that can be used by the door of the aircraft. If you want to learn more about "exit separation" do a search as there are a few very informative threads on the topic. "It's just skydiving..additional drama is not required" Some people dream about flying, I live my dream SKYMONKEY PUBLISHING Quote Share this post Link to post Share on other sites
roccoflys 0 #3 August 19, 2008 thank you for the links! what i was referring to inside the aircraft is the notes on exit seperation(i.e. group size, discipline and ground speed). it may be included in the link, as i haven't opened it yet. thank you for your help. ah... it IS the link you sent! Quote Share this post Link to post Share on other sites
kallend 2,196 #4 August 19, 2008 Quotedoes anyone have a link/copy of the exit seperation "packet" hanging by manifest at skydive arizona? i've searched a bit on here, but to no avail(and i gave up quickly). also would love the guidelines that are posted in the planes there... thanks for your help! i'm on a mission to squash the "45 degree rule" at my dz! If you want to debunk the "45 degree myth", try this. And Here's a long thread on the subject.... The only sure way to survive a canopy collision is not to have one. Quote Share this post Link to post Share on other sites
