reyno_gr 0 #1 March 27, 2005 I've just been reading some bits in 'The Skydiver's Handbook' by Dan Poynter and Mike Turoff. It suggests that a main will open within 3 to 4 seconds with a reserve taking slightly less. The book suggests this equates to about 700 feet (assuming the freefaller is at terminal i.e. 120 mph). An expert Cypres fires at 750 feet which, by my logic means that if a skydiver lost altitude awareness and had a Cypres fire they would have about 50 feet to find the toggles and select a safe landing area. Now that's a very small margin!! Is this statement correct or am I missing the point? With regards to aircraft emergencies it suggests that expert jumpers may elect to jump from a stricken plane between 500 and 1000 feet. From a personal point of view the plane would have to be pretty much engulfed in flames to get me out at 500 feet, especially if the reserve takes about 700 feet to deploy (although I accept this assumes terminal velocity not an enforced hop and pop). Any views regarding the accuracy of this information? Quote Share this post Link to post Share on other sites
AggieDave 6 #2 March 27, 2005 A reserve should open within 300-400ft, a main opens anywhere from 400-1000ft. My XF2 consistantly takes 900ft to open, for instance. As for when to get out in an AC during an emergancy. Depends on the plane and the pilot. When a 182 I was in lost the engine at 200ft I stayed in and the pilot landed us perfectly in a cow pasture (no injuries, not even a bump or a bruise). However, the wing falls off or some other random (probably not going to happen) incident along those lines I'd rather take my chances with my reserve. That's just IMO, so please talk to your S&TA and/or your instructors about these scenerios!--"When I die, may I be surrounded by scattered chrome and burning gasoline." Quote Share this post Link to post Share on other sites
ryoder 1,590 #3 March 27, 2005 Bear in mind there is a huge difference in altitude lost when you deploy at a specified altitude at terminal, vs doing a hop & pop from an aircraft at that altitude. In the latter case, you will be starting with a vertical velocity of zero, but you will have plenty of airspeed (from the a/c) to deploy the canopy, so you will open with much less altitude loss than if you had been at terminal at that altitude."There are only three things of value: younger women, faster airplanes, and bigger crocodiles" - Arthur Jones. Quote Share this post Link to post Share on other sites
mark 107 #4 March 27, 2005 Check your assumptions. If your reserve takes 4 seconds to open, do you think you'll be falling at 120 mph at the 3-second point? And if you exit an airplane moving horizontally at 80 or 100 mph 500 feet above the surface, what is the length of your trajectory to the ground? Mark Quote Share this post Link to post Share on other sites
tdog 0 #5 March 28, 2005 Quote In the latter case, you will be starting with a vertical velocity of zero, but you will have plenty of airspeed (from the a/c) to deploy the canopy, so you will open with much less altitude loss than if you had been at terminal at that altitude. So at a low altitude bailout - the faster the airspeed of the aircraft the better - so you can use the forward throw of the plane to give you airspeed to fill your reserve the quickest???? Side question... Faster you go, the harder the reserve opens - I.E. "terminal opening". But, that does not mean you are using the least distance to get to stable canopy flight. Specifically, does a longer, softer opening at, let say 80MPH relative wind speed take more or less distance than a harder opening at 130 MPH relative wind speed? Quote Share this post Link to post Share on other sites
Kris 0 #6 March 28, 2005 Another thing you're forgetting as well....as soon as that bag comes off your back you're already starting to decelerate. Same thing when your canopy is snivelling. This is a big reason why people think they have 1000' openings, although they're very rare. A really slow opening on my Stiletto, where it snivels for 2-4 seconds, is usually only chewing up about 400-600 feet. I watched someone deploy about 300' away from me and they swore they had a 1000' opening, it was maybe 400'. It's more of a perception thing.Sky, Muff Bro, Rodriguez Bro, and Bastion of Purity and Innocence!™ Quote Share this post Link to post Share on other sites
Andrewwhyte 1 #7 March 28, 2005 I've had 1500' openings on tandems and they really do take a long time (like fifteen seconds). Quote Share this post Link to post Share on other sites
Kris 0 #8 March 28, 2005 QuoteI've had 1500' openings on tandems and they really do take a long time (like fifteen seconds). Another reason why I'm not getting a tandem rating. Tandem mains and reserves are different animals, I'll grant you that. If my Stiletto isn't open after 5-6 seconds of snivel, I'm tugging on the rears to speed things up then chopping it if it still wants to just stay all compressed and pouty about opening. But, thanks for proving my point, 15 seconds for 1500 feet is roughly half belly terminal speed.Sky, Muff Bro, Rodriguez Bro, and Bastion of Purity and Innocence!™ Quote Share this post Link to post Share on other sites
JohnMitchell 16 #9 March 28, 2005 Quote Another reason why I'm not getting a tandem rating. Tandem mains and reserves are different animals, I'll grant you that. That's why we pull so dang high all the time. Quote Share this post Link to post Share on other sites riggerrob 643 #10 March 28, 2005 According to TSO standards, reserves are supposed to open in less than 3 seconds and less than 300 feet. Tandem reserves are allowed slightly more time and distance for inflation. Quote Share this post Link to post Share on other sites billvon 3,114 #11 March 28, 2005 >An expert Cypres fires at 750 feet which, by my logic means that if a >skydiver lost altitude awareness and had a Cypres fire they would have > about 50 feet to find the toggles and select a safe landing area. Now >that's a very small margin!! Is this statement correct or am I missing the > point? Well, reserves open faster than that, but also cypreses can fire lower than that. They have simple barometric triggers which sense altitude, and they can easily be off by a few hundred feet. We had a very low cypres firing at Perris a few weeks back, and the jumper only had about 10 seconds under canopy before he landed. A cypres is intended as impact prevention, little more. It's not designed to give you altitude to release your toggles, do a few practice flares, find a landing area etc. >From a personal point of view the plane would have to be pretty much > engulfed in flames to get me out at 500 feet . . . If the plane were on fire and going down I'd get out at 100 feet. If I could really get out at 100 feet (i.e. not start to open the door at 100 feet and get out just before impact) then I figure my reserve would at least stand a chance at slowing me down to a survivable speed before impact. It would depend on how bad the aircraft emergency was. Quote Share this post Link to post Share on other sites reyno_gr 0 #12 March 28, 2005 I never considered that AAD'S would be less than 100% accurate in their activation altitude. A difference of a hundred feet is a sobering thought but I guess the bottom line is at least they get a canopy over your head. Another issue arising from this (and yet another thing I'd never considered - thank god for thought provoking forums) is can AAD's be adjusted (like altimeters) if the emplaning point is different from the DZ (i.e there is an altitude difference between the two) or is there no requirement to do so? Quote Share this post Link to post Share on other sites jakee 1,594 #13 March 29, 2005 The Cypres can be set for offset landing areas when you turn it on. I would ASSume other AAD's use a very similar process. Seriously though, more jumps than me and you didn't know that? (Don't mean to be rudeThere is a one or two week old incident thread from Perris that might be an eye opener to you. I strongly recommend you find it and learn from anothers mistake.Do you want to have an ideagasm? Quote Share this post Link to post Share on other sites billvon 3,114 #14 March 29, 2005 >can AAD's be adjusted (like altimeters) if the emplaning point is different from the DZ? I was going to answer "very funny" but I have a sinking feeling you are asking a serious question. Yes. A recent fatality occurred when a woman did not pull in time at Perris. Her cypres did not fire because she turned it on at a different location (a lower elevation) than she jumped at. The instructions on how to turn on the cypres, and how to rezero it or reset it to a different LZ location are contained in the cypres manual. Quote Share this post Link to post Share on other sites NWFlyer 2 #15 March 29, 2005 QuoteThe Cypres can be set for offset landing areas when you turn it on. I would ASSume other AAD's use a very similar process.. The Vigil has that capability as well."There is only one basic human right, the right to do as you damn well please. And with it comes the only basic human duty, the duty to take the consequences." -P.J. O'Rourke Quote Share this post Link to post Share on other sites mjosparky 4 #16 March 29, 2005 If you go through 1,000 feet at terminal, you have about 5/6 seconds until impact. If you step out of an airplane doing 80 to 90 mph at 500 feet, you have about 5/6 seconds until impact. From the time your container opens at terminal you start slowing down and as soon as you step out of the airplane you start slowing down. The difference is that when you step out of the airplane you will only slow down at first then you will speed up. That is if you don't pull. Most reserve canopies are tested to open in 3 seconds. And 3 seconds is 3 seconds no matter how fast you are going. I have stepped out of an airplane at 600 feet and would take that over going through 1,000 feet at terminal anytime. (And BillVon is right, I went for my main.) When your cypres fires it is just about to late for you to do anything useful. SparkyMy idea of a fair fight is clubbing baby seals Quote Share this post Link to post Share on other sites diablopilot 2 #17 March 29, 2005 QuoteI guess the bottom line is at least they get a canopy over your head. No, the bottom line is when the work properly they activate the reserve deployment (cut a loop, or pull a pin).---------------------------------------------- You're not as good as you think you are. Seriously. Quote Share this post Link to post Share on other sites reyno_gr 0 #18 March 29, 2005 Your sinking 'feeling' was right. It was a serious question and apperantly (judging by some of the comments one I should have known the answer too) However, as this information was never imparted to me on my AFF course, and I never received a Cypres manual when I brought my rig (it was second hand) I genuinely didn't know the answer. I haven't come across it in any publication (I've read so far), and as I've always taken off and landed at the same DZ I've never had cause to pose the question till it arose in this forum. Was it missed (by me or my instructors on the AFF course) or am I just dense? At least I know the answer now (and I will get a copy of the Cypres manual too). Thanks for enlightening me. Quote Share this post Link to post Share on other sites wmw999 2,587 #19 March 29, 2005 There's no way that your FJC and even subsequent AFF training can cover everything you might need to know. If you're not near water, you probably haven't had much in the way of water training, but the assumption is that if you get closer to water, you should take the responsibility of asking. Your life is in your hands. It's not in the hands of the gear maker, the Cypres, or anything else. Because you can learn about everything that you jump with, enough to KNOW why it works, and what will reduce its chance of working. Not that you have to. Plenty of people don't. But it's all something you can learn about, and you should know enough to know what you haven't learned. Yes, that sounds weird. But it's your life. Wendy W.There is nothing more dangerous than breaking a basic safety rule and getting away with it. It removes fear of the consequences and builds false confidence. (tbrown) Quote Share this post Link to post Share on other sites AndyMan 7 #20 March 29, 2005 You can download the Cypres Manual here: http://www.cypres.cc/ _Am__ You put the fun in "funnel" - craichead. Quote Share this post Link to post Share on other sites billvon 3,114 #21 March 29, 2005 >However, as this information was never imparted to me on my AFF course, > and I never received a Cypres manual when I brought my rig (it was >second hand) I genuinely didn't know the answer. Your AFF course taught you everything you needed to make it through AFF, but only about 10% of what you need to survive in this sport. Some other good sources of info/ways to learn: 1. Read Parachutist, especially the incident reports. 2. Ask people questions when it's raining. 3. Get the manuals for all the gear you own and read them. Most are available online. Pay special attention to your harness/container manual. 4. Buy your beer for firsts. When you give it out, make sure you tell people why you bought it. You will likely get some good advice/observations/stories about what happened when they had their first X too. 5. Get a SIM and read it. It will make license tests easier and contains useful stuff. 6. Go to new DZ's and ask people there why they do things differently. >Was it missed (by me or my instructors on the AFF course) or am I just dense? I think this happens a lot - once people are off AFF they don't get much further education. The ISP was intended as a way to get more education out there but it is of limited effectiveness since not all DZ's implement it. When there's no ISP you have to be more aggressive in learning stuff yourself. Quote Share this post Link to post Share on other sites riggerrob 643 #22 April 2, 2005 QuoteQuote Another reason why I'm not getting a tandem rating. Tandem mains and reserves are different animals, I'll grant you that. That's why we pull so dang high all the time. >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Just to amuse myself, I used to play "beat the beeper" by setting my Dytter to 5,000 feet and trying to time my pull so that my Dytter would "dyt" during line stretch. Quote Share this post Link to post Share on other sites bodypilot1 0 #23 April 2, 2005 QuoteI've had 1500' openings on tandems and they really do take a long time (like fifteen seconds). Holly shit! 15 seconds? I know POSITIVELY that I'd never ride any tandem canopy that took 15 seconds to open. That's WAY too long if your pulling at 5000ft, I'd look at the trim of the canopies. Be safe. Edwww.WestCoastWingsuits.com www.PrecisionSkydiving.com Quote Share this post Link to post Share on other sites Andrewwhyte 1 #24 April 2, 2005 It has happened a few times, ususally with tiny passengers. Trim's usually ok, but on older canopies for sure. I leave that stuff up to riggerrob. Quote Share this post Link to post Share on other sites tbrown 26 #25 April 3, 2005 People shouldn't forget that a Cypres will not arm itself until 1500 ft of climbout from takeoff. So if you have to bail from less than 1500 ft, the Cypres isn't going to do ANYTHING at all. Because that's the way they're programmed. Once again, you'll have to pull silver yourself. In the olde days of the seventies, 500 ft used to be considered the minimum acceptable altitude for bailing out, below 500 you kissed your ass goodbye and trusted the pilot. Nowadays it seems more like 1000 ft is the bail or kiss altitude. Personally, if the plane's on fire, falling apart, or in a steep dive, I'll be clawing at the door to get it open and I'll bail at 50 ft because I'd rather bounce than burn. But if the pilot's got the plane in a glide, I'll stay buckled and kiss my ass goodbye, and maybe the ass next to me if she's pretty... Your humble servant.....Professor Gravity ! Quote Share this post Link to post Share on other sites Join the conversation You can post now and register later. If you have an account, sign in now to post with your account. Note: Your post will require moderator approval before it will be visible. Reply to this topic... × Pasted as rich text. Paste as plain text instead Only 75 emoji are allowed. × Your link has been automatically embedded. Display as a link instead × Your previous content has been restored. Clear editor × You cannot paste images directly. Upload or insert images from URL. Insert image from URL × Desktop Tablet Phone Submit Reply 0
