Rover 11 #1 June 20, 2009 If you put an ordinary thermometer in a windflow - like in the airvent inside an aircraft - will it give a true reading or is it affected by a 'windchill' factor?2 wrongs don't make a right - but 3 lefts do. Quote Share this post Link to post Share on other sites
NewGuy2005 53 #2 June 20, 2009 The thermometer would not be affected by wind chill From Wilipedia: Wind chill is the apparent temperature felt on exposed skin due to wind http://en.wikipedia.org/wiki/Wind_chill Quote Share this post Link to post Share on other sites
JohnRich 4 #3 June 21, 2009 QuoteIf you put an ordinary thermometer in a windflow - like in the airvent inside an aircraft - will it give a true reading or is it affected by a 'windchill' factor? Someone get a thermometer, hold it up in front of a fan, and see if the mercury drops. Quote Share this post Link to post Share on other sites
riggerrob 643 #4 June 22, 2009 A dry thermometer will not read "wind chill factor" when the wind changes. You need a special wet thermometer to read "wind chill factor." Quote Share this post Link to post Share on other sites
billvon 3,110 #5 June 22, 2009 >You need a special wet thermometer to read "wind chill factor." That's relative humidity, not wind chill. Wind chill is an effect where rapidly moving air transfers more heat from a warmer body than still air does. If the air is 98.6 degrees, there is no "wind chill" at all, because it can't transfer heat away through conduction. However, the wind can still cool people at those temperatures, because people sweat - and evaporation _does_ cool you when the wind is moving faster. To test for wind chill you use a heated thermometer and see how much the temperature drops under varying conditions. (That's also a way to measure airspeed BTW.) Quote Share this post Link to post Share on other sites
bpeck 0 #6 June 24, 2009 Or just find out the temp and wind speed. Then find a wind chill table.. Quote Share this post Link to post Share on other sites
pirana 0 #7 June 25, 2009 QuoteIf you put an ordinary thermometer in a windflow - like in the airvent inside an aircraft - will it give a true reading or is it affected by a 'windchill' factor? Actually, all other things being equal, with a high enough windspeed, the thermometer will actually read higher, not lower. Friction of the air passing over it will raise the temperature of the thermometer." . . . the lust for power can be just as completely satisfied by suggesting people into loving their servitude as by flogging them and kicking them into obedience." -- Aldous Huxley Quote Share this post Link to post Share on other sites
