superjim 0 #1 August 21, 2009 Anyone else notice that this canopy has a minimum jump weight??? Whats the deal with this??? 121 SQ foot canopy with 21 cells maximum jump wieght of 290 lbs and a minimum of weight of 193 lbs??? Someone clue me in. Does this thing produce more lift then a standard canopy or??? Quote Share this post Link to post Share on other sites
virgin-burner 1 #2 August 21, 2009 i forgot! “Some may never live, but the crazy never die.” -Hunter S. Thompson "No. Try not. Do... or do not. There is no try." -Yoda Quote Share this post Link to post Share on other sites
piisfish 140 #3 August 21, 2009 maybe it's the way the found to steer away people who can not fly at 1.6 wingloading maybe openings and flight characteristics are not good at lower wingloadings.scissors beat paper, paper beat rock, rock beat wingsuit - KarlM Quote Share this post Link to post Share on other sites
phoenixlpr 0 #4 August 21, 2009 Don't you know that heavier than air things can not fly? Quote Share this post Link to post Share on other sites
freeflye73 0 #5 August 21, 2009 Well if you look at PD website they also state min weight(Velocity) X- braced are usually designed to be flown at a higher WL above 2.0. And yes the sensei i Xbraced so it would produce more lift then a standard canopy. So if you plan on jumping a sensei at lower WL save your money and buy something else. And like some else stated it might not perform well if you go under min weight. Quote Share this post Link to post Share on other sites
chuckakers 426 #6 August 21, 2009 QuoteAnyone else notice that this canopy has a minimum jump weight??? Whats the deal with this??? 121 SQ foot canopy with 21 cells maximum jump wieght of 290 lbs and a minimum of weight of 193 lbs??? Someone clue me in. Does this thing produce more lift then a standard canopy or??? That's nothing new. The Nova had a minimum wing loading because it was unstable in turbulance without enough weight hanging from it. I loaded mine 2.3:1 and never had a problem. Of course the Nova was eventually grounded by the manufacturer after several low altitude collapses. Oops.Chuck Akers D-10855 Houston, TX Quote Share this post Link to post Share on other sites
billvon 3,154 #7 August 21, 2009 > Does this thing produce more lift then a standard canopy or??? All functioning canopies produce exactly the same lift, and is exactly equal to the magnitude of the vector sum of your weight and drag. If it wasn't you'd accelerate upwards or downwards. Some canopies require a minimum load to fly well. Stilettos are like this; below about .9 to 1 they are pretty unstable. Quote Share this post Link to post Share on other sites
freeflye73 0 #8 August 23, 2009 Quote> All functioning canopies produce exactly the same lift, and is exactly equal to the magnitude of the vector sum of your weight and drag. If it wasn't you'd accelerate upwards or downwards.<Quote So you are saying that the shape of the airfoil, xbrace to produce a smother topskin etc doesn't play any role in the amount of lift a canopy can produce. if you compare a sabre2 and a velocity of the same size i am quite certain that the velocity is capable of producing more lift, due to having a more effective airfoil. //JF Quote Share this post Link to post Share on other sites DrewEckhardt 0 #9 August 23, 2009 Quote> Does this thing produce more lift then a standard canopy or??? All functioning canopies produce exactly the same lift, and is exactly equal to the magnitude of the vector sum of your weight and drag. If it wasn't you'd accelerate upwards or downwards. Sure. More relevant issues are how slow can it be trimmed to fly with no vertical speed at a given suspended weight and as that approaches how easy is it to kill the remaining forward speed with an abrupt pitch change. Newer cross-braced and bi-cell tapered designs go slower before you can't avoid downwards vertical acceleration, and some canopies are decidedly easier to stop when you don't care to start running on landing when that happens. Quote Share this post Link to post Share on other sites Join the conversation You can post now and register later. If you have an account, sign in now to post with your account. Note: Your post will require moderator approval before it will be visible. Reply to this topic... × Pasted as rich text. Paste as plain text instead Only 75 emoji are allowed. × Your link has been automatically embedded. Display as a link instead × Your previous content has been restored. Clear editor × You cannot paste images directly. Upload or insert images from URL. Insert image from URL × Desktop Tablet Phone Submit Reply 0 Go To Topic Listing
