pojj 0 #1 August 8, 2009 your taught to kick out of line twists but see alot of guys reaching for the risers and trying to spread them apart....is this dangerous can your hand get caught in a tightly bound twist and whats the best canopy for a A licensed jumper that get the least line twists provided that its packed and deployed right Quote Share this post Link to post Share on other sites
labrys 0 #2 August 8, 2009 Spreading the risers is SOP for starting the process of getting out of line twists. Forget the canopy (assuming you're jumping something appropriate for your skill level) and focus on body position and stability to reduce line twists.Owned by Remi #? Quote Share this post Link to post Share on other sites
riggerrob 644 #3 August 8, 2009 On student canopies, it is standard practice to reach up and spread risers help clear line twists. If you grab the risers at shoulder height and slide your hands up, there is negligible risk of jamming. Injured fingers only become an issue on heavily-loaded tandem canopies. Quote Share this post Link to post Share on other sites
chris03852 0 #4 August 9, 2009 I was taught to do both pull risers apart and kick. Still doing AFF so its current advice. Quote Share this post Link to post Share on other sites
Will_Evo 0 #5 August 9, 2009 Section 4, Category A, Topic G, Line D. To untwist the lines, spread the risers and kick,but release the brakes only after clearing the twist. Straight from the SIM.Zoo Crew Quote Share this post Link to post Share on other sites
billeisele 130 #6 August 10, 2009 I've never liked the term "kick your legs" seems like a much clearer solution is to simply - extend your leg out to the side and throw it in the direction that you want to untwist, do that one time and you will continue turning until the twists are outGive one city to the thugs so they can all live together. I vote for Chicago where they have strict gun laws. Quote Share this post Link to post Share on other sites
thedude325 0 #7 August 10, 2009 QuoteI've never liked the term "kick your legs" seems like a much clearer solution is to simply - extend your leg out to the side and throw it in the direction that you want to untwist, do that one time and you will continue turning until the twists are out I just had some serious twists on my last jump. (level 5 AFF) It's so natural; it's easier to do than explain! Quote Share this post Link to post Share on other sites
billeisele 130 #8 August 10, 2009 QuoteQuoteI've never liked the term "kick your legs" seems like a much clearer solution is to simply - extend your leg out to the side and throw it in the direction that you want to untwist, do that one time and you will continue turning until the twists are out I just had some serious twists on my last jump. (level 5 AFF) It's so natural; it's easier to do than explain! yep, except for the folks that you see kicking both legs and squirming around, not to natural for themGive one city to the thugs so they can all live together. I vote for Chicago where they have strict gun laws. Quote Share this post Link to post Share on other sites
Nataly 38 #9 August 10, 2009 Quote your taught to kick out of line twists but see alot of guys reaching for the risers and trying to spread them apart....is this dangerous can your hand get caught in a tightly bound twist and whats the best canopy for a A licensed jumper that get the least line twists provided that its packed and deployed right Just think back to when you were a kid on a swing.. In fact, you could always go on a playground (not during daylight or you might get laughed at by 5 year olds!!), sit on a swing, twist it up and stop. Then try and kick your way out of the twists. Bingo!!! Easy! Now just get a MASSIVE fan blowing toward you and someone to shake you violently around when you do it and it's just like under canopy!!! (NOTE: this is not entirely serious.)"There is no problem so bad you can't make it worse." - Chris Hadfield « Sors le martinet et flagelle toi indigne contrôleuse de gestion. » - my boss Quote Share this post Link to post Share on other sites
crotalus01 0 #10 August 11, 2009 Just make sure you are not still spinning up when you try to spread your risers - I stupidly did that while still spinning and got my right hand wrapped over 3 times. Fortunately I was able to stop spinning up and was able to get my hand free and get all the twists out (I was briefly knocked out from the opening and still groggy when I tried to spread my risers while still spinning - was jumping an original Sabre 190 that has since blown up and been retired). As for me and my house, we will serve the LORD... Quote Share this post Link to post Share on other sites
twistedspark 0 #11 August 11, 2009 I've had line twists that were so severe, and I was still spinning, that kicking didn't do shit. Only by grabbing the lines above the twists and pulling myself up was I able to stop spinning. Then by pulling the risers apart I was able to untwist it all. Basically, do whatever is necessary, and decide to cut-away or land it by 2.5k (A-License) As far as gear that's less likely to give line twists; Line twists are usually caused by uneven packing, uneven line stows, and body position during deployment. I had line twists a few times when I was begining to jump my own gear. By talking to riggers and packers I was able to improve my pack jobs to prevent it. No problems anymore. Quote Share this post Link to post Share on other sites
VideoFly 0 #12 August 12, 2009 Another reason I find it important to be on your risers is that I find that if you even the ends of the risers or get them level with each other, you can stand a better chance of having the canopy fly straight while untwisting the lines. Otherwise, the canopy might tend to dive while untwisting. On the other hand, I have had twists with an eliptical canopy and over a 2 to 1 wing loading that just wanted to keep twisting in spite of my efforts to untwist my lines. In that case, by having your arms extended up on your risers while you look at your lines, your altimeter is in plain sight. Quote Share this post Link to post Share on other sites
Trevor 0 #13 October 9, 2009 I keep my hands on my risers spreading them apart as my canopy opens. When I have line twists, instead of spreading my risers apart and kicking my legs, I simply twist my risers in the opposite direction of twist. This moves the twist down to my chest and the resulting tension spins me back around and out of the twists. I don't know if this technique is unique to my canopy (XAOS 21 88) and 2.3 wingloading, but it works every time. I have never had to cutaway line twists. I do it in this video below: http://www.youtube.com/watch?v=5FD2I8OqbS0#watch-vid-title {edited to fix link} Quote Share this post Link to post Share on other sites
Trevor 0 #14 October 9, 2009 looks like the same technique is being discussed in this thread: http://www.dropzone.com/cgi-bin/forum/gforum.cgi?post=3657394;sb=post_latest_reply;so=ASC;forum_view=forum_view_collapsed;;page=unread#unread Quote Share this post Link to post Share on other sites
JohnDeere 0 #15 October 9, 2009 QuoteI keep my hands on my risers spreading them apart as my canopy opens. When I have line twists, instead of spreading my risers apart and kicking my legs, I simply twist my risers in the opposite direction of twist. This moves the twist down to my chest and the resulting tension spins me back around and out of the twists. I don't know if this technique is unique to my canopy (XAOS 21 88) and 2.3 wingloading, but it works every time. I have never had to cutaway line twists. I do it in this video below: http://www.youtube.com/watch?v=5FD2I8O Can you check your link? I get the message of ...."The URL contained a malformed video ID." I have used this same method but still like to see more video of it being used.Nothing opens like a Deere! You ignorant fool! Checks are for workers! Quote Share this post Link to post Share on other sites
JohnDeere 0 #16 October 9, 2009 Thanks for fixing link. This is prob. the best video (I have seen) showing how well this works Nothing opens like a Deere! You ignorant fool! Checks are for workers! Quote Share this post Link to post Share on other sites
crashtested 0 #17 October 9, 2009 awesome video.. great technique... that is how to roll you dirty high puller Quote Share this post Link to post Share on other sites
