phoenixlpr 0 #1 June 5, 2005 Over what WL can I expect harness turns? I`ve noticed some little, but niticeable left turns of my gear recently. Can it be a reason? Quote Share this post Link to post Share on other sites
linestretch 0 #2 June 5, 2005 that could be your left leg strap is tighter than your right, or you junk is under your left leg strap.....my pics & stuff! Quote Share this post Link to post Share on other sites
rhino 0 #3 June 6, 2005 Check to see if your break lines are twisted. Quote Share this post Link to post Share on other sites
Hooknswoop 19 #4 June 6, 2005 QuoteI`ve noticed some little, but niticeable left turns of my gear recently. Check your line trim. There is an article on my rigging page how to do that. Derek Quote Share this post Link to post Share on other sites
ryoder 1,590 #5 June 6, 2005 QuoteOver what WL can I expect harness turns? In my experience, it takes at least a 1.3 WL for harness turns to be fast enough to be useful. Less than that, you will get a slow turn that may be an annoyance if you aren't doing it intentionally."There are only three things of value: younger women, faster airplanes, and bigger crocodiles" - Arthur Jones. Quote Share this post Link to post Share on other sites
billvon 3,112 #6 June 6, 2005 Any wing loading can result in harness turns. In my experience they are significant above about 1.2 and can become a serious problem if you don't know what you're doing above about 1.5. Quote Share this post Link to post Share on other sites
bodypilot1 0 #7 June 6, 2005 QuoteOver what WL can I expect harness turns? I`ve noticed some little, but niticeable left turns of my gear recently. Can it be a reason? A nut under the leg strap will cause a turn at times also. Be safe. Edwww.WestCoastWingsuits.com www.PrecisionSkydiving.com Quote Share this post Link to post Share on other sites
bch7773 0 #8 June 6, 2005 it would depend on the canopy type as well, yes? MB 3528, RB 1182 Quote Share this post Link to post Share on other sites
phoenixlpr 0 #9 June 6, 2005 I have ~70jumps only in my canopy. I`ve checked and untwisted my brakes, but still.... Quote Share this post Link to post Share on other sites
phoenixlpr 0 #10 June 6, 2005 I`m somewhere WL 1.3..1.4. Quote Share this post Link to post Share on other sites
DancingFlame 0 #11 June 6, 2005 WL ~1.4 might give fast turns. I can make pretty quick 90's with harness input. Quote Share this post Link to post Share on other sites
Squeak 17 #12 June 7, 2005 Quote A nut under the leg strap will cause a turn at times also. Be safe. Ed Yeah but that's 'cause your lifting ya leg trying to get the squashedone out You are not now, nor will you ever be, good enough to not die in this sport (Sparky) My Life ROCKS! How's yours doing? Quote Share this post Link to post Share on other sites
