jigneshsoni 0 #1 June 12, 2005 Who decided the 13500 limit? Is it the kind of aircraft which can only go to that heights? OR is it something to do with law? OR is it due to thin air or cold? I was wondering why not go to 30-40 thousand feet and have a longer free fall? Quote Share this post Link to post Share on other sites
FlyinseivLP2 0 #2 June 12, 2005 Anything over 15000 msl and you are required to use oxygen before the jump. Itis done quite often but is just too expensive and to much of a hassle to do this for every jump. Plus the jump planes climb slower at higher altitudes so it takes longer and burns more fuel. So 13,500 seem to be a coomon altitude. Some DZ's at higher elevations go to 12,500 and most cessna DZ's only go to 10,500 or 11,500 due to slow climb rates. Quote Share this post Link to post Share on other sites
Kris 0 #3 June 12, 2005 Per FAA regulations, above 15,000' MSL, supplemental oxygen is required. Who wants to deal with that on a regular basis? Not me. Now, because of that 15,000' limit, and the fact that very few places are at sea-level, you get the 13,500' cap. Let's say that you're at a DZ that has an elevation of 1000'. That means you can go to 14,000 AGL. 14,000 AGL + 1000' elevation = 15,000MSL. MSL = Mean Sea Level, and AGL = Above Ground Level. There are times when some places will do high-altitude loads, but those are only generally to 23,000'. When you start getting closer to 30K', you have to have bail-out oxygen bottles, special thermal gear, etc... Start going higher than that and you'll need a pressure suit because you can cram all the tank oxygen you want into your lungs, but you can't do anything with it because the oxygen partial pressure is too low. And let's not even get started with how cold it is above 20K, even in AZ or FL during the summer. That's some cold stuff.Sky, Muff Bro, Rodriguez Bro, and Bastion of Purity and Innocence!™ Quote Share this post Link to post Share on other sites
kjarv 0 #4 June 12, 2005 Skydive Tortuga, in Italy, goes to 15,000 ft AGL EVERY LOAD! I love going to that DZ! They are running a Pilatus Porter and a Cessna Caravan...I hope this catches on in the US when I return! Quote Share this post Link to post Share on other sites
tombuch 0 #5 June 12, 2005 Back in the day, 7,500 was considered standard, with 10,000 a 'high' jump, and 12,500 the maximum normal altitude. That was mostly a factor of aircraft efficiency. Today, in the United States, we are governed by FAR 91.211. It specifies: All passengers must be provided with oxygen for that part of the flight in excess of 30 minutes above 12,500 feet. All passengers must be provided with oxygen anytime the aircraft is above 15,000 feet. The required flight crew must use oxygen for the entire time above 14,000 feet. .Tom Buchanan Instructor Emeritus Comm Pilot MSEL,G Author: JUMP! Skydiving Made Fun and Easy Quote Share this post Link to post Share on other sites
PhreeZone 20 #6 June 12, 2005 It won't here unless you are at sea level. The FAR's restrict anyone going above 15000msl from doing so with out supplimental O2 availble. Most DZ's outside the mountianous Western US don't carry O2 on every flight.Yesterday is history And tomorrow is a mystery Parachutemanuals.com Quote Share this post Link to post Share on other sites
Icon134 0 #7 June 13, 2005 Its my understanding that 4-way competition jumps are from 10,500 ft because you only need 35 seconds of measurable jump for competition... so 13,500 isn't exactly a standard... Livin' on the Edge... sleeping with my rigger's wife... Quote Share this post Link to post Share on other sites
